Steve F's Avatar
Awesome Henry!! What is the green material on the cylinder base as the piston is being inserted please?
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 10-25-2019, 04:37 AM
Originally Posted by Steve F View Post
Awesome Henery!! What is the green material on the cylinder base as the piston is being inserted please?
Curil T sealant
No physical quantity completely explains its own existence
Old 10-25-2019, 06:23 AM
Steve F's Avatar
Thank you.....Henry, sorry I spelled your name wrong....fat fingered it
Old 10-25-2019, 06:46 AM
That is the cleanest straightest line of Curil T I’ve ever seen. I get it all over the place. Henry is a Curil T artist. Props
Tony
Old 10-25-2019, 06:53 PM
camgrinder's Avatar
Originally Posted by Henry Schmidt View Post
The DC62 is not on Dougherty Racing Cams Porsche 911, 930 and 964 camshaft profiles website but I have experience with the cam so he still makes it on request.
John does great work and I tend to stick with what works/has worked.
Thanks Henry
John Dougherty
Old 10-26-2019, 02:59 PM
Gorgeous!
Old 10-26-2019, 06:35 PM
Very nice. Did I miss the fine print (asking price)?
Of course, if I have to ask ............
Sherwood
Old 10-28-2019, 06:15 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Sherwood
More than you want to spend but less than you think.
Singer (Ed Pink) stratosphere numbers.....no
Shade-tree numbers.....no again.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-29-2019, 03:51 PM
Henry do you have your cases vapor cleaned? It still appears that some controversy remains ,as to whether its "safe"
Old 10-30-2019, 11:15 AM
Spent the afternoon at Henry's shop and this engine looks even better in person. It's a work of art!
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 10-30-2019, 06:53 PM
onboost's Avatar
Jee-zus!
Always a tasty build from Supertec!
Thx for sharing!!
RGruppe #180
Old 10-31-2019, 07:51 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
thanks for posting! Awesome build, I bet it pulls like a beast!
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 10-31-2019, 12:10 PM
Not high butterflies, but here's my beautiful set of rebuilt throttle bodies for the 70E sporto I'm putting back together. Henry and his crew do some nice work.
Old 11-01-2019, 06:56 AM
Constitutional Liberal
Turbo_pro's Avatar
There's a lot going on with this pump. Can you tell us about it?
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 11-02-2019, 12:53 PM
Call 911
dkirk's Avatar
Stunningly beautiful work Henry! Thanks for your detailed post.
Dave Kirk
My Porsche restoreth my soul.
Old 11-03-2019, 10:26 AM
The pump mods are items we've developed over the years to enhance reliability and function, not to mention a touch of WOW. The trick bits are ours but the magic tuning was performed by Mark Jung @ MFI Werks.
First the RSR replica cover was designed and manufactured by Aaron Burnham exclusively for Supertec. As you can see, it's work of art. It varies from the original RSR cover in that it has a boss to mount our enrichment device. The original thermostat can also be mounted.
This is a cable operated enrichment device that allows the drive to control the mixture for start up. This is the 3rd generation and we believe the improvements move it to the next level. If you own a 1st or 2nd generation device, we would be happy to up-grade yours for no charge. Simply send it back
Years ago we decided that hot engine oil in the pump made sense only if you ran a cold start thermostat. So with a enrichment device, sealing the pump was a no brainer.
As the pump heats up, pressure builds inside so if you seal the pump you have to run a breather. We made this breather a bolt on item the make it user friendly.
The fuel fitting were originally designed to accommodate the tight space engine compartment on a 917 replica. We were so happy with the results we decided to add it to our list of products.
Making custom fuels to match the fitting was the logical next step.
Henry Schmidt
Ph: 760-728-3062
Old 11-05-2019, 05:42 AM
47silver's Avatar
fantastic!
1975 911S Targa
Silver Anniversary Edition
Old 11-05-2019, 09:42 AM
Jeff Alton's Avatar
Nice looking bits there Henry!
www.turn3autosport.com
Old 11-07-2019, 08:32 PM
Send a message via Skype™ to starchy 911sc
Henry, tell us a bit more about the ITG vs the K&N filters used in your earlier high performance builds please.
Do the ITG’s have superior air flow? Does it just come down to aesthetics?
I note the ITG’s come with base plates that allow custom mounting/machining to mag, plastic or individual stacks to match the intakes. This seems to be more flexible than the K&N option which is predrilled for carbs.
Regards,
Andrew
Old 11-16-2019, 01:48 PM
Regards,
Andrew
The choice has a little bit to do with a multitude of variables.
First, dyno sheets show an increase in performance with air filters installed vs. no air filter. We did not do a comparative dyno run with K&N.
Aesthetics is always a consideration. ITGs offer high quality filtration with a "period correct" feel.
Perhaps the largest factor is the universal appeal of the ITG. They allow us to custom fit them to a plethora of custom intakes.
We're really happy with the way they fit on our custom high butterfly stacks.
With ITG air filters
Without air filters
Henry Schmidt
Ph: 760-728-3062
Old 11-17-2019, 06:48 AM
