Anyone with real world experience using these?
Ass-engine Nazi slot car -- PJ O'Rourke |
I’ll stay tuned. Thanks!
I used them for my 3.8 MFI build and made 410 hp at 11 to 1 compression on 93 octane.
MST0118 - the piston pic at the beginning of this tread has inverted dome (channel between intake and exh valve), however pic in your engine post did not… Most likely because cr only 11:1 on 102’s which must not need volume on either side of channel to get cr?
Yes.. his pistons look more conventional to me.. not at all like Fred's design.. But I am still learning as we go...
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Yes, my pistons probably had to have more conventional shape because had reduced compression height due to using longer rods and Xtreme heads have less chamber volume. The weight of Fred’s 98mm piston is 430 grams where my 102mm piston was 422. So, maybe these factors caused the shape to be less of a dish? There’s probably less of an advantage with dish design when piston has less dome like mine.
I have a set of 98mm going into a 3.2 to make a 3.4 , comp is 10-1piston.
Measured at 9.78 deck clearance at .040", knight 75 cams , "MaxxEcu Street" Brain Carrillo rods, should be on the dyno at the end of the month. I forgot, PMO ITB's Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains Last edited by icarp; 08-13-2024 at 05:17 PM.. |
Looking forward to seeing the results. Have the same set of pistons on our shelf....
Will go a different route ECU/CAM wise, and run on ITB's.... Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Ian... also looking fwd to how this all shakes out...
You got this Ian & you have put in the time & have the experience & resources to achieve a great build...!! Carry on...!!
I live for 911 tweaks... |
I say 183.2 RWHP
I'm not picking my nose..I'm porting my upper intake manifold. |
I talked to Ian this morning.. I'll up my guess to 350 HP
It is running very well, very crisp, and snappy . A little drive up and back put a huge smile on the drivers face . 315/35/17 tires on the rear . The dyno run is set for next Monday at 8 am eastern time .
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
Congrats… Sounds awesome…. But, we need some pics… a picture says a thousand words…
A dyno chart says 2 thousand words..
A video says it all....
Ok, the short story is , 308 hp at the crank @ 6350 rpm on the Dynojet 248 scale
I will post Dyno graphs and info shortly , the TQ is the amazing set of numbers . All on 1.5" standard SSI heat exchangers, too small for this displacement of 3.4 ltrs More to come Ian
Ian… Fred is looking down on you from above with a great big smile & applauding…!
1.48 HP/CI, that is pretty good..
Well done Ian!
I look forward to seeing the dyno graphs.
Bert Jayasekera 1970 911T - Tangerine Orange Early 911S Registry #494 R Gruppe #167 |
Thread Tools | |
Rate This Thread | |
