LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
this was very interesting to watch. Looks almost DIY able with the proper tools and some space and specs. cool.
Emery
1988 930 coupe - Silver Metallic
TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 05-23-2016, 05:15 PM
Work in Progress
Rich76_911s's Avatar
Another Update:
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 05-24-2016, 10:37 AM
TurboKraft's Avatar
It is DIY-able, that's why we designed it the way we did.
Have sent plenty of these systems out to DIYers installing at home, ex:
Taking the EFI Plunge
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 05-24-2016, 11:07 AM
Brando
quattrorunner's Avatar
Sweet
Turbo powa!
1977 911s. it's cool
Old 05-24-2016, 06:51 PM
Sorry for the lack of updates guys and I appreciate the few of you posting the vids. It's been so hectic since returning home that I find myself with very little time to get onto the forums.
The 930 is still sitting at my brother's home waiting patiently for me to pick it up. The weather is finally summer-like here so my anticipation is to grab it in the coming weeks and start the process of upgrading the suspension and a few other mods I have in mind.
1987 930 Turbo - 3.4L EFI Conversion
Old 05-26-2016, 06:47 AM
onboost's Avatar
Yeah.. that's what he told you!
Your brothers' been out tooling that thing around enjoying the boost! You'll need new tires when you go to pick it up!
Enjoy!
RGruppe #180
Old 05-26-2016, 07:48 AM
TurboKraft's Avatar
Hahaha!
Needed new rear tires anyway, right? ;-)
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 05-26-2016, 09:53 AM
Hello everybody !
I am very curious to know the new power and the torque of the engine in this configuration.
Old 05-26-2016, 10:02 AM
TurboKraft's Avatar
Watch for the next video. :-)
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 05-26-2016, 12:02 PM
Porsche 935's Avatar
Turbocraft, how did that 4.0 liter monster dyno out?
Old 05-26-2016, 12:41 PM
Brando
And the comparo of the turbos
Turbo powa!
Old 05-26-2016, 12:43 PM
TurboKraft's Avatar
Short update here -- keeping separate from this thread.
Turbokraft takes the RWB to the next level
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 05-26-2016, 02:16 PM
Good job Turbokraft. Sad thing is when complete and done all the accomplishments and credit is to RWB. Most people outside this forum have no knowledge who's the ultimate tuner underneath.
Old 05-29-2016, 09:44 AM
AskewRSR's Avatar
Good Point Cody818....... Chris and I are working to change that soon.......
1965 911 Vin 1249 Slate Grey
1969 911 Golden Green 2.0 Twin Plug
1971 911 S Gold Metallic. Peter Gregg
1974 911 RS Euro Metallic Blue Gold lettering
1991 Brumos 3.6 Turbo Pikes Peak Zwart Motor
Old 05-29-2016, 02:44 PM
Ingenieur
I like it! Get a cover over the relay box, and get the rotary IAC plumbed to filtered air though. Otherwise a little rain will park your new ride, and you don't want your new motor sucking dirt.
Old 05-29-2016, 07:42 PM
Mr9146's Avatar
Nice job.
It's always strange to me when a turbo runs without the intercooler...then I remember it's EFI and it all makes sense.
One question: did you pull BOV signal off the throttle body?
Old 05-29-2016, 08:38 PM
Work in Progress
New video
Old 05-31-2016, 07:30 AM
Brando
Wonder why that spring opened so quickly?
Mine is also stock with gt30r and it keeps closed till .85 bar then opens. I get everything by it seems 2900rpm and that spring looks like it's not doing it's job till 5000rpm.
That turbo should get full boost by 2700-3000rpm on that motor for sure! And then be flat till redline.
I'd bet it can do more boost easily as well.
Turbo powa!
Old 05-31-2016, 09:19 AM
I believe the GT30R exhaust housing is too small for 3.4L engine. It is a very good fit for a 3.0L. My GTX7130R makes 1.2 bar at 3000 to 3200 rpm. The GTX7130R flows about the same as a GT7630R. He is using a GTX7630R, the compressor flows about the same as GT3583R, but I read some stuff on the internet that people found the 30R turbine housing to small to power the GTX76 compressor.
Once they have EBC setup, I think they will find that exhaust back pressure will push the wastegate further open at high RPM's dropping boost pressure. To keep boost from dropping, I had to add more DC to my wastegate solenoid to offset the increase in back pressure in the 5500 - 6500RPM range in the coarse of EBC tuning.
-Dennis
1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R
Old 06-01-2016, 10:40 AM
TurboKraft's Avatar
dap, you have your numbering backwards, like Precision does -- it's Garrett GT3076R, not GT7630R. "30R" is the turbine wheel family, "76" is a 76mm diameter compressor wheel exducer.
Pete's car had a GTX3076R, "biggest" of the GT30R-series compressor wheels. Yes, at this low boost pressure, the theoretical airflow of the billet 11-blade 71mm compressor wheel is comparable to a GT3582R cast 6+6 compressor wheel. Theoretical. Start factoring in exhaust flow and pressure, and it affects the turbo's actual performance.
But it isn't the turbine housing that's the flow restriction -- it's the turbine wheel itself.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 06-01-2016, 11:04 AM
