930/66's Avatar
Conversion to Precision 5862 Turbo
Title say`s conversion to a new Turbo after experiences with K27/7200; K27/29; K27 Based Turbo from ETG (never run correctly).
Numbers from the new Turbo:
- PT5862
- 58mm inducer compressor wheel (Billet)
- "Ported S" compressor cover 4.0" inlet/2.5" outlet
- 62mm, 76 trim turbine wheel (A/R 0.82) T3 (T31) 4-Bolt
- air-cooled, dual ceramic ball-bearing center housing rotating assembly (CHRA)
Some Picture:
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods
Old 08-14-2016, 02:16 AM
930/66's Avatar
Fitting Test
Before I bought the new Turbo was clear to me that I have to make some modification.
- Oil feed restrictor
- compressor inlet / outlet modification
- T3 / T31 muffler fitting issues
Fitting Test:
Old 08-14-2016, 02:35 AM
930/66's Avatar
Fit on T3 Flange
Some work with the carbide milling cutter:
Old 08-14-2016, 08:33 AM
930/66's Avatar
Muffler Flange Modification
Don`t fit:
Need some modification on the muffler flange:
Old 08-14-2016, 08:37 AM
This will solve your compressor inlet issue:
4.0
Old 08-14-2016, 11:12 AM
Chain fence eating turbo
I bet you'll love that thing! The hp numbers I've seen from these are huge. Can't wait to hear the results!
Old 08-14-2016, 12:41 PM
I'm sort of surprised PTE doesn't make some kind of direct fit replacement or close for the Triple K 3LDZ 930 application. Market is probably way too small now, though.
Old 08-14-2016, 12:54 PM
That's an understatement!
930 is a tiny, tiny market, then you have those trying to keep originality plus those who feel nothing holds up as long as a triple-K.
There's only losses to sell to the 930 market.
Old 08-14-2016, 02:28 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Originally Posted by Tippy View Post
. . . then you have those trying to keep originality . . .
Not to mention that those weenies don't drive the cars or care about its performance anyway - not much need for a good turbocharger when the car spends all its time parked in a garage and wrapped in a dust cover!
Old 08-14-2016, 02:32 PM
That turbo does look freekin bad to the bone,looking forward to hearing the difference between this one and the one you just took off.
Sent from my SM-N910T using Tapatalk
Old 08-14-2016, 04:39 PM
You are a fact stater
Old 08-14-2016, 04:43 PM
proffighter's Avatar
Tada! Keep on working Thomas, hope to see some info about performance soon.
Roland
930 Turbo '81 Too many modifications to list
Old 08-15-2016, 04:14 AM
Missed an earlier pic. I'd get the proper 4" to whatever size that black inlet pipe is in silicone adapter.
Your anti-surge ports might do something funky????
Don't think you can leave those ports open like that???
Old 08-15-2016, 04:20 AM
Crotchety Old Bastard
RarlyL8's Avatar
Yes looks like a custom inlet pipe is next.
What do you anticipate the characteristics of this turbo will be on your engine with the mods you have in place? I notice it is not split plenum, do they offer that option?
Old 08-15-2016, 04:48 AM
as I met Thomas last week I can say, yes, pipe and more is custom. Regarding split plenum (means twin scroll, right?)I guess it's because of the Fabspeed headers, don't know if Thomas did not want for some reason or Fabspeeds aren't available. I am sure he will post some info about soon.
Roland
Old 08-15-2016, 06:50 AM
930/66's Avatar
4.0
have a straight hose connector (before cutting)
Old 08-15-2016, 12:27 PM
930/66's Avatar
I also hope for good results, I'm going now a new way with that turbo.
Turbine outlet size 2mm bigger as a K27/7200 and Compressor inlet size is 3mm smaller as my K27/29 with the 61mm Holset. Hope i love the duall ceramic ball bearing too.
Old 08-15-2016, 12:36 PM
930/66's Avatar
That is true...but you don`t want know how much time that i needed to fix my problems with the "modified" KKK`s.!
Old 08-15-2016, 12:40 PM
930/66's Avatar
Originally Posted by tippy View Post
that's an understatement!
930 is a tiny, tiny market, then you have those trying to keep originality plus those who feel nothing holds up as long as a triple-k.
+1
Old 08-15-2016, 12:41 PM
930/66's Avatar
930`s want to be driven!!!
Old 08-15-2016, 12:43 PM
