Conversion to Precision 5862 Turbo
Title say`s conversion to a new Turbo after experiences with K27/7200; K27/29; K27 Based Turbo from ETG (never run correctly).
Numbers from the new Turbo: - PT5862 - 58mm inducer compressor wheel (Billet) - "Ported S" compressor cover 4.0" inlet/2.5" outlet - 62mm, 76 trim turbine wheel (A/R 0.82) T3 (T31) 4-Bolt - air-cooled, dual ceramic ball-bearing center housing rotating assembly (CHRA) Some Picture: ![]() ![]() ![]() ![]()
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods |
Fitting Test
Before I bought the new Turbo was clear to me that I have to make some modification.
- Oil feed restrictor - compressor inlet / outlet modification - T3 / T31 muffler fitting issues Fitting Test: ![]() ![]() ![]() ![]()
Fit on T3 Flange
Some work with the carbide milling cutter:
Muffler Flange Modification
Don`t fit:
![]() Need some modification on the muffler flange:
Chain fence eating turbo
I bet you'll love that thing! The hp numbers I've seen from these are huge. Can't wait to hear the results!
I'm sort of surprised PTE doesn't make some kind of direct fit replacement or close for the Triple K 3LDZ 930 application. Market is probably way too small now, though.
930 is a tiny, tiny market, then you have those trying to keep originality plus those who feel nothing holds up as long as a triple-K. There's only losses to sell to the 930 market. |
Mighty Meatlocker Turbo
Not to mention that those weenies don't drive the cars or care about its performance anyway - not much need for a good turbocharger when the car spends all its time parked in a garage and wrapped in a dust cover!
That turbo does look freekin bad to the bone,looking forward to hearing the difference between this one and the one you just took off.
Sent from my SM-N910T using Tapatalk |
Tada! Keep on working Thomas, hope to see some info about performance soon.
Roland 930 Turbo '81 Too many modifications to list |
Missed an earlier pic. I'd get the proper 4" to whatever size that black inlet pipe is in silicone adapter.
Your anti-surge ports might do something funky???? Don't think you can leave those ports open like that??? |
Crotchety Old Bastard
Yes looks like a custom inlet pipe is next.
What do you anticipate the characteristics of this turbo will be on your engine with the mods you have in place? I notice it is not split plenum, do they offer that option?
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
as I met Thomas last week I can say, yes, pipe and more is custom. Regarding split plenum (means twin scroll, right?)I guess it's because of the Fabspeed headers, don't know if Thomas did not want for some reason or Fabspeeds aren't available. I am sure he will post some info about soon.
have a straight hose connector (before cutting)
Turbine outlet size 2mm bigger as a K27/7200 and Compressor inlet size is 3mm smaller as my K27/29 with the 61mm Holset. Hope i love the duall ceramic ball bearing too.
That is true...but you don`t want know how much time that i needed to fix my problems with the "modified" KKK`s.!
930`s want to be driven!!!
