Tom,
I purchase mine from a reseller of www.fvd.de, the cost was a little more than what you said 2750€ HT. Think fvd is selling in US, UK , Japan,.... phe |
Super Moderator
Phe,
What I was saying is that I couldn't see any assembly lube used on the bearing surfaces in your pictures posted here.
Chris you killed me last night, I had really really bad sleep.
There was assembly lube. I do not send every picture I have. Thanks a lot. I feel better now. Philippe |
Super Moderator
Sorry buddy, I'm just the paranoid type when it comes to motors. Sorry to heap more worries onto your existing pile!
some practicing for the seats:
I will drop the rear seats and the plastic box around the gear stick. Good no? phe |
Irrationally exuberant
While you have the seats out you should put in the eye bolts for your sub strap belts.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
I do not have them yet, we have done a swith for larger belts.
I will receive that in a few days. phe |
Here comes the week-end pictures :
phe |
how to do the block?
I didn't imagine that it was so difficult to put the springs in place. I am the lucky boy, the one with the camera !! I have also a small dirty video of someone masturbating a valve but due to morale (and technical) reason I cannot post it. sorry
Last serie for today :
Hi Phe,
Well this engine will be soon in the car ! I have few remarks : Do you use original valves ? It would have been a good idea to machin them, reducing the angle radius : this helps tork at middle ranges. The ports should also have been cleaned. Did you also check the springs' strength ? One more important thing : don't forget to check the chamber volume and piston clearence for each cylinder ! I think it's non-sens to lose some time lighting and equilibrating rods if this basic work haven't been done. Regards, Luc
Porsche 961 Le Mans'86 |
Luc(snoopy),
valves: 50%new 50% old but checked (for machining too late).Must stay a road car (about 60.000km/year!) springs: all new. ports: agree, it looks dirty (I will drop a call) clearance: schedulled. phe Last edited by phe; 06-30-2003 at 09:27 AM.. |
re Phe !
>Must stay a road car (about 60.000km/year!) This is always my goal to keep an engine reliable. Machining valve just helps flow at low valve lift and never affect reliablity. >springs: all new. Good. Bought all together ? >ports: agree, it looks dirty This is not important. Never polish the ports, it's lost time. But the moulding lines should be removed. It should have been done if the valves, seats and guides were done. So keep them like this, 3.4 engines work enough don't they ?And let's consider you will have a good air/fuel mixture thanks to it ![]() ps. Snoopy is already used by another one on this forum ![]() Luc.
Finished (I am getting closer.....)
Good work for the day !!! I know you dont like to do that so (Merci pour l'effort) phe |
![]() Now you *just* have to check for the volume of each combustion chamber. Also don't forget to compare piston heights. A good trick : if you need to remove material to set the biggest volume you measure to all chambers, remove it around the spark plug. This helps combustion and reduce detonation risk. Have fun ![]() Luc.
Nice pictures! I just love to watch rebuild in progress.
I have one idea: if you are going to assemble the heads with plugs already mounted, why not use the oportunity when you can see the plugs "from inside" and index them, to get every last horsepower drop?
Thank you for your time, |
-Chris
Indexing the plug doesn't matter if you don't have a per-cylinder compensation (that means advanced sequantial EFI with one temp sensor per head). It's really more important to calibrate injectors (or fuel distributor) and be sure to get the same compression ratio for each cylinder.
Luc
look nice !
