More and mor difficult to wait... phe |
Super Moderator
Nice! Boy those PMO's sure look a lot simpler than the webers!
PRO Motorsports
Just thought that I should inform you that you installed your cylinders UPSIDE DOWN!!!!!!!!
The long cooling fins go on the bottom, not the top!!!!!! Hope I told you soon enough!
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Hi Tyson,
Where did you see the cylinders ? The engine looks not to be assemblied yet ?! Luc.
Porsche 961 Le Mans'86 |
Tyson,
There are not yet installed, it was just for the pictures. But good to know!! phe |
Sorry ! I see...
![]() I didn't know this tip, I use the letters on cyl. to check the orientation. This is a good easy-to-check tip... thanks
just looked at the picture, the complete engine is upside down, so cylindres were correct
Normally, the mount of the engine will be done today and the precision setup of the cams,clearence,... will be done tomorrow. phe |
Warren Hall Student
Actually the motor is right side up in the pictures with the cylinders on page 3 and the cylinders are upside down as Tyson stated. No big deal though since it's not assembled yet. Just make sure the long fins face down when the motor is assembled.
What profile cams are you going with?
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ Last edited by Bobboloo; 07-02-2003 at 02:29 AM.. |
2.4S cams, I had to change the mount part for the cams also
phe |
Super Moderator
Good catch Tyson.
Phe, I agree with Tyson, they were upside down!
Assembly step 1
Irrationally exuberant
Your mechanic seems to have his own way of assembling things. Is this his first 911 motor?
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Oil return tubes? I can't see them but maybe it's the angle.
-Chris EDIT: From the last picture, it looks like you caught it. (Cam tower looks like it was removed...) BTDT
phe |
Now this is the right time for the check of the cylinders mount
![]() phe |
Chris,
You are really good you replied before I ask question !!! respect
