PCA Member since 1988
Originally Posted by Henry Schmidt View Post
Hi Fred
I like your "new" design. Very impressive.
One thing we questioned with CP and JE pistons is the sharp transision between valve pockets. We discovered that by simply rounding those "sharp" edges that horse power gains were substantial and compression loss is minimal. A measured 5 HP in 200. Theoretically, it promotes better exhaust gas expulsion. I'm sure you considered this mild modification but I thought I would mention it for people who didn't.
Cheers
Henry, I'm somewhat a newbie to the Pelican forums, and just finding this thread. I recently built a RoW 1980 SC engine using the 74.4 crank and rods from a Turbo to get a 3.2. I worked with both William Knight and Dick Elverud to spec it and do machine work. I assembled it. One of the things I like to use in engines is thermal barrier coatings (TBC). William advised against TBC on the piston or combustion chamber. However, I did put it in the exhaust port to reduce heat transfer to the heads.
It looks like the pistons you posted have a TBC on them. Is that TBC or just a different surface finish?
Thanks for sharing your extensive knowledge.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 01-14-2023, 12:56 AM
�� friendly bump
Old 02-13-2023, 11:37 AM
Still interested, please reach out when you're free.
Sent from my Pixel 7 using Tapatalk
Old 04-28-2023, 07:29 AM
Bumping for me to respond, or Henry? I'm hoping Henry will reply.
Old 04-28-2023, 11:53 AM
Try not, Do or Do not
Henry Schmidt's Avatar
I'm not sure I understand the logic in ignoring thermal barrier in high heat applications.
POWERKOTE™ CBC-1 CERAMIC THERMAL BARRIER COATING
Thermal barrier/heat management
Reduces part temperature. Protective to above 2000°F.
Keeps heat in the combustion chamber longer through the power stroke.
Blurs hot spots. Reduces the potential for detonation.
Highly resistant to thermal shock. Survives cyclic heating and cooling.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-28-2023, 01:58 PM
Henry, do the manufacturers of these coatings ever provide a thermal conductivity value at the recommended application thickness?
I googled the one posted, found only application instructions.
How do you evaluate expected effectiveness without that kind of basic data?
Old 04-28-2023, 02:58 PM
Responded to all pms
Cheers
James
Old 05-31-2023, 05:45 PM
Shipped a few sets have a few guys waiting for spec sheets.
Old 10-21-2023, 02:17 AM
3.0 set shipping Thursday
In stock we Have
1 3.0 set left
4 3.2 sets
4 3.4 sets
1 3.6
Old 11-29-2023, 07:58 AM
I will take a set of the 3.0 if you still have them. Pm me please.
Old 11-29-2023, 06:00 PM
prschmn's Avatar
Henrys post
I wonder too about thermal coatings but am thinking that putting them on the piston crown implies that you would need to adjust cold clearances-perhaps risking them being too tight cold and risking skirt damage,
In other locations though there is certainly merit.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 11-30-2023, 08:21 AM
Can I ask how much a set of 3.0’s? I’m building a stock with a 964 cams. Evaluating my budget.
Old 12-02-2023, 06:45 PM
Current pricing is 2300$ shipped.
Just sent a set to California this week about 4 days coast to coast currently.
Thanks guys.
All pms responded too
Old 12-03-2023, 03:40 PM
How do these pistons work with a CIS?
Old 02-23-2024, 05:53 PM
I guess we all get to choose who we listen to.
From Mahle Motorsports.
Ceramic coatings on piston crowns are proven technology, and MAHLE is now offering their proprietary ceramic thermal barrier coating on any of its PowerPak lineup of performance forged pistons, in both the gas and diesel engine lineup. MAHLE’s Ceramic-based coating acts as a physical heat barrier on the crown of the piston.
An article from Engine Builder Magazine.
JE’s Nick DiBlasi,
Fortunately, unlike some custom piston upgrades or options, ceramic crown coat is appropriate for all kinds of applications. “One of the great benefits of ceramic coating is that it is so universal,” DiBlasi explains. “We have huge success using this in all types of applications. We apply it on pistons for forced induction, nitrous oxide and naturally aspirated applications regularly, and have tested it on all fuel types. In order to ensure compatibility with whatever customers might throw at it, we have done extensive work creating ‘worst case’ scenarios in an attempt to make the crown coating formula fail so it won’t cause a problem for the end user. We go through a rigorous testing process to ensure we are getting maximum adhesion and benefits.”
Because ceramic crown coating is thinner than a human hair, it can be applied to any piston without requiring any changes to the crown or combustion chamber design.
Overall ceramic crown coating is good insurance for the racer pushing the edge, especially in the forced induction and nitrous realms. In naturally aspirated environments, the additional heat reflected into the chamber can even improve exhaust scavenging that returns real world horsepower!
Henry Schmidt
Ph: 760-728-3062
Old 02-25-2024, 03:01 PM
Has anyone who has purchased these pistons, built an engine and run it yet? If so, what was your engine spec and how did it perform?
There must be at least a dozen sets out in the wild by now?
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 02-26-2024, 02:24 AM
Henry, thanks for that update. Next time that's what I'll do. If there is a next time...
Old 02-26-2024, 02:47 PM
Jeff Alton's Avatar
Mike, as you may know, we have a set of 98mm one for 74.4 stroke 3.4. Looking forward to the engine we do finally build with them.
Cheers
www.turn3autosport.com
Old 02-26-2024, 09:56 PM
Cheers
Hi Jeff, yes, really looking forward to hearing from someone like yourself with experience and able to say "yes" or "no" to this design.
Always learning.
Old 02-27-2024, 03:13 AM
We are also waiting for the first engine to get finished with a set of my dad’s pistons.
Currently we have 4-3.2 sets left in stock 4 3.4l sets in stock and one for a ss 3.0.
If anyone needs specs please reach out
Old 03-27-2024, 10:21 AM
