Just spitballin' - 3.6 plenum fit to 3.2/3.3 heads?
Hey,
Just wondering; does a 964/993 plenum line up with the ports on a 3.3 motor, or is there a difference in port-to-port spacing between 1-2-3 on the same bank?
Looks to be pretty trivial to deal with bank-to-bank spacing, if that's different...
Thanks in advance!
'77 S with '78 930 power and a few other things.
Old 08-27-2018, 04:54 PM
Chain fence eating turbo
They’re the same
Old 08-27-2018, 07:26 PM
oh snap's Avatar
I think you just need adapters for the studs. I think rothsport makes them
1985 Iris Blue M491 911 Coupe
Old 08-27-2018, 09:19 PM
Evan Fullerton's Avatar
Clewett makes some or TurboKraft can make them from their 930 aluminum EFI injector blocks. That's the route I went to get a proper taper from the ~42mm VRam intake runner ID down to the 39MM big port SC head size.
Old 08-27-2018, 09:41 PM
Slippery Slope Expert
Steam Driver's Avatar
PM me.
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.”
Old 08-28-2018, 03:16 AM
Cool, thanks guys!
Had hoped it'd be that simple, but wasn't that hopeful...
Was looking at some of these (well, actually, a GT3 RS intake plenum caught my eye first), noticed ends obviously intended to fit straight onto ITBs and thought "hmmmm",
Then, not actually having $4K lying around for a rare carbon fibre motorsport part, I looked at some 964 manifolds and thought "gee, these look functionally identical - but much cheaper...", and "be pretty easy to connect the intercooler outlet to where the throttle body used to bolt on"...
I'm leaning towards alloy over plastic - other than weight, any reason to prefer the plastic ones?
Old 08-28-2018, 09:05 AM
The GT3 plenum is too big for a 3.0-3.3 and N/A engines will lose a lot of low & mid-range power unless ITB's are installed under the plenum. This one is best suited for 3.5 & larger.
The late 964/early 993 plastic ones can be made to work, however you will lose some low end power (unless ITB's are used under the plenum for N/A applications).
For turbo motors, its a nice upgrade when bigger cams are used.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-28-2018, 09:13 AM
Apparently, the plastic ones flow more evenly from runner to runner.
I have an aluminum set if that is not a super concern for sale. It does not have a center section or any other supporting parts. It's just the manifold halves.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 08-28-2018, 09:22 AM
True, but aluminum ones may be Extrude-Honed for effect.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 08-28-2018, 04:38 PM
OK, I probably shouldn't be too coy about why I'm asking, 'coz guys are guessing
Car's a Motec 3.4 930, 8:1, heads ported to match 3.2 manifold(s) and SC cams. Runs great. Throttle response totally unlike CIS...
However, distance from the throttle butterfly to the valves is still ~2 feet; ITBs would seem ideal to further improve throttle response low speed/off-boost.
964 manifolds look like a laughably easy route; drop them on top of ITBs, the intercooler outlet->plenum joint is one fitting, one bend and a straight shot to the manifold throttle body flange...
Or am I missing something obvious?
Old 08-29-2018, 10:26 AM
Exactly what I am going to do. Read my sig.
The 964 intake couples to ITB's with a simple silicone coupler and hose clamp.
Old 08-29-2018, 11:11 AM
sp_cs's Avatar
I’ve have done similar recently using 993 intake and ATPower ITBs - more work still needed due to failed valve stem seals, but runs pretty well. Looking to use the opportunity to increase the CR with new JEs:
Shirish
1987 Carrera, Granite Green
Old 08-29-2018, 02:06 PM
Irrationally exuberant
ChrisBennet's Avatar
I don’t see a distributor. What sort of EFI setup are you running? (If it’s not a secret I mean.)
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-23-2018, 07:53 PM
sp_cs's Avatar
Motec m84, Audi COP
Shirish
Old 09-24-2018, 12:22 AM
clutch-monkey's Avatar
what's the advantage of running a system like this instead of trumpets?
Old 09-24-2018, 04:05 AM
sp_cs's Avatar
Torque is meant to be the primary benefit - i’ve read that the plenum provides a ready (pre-collected) dollop of air to expedite/improve combustion and sharpen throttle response.
William Knight mentioned to me that a common plenum will always provide more area under the torque curve than straight stacks.
Shirish
Old 09-24-2018, 06:10 AM
interesting. i have CNC'd mounts for the plenum but my tuner prefers the trumpets (perhaps for setup). i may look at doing back to back dyno tests down the line.
Old 09-24-2018, 02:57 PM
sp_cs's Avatar
The atPowers leave you with stubs so relatively easy to mount the plenum with use of silicone connectors.
Shirish
Old 09-25-2018, 12:38 AM
