Jeff Alton's Avatar
3.4 Dyno Chart
Just wanted to share the lasted dyno chart after final tuning. The motor is a 3.4. The great torque curve is courtesy of cams from John at DRCamshafts. We have used these exact cams in a couple of other 3.4 builds and love the power/torque curves.
Cheers
www.turn3autosport.com
Old 10-23-2019, 09:15 PM
Jeff,
I got a similar shaped curve with John's 993SS cams in my 3.4 build. Only difference to your build is that I used the standard 3.2 intake manifold and consequently lower peaks of course.
Similarly I used Motec/twin plug/CoP/twin O2 sensors/twin knock sensors/AFM delete tube/1 5/8" BBE's/Dansk Motorsport muffler/Mahle 10.3:1 98mm. It's great to drive in the Twisties.
What is the spec of the cam you used?
Old 10-24-2019, 12:01 AM
sp_cs's Avatar
Really impressive - I achieved similar figures on my 3.45. Similar setup except for using 1.65” OD headers
Old 10-24-2019, 08:24 AM
Chain fence eating turbo
Since it is showing uncorrected, what temps were this engine ran in?
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 10-24-2019, 09:11 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Very nice....
I have a stump or two on the property. I was going to use the Tundra but ?????
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-24-2019, 10:46 AM
I would rather be driving
jpnovak's Avatar
Very nice shape to those power curves. Love the flat torque curve. Looks like there are some more rpms in that beast.
Old 10-24-2019, 12:31 PM
Jeff Alton's Avatar
Originally Posted by Peter M View Post
Jeff,
Very nice Peter, this motor has a DC44 108.
We have another 3.2SS on the dyno right now, then sending out latest 3.8 over there as well.
Old 10-24-2019, 08:41 PM
Jeff Alton's Avatar
Jamie,
We ran out of injector... It could spin 7200 reliably I feel, but we limited it to 7000. With a larger injector we would seen north of 300 at the wheels.
cheers
Old 10-24-2019, 08:42 PM
Jeff Alton's Avatar
Very Nice!
Jeff Alton's Avatar
Originally Posted by Henry Schmidt View Post
Very nice....
Thank you Henry. We do have a tow hook on the rear....
Old 10-24-2019, 08:43 PM
Jeff Alton's Avatar
Dyno room temps approx 78 degrees.
Old 10-24-2019, 08:44 PM
That is awesome. Great build!
No physical quantity completely explains its own existence
Old 10-25-2019, 06:24 AM
Under the radar
Trackrash's Avatar
That's a V-8 torque curve. Very nice. How does it drive?
Gordon
'71 911 Coupe 3,0L outlawed
Old 10-25-2019, 12:40 PM
Jeff Alton's Avatar
Thanks!
Old 10-25-2019, 06:25 PM
Jeff Alton's Avatar
Yes very flat, almost like a new gen small turbo car, except it keeps pulling. It drives a amazing, never really in the wrong gear. You can run it out to 7K or short shift it, always some torque there. It also helps that it is in a car weighing around 2300lbs
We have built this combo a few times and just love the torque.
We have a 3.2SS ITB motor on the dyno getting final tuning right now, then the 3.8 ITB one will be on the dyno hopefully late next week. Just putting some break in miles on it before final tuning.
Cheers
Old 10-25-2019, 06:28 PM
camgrinder's Avatar
Great job on this build Jeff!
John Dougherty
Dougherty Racing Cams
Old 10-26-2019, 03:01 PM
Love it, such a good promise for my 3.4 build...almost the same spec except for PMO's, Eisenmann exchangers and DC35 cams....
If I can get that torque curve even with 10% less HP and torque I will be delighted.....
Dennis
Old 10-27-2019, 07:47 AM
which injectors were you using?
1980 911SC Targa 3.6L
Old 10-28-2019, 06:20 AM
Any reason to go with 98mm pistons over 100mm? I am having an engine built and thinking 3.5? Also struggling with ITB selection, as there are a number of choices. I want something easy to maintain over all else.
I have a 915 box (engine will be in a 71T) ... stock gear ratios seem fine; any sense in re-gearing it closer / shorter? With this torque it would seem not.
Old 10-28-2019, 10:38 AM
Jeff Alton's Avatar
These were 30Lb Bosch, we should have used a 36lb.
Old 10-28-2019, 11:10 PM
