gumba's Avatar
930 intake porting
I picked up a 3.3 intake I need to get ported to 38mm. I also read a couple of old threads about extrude-honed to match the flow. The posts are pretty old, who is still doing this? Is this still the way to go? I was thinking of setting up the intake on my mill to enlarge the opening, but I'm getting there is more to it.
This is for my hodge-podge 3.3/3.0 motor. TK ported the heads, aluminum injector blocks and 3.0 intake (CIS). The current i/c set up has the i/c in the firewall so the 3.0 intake is fine. If I want to try another i/c in the stock position I need the 3.3 intake. I test fit a Andial/Garretson 3.0 i/c (for sale) but it sits too high.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 08-22-2015, 04:02 PM
The 930 manifold is like a flat plenum chamber with 6 holes and a throttle body.
Port match the holes in the manifold to the injector blocks you already have. Doing it by hand with a die grinder is easy.
Old 08-22-2015, 06:48 PM
3 restos WIP = psycho
kenikh's Avatar
Here's how I did it:
My New 1979 930 - yes, another introduction...
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-22-2015, 08:44 PM
Chris at TurboKraft did mine
40mm
nice job , pic's do ot do justice
Forced to Deal with This
Old 08-23-2015, 05:58 AM
kenikh's Avatar
Doing it again, I'd have Chris do it.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-23-2015, 06:00 AM
Crotchety Old Bastard
RarlyL8's Avatar
I'm porting mine soon to match the headwork we did. Don't plan to extrude hone as that just isn't necessary, porting should allow adequate flow for the pancake manifold design.
Old 08-23-2015, 09:02 AM
gumba's Avatar
thanks.
Harold
Old 08-23-2015, 11:27 AM
Alan L's Avatar
The intake manifold is magnesium so real easy to smooth out to shape.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 08-23-2015, 12:19 PM
