Try not, Do or Do not
Henry Schmidt's Avatar
Originally Posted by Richey View Post
As I said , what a person likes , not necessarily the fastest , I like the original 2.2S personality , but interesting story about the 2.5 liter engines . I think Porsche also experimented with 2.5's in the ST and used the short stroke version , but a different time and a different track .
The story is not about performance/horse power. It is about the mindset that created an inaccurate assessment of performance.
Actually. Porsche experimented with short and long stroke 2.5 liter engines and the results were as follows.
70-71 2.5l short stroke 87.5 x 66 250hp @ 7800 188 f/lb@ 6200
70-71 2.5l long stroke 86.7 X 70.4 270 hp @ 8000 191.6 f/lb @ 6200
Of course in the development of the long stroke engine they discovered the inherent problem with the 70.4 crank at high RPM. The crank would develop a high RPM harmonic that would spit the flywheel off. The cure for that issue was a redesigned crank used in the later 2.8 and 3.0 RSR engines.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-04-2025, 08:23 AM
According to the above specifications , the short stroke was a 2.38 liter engine and the long stroke was 2.49 liters , so not really
a simular comparison .
Old 03-04-2025, 06:56 PM
Rosco_NZ
Send a message via Skype™ to Rosco_NZ
Carrera 3.0 engine rebuild
No, there were long and short stroke 2.5’s. 2.3’s all SS.
Old 03-05-2025, 08:43 AM
Jesse911's Avatar
Thanks guys for all the replies.
I went for the Cat Cams as this camgrinder is very local to me and I read on this forum of someone from Denmark who had the same cam in his 2.7 with ITBS and he had 270hp at the crank. If I can get to similar number i would be very happy!
I'm also using the valve springs from CAT Cams which are made by PAC springs in the USA.
Just ordered a lot of tools from Stomski Racing and my case, crank and heads are at the machine shop to have them checked and rebuild, balance the crankshaft with pulley and flywheel.
Jesse
'76 911 backdate with Carrera 3.0 engine
Old 03-06-2025, 01:38 AM
Jesse911's Avatar
Lovely tools by Stomski have arrived today. Not bad one week after ordering in the USA to Europe.
Jesse
Old 03-13-2025, 02:45 PM
yep, I use them and love them.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 03-13-2025, 07:44 PM
Rosco_NZ
The piston pin C clip tool from Stomski is a very good thing!!
Old 03-18-2025, 10:12 AM
Jesse911's Avatar
My reground cams for Cat Cams arrived together with their springs. Now waiting for the machine shop.
Jesse
Old 03-25-2025, 08:16 AM
Jesse911's Avatar
Some more parts.
Supertec head stud kit
ECUMaster Black ecu and sensors
Jesse
Old 05-04-2025, 04:38 AM
Nice pieces & parts. Thx for keeping this thread going. This will be fun to watch. Best of luck. Patrick
912E-3.oh
Old 05-04-2025, 06:29 AM
You will love the Stomski bits and they will take the likelihood of an error on your part down to near-zero. Excellent investment!
Ken
1986 930 2016 R1200RS
Old 05-04-2025, 12:14 PM
I use this dynamic compression ratio calculator, I hope it’s of use to you,
https://uempistons.com/p-27-compression-ratio-calculator
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 05-29-2025, 01:47 PM
Administrator
What ITB's are you using?
Old 05-31-2025, 06:10 PM
Originally Posted by Jesse911 View Post
Some more parts.
Glad to see another Emu Black ecu join the group. Amazing value.
Always learning.
Old 06-01-2025, 02:29 AM
Jesse911's Avatar
Thanks!
Still deciding between Jenvey ITB or a local dutch company KMS.
https://kms.vankronenburg.nl/products/throttle-body-kits/porsche/throttle-body-kit-porsche-911-optional-airhorns-45mm
Thanks Mike. The value of the EMU black does seem to be excellent!
Jesse
Old 06-02-2025, 11:26 PM
Jesse911's Avatar
In the meantime I have received my DP motorsport amber fanshroud. Also had some parts Cerakoted.
My 3.1 supertec piston/cylinderset will arrive this week
Jesse
Old 06-07-2025, 03:49 AM
Jesse911's Avatar
And the 3.1 pistons and cylinders received. Now waiting for the engine shop to have my heads, crank, case ready.
Jesse
Old 06-12-2025, 12:16 AM
Jesse911's Avatar
So picked up all the parts from the machinist. Crank was balanced and checked, heads rebuild, case cleaned and inspected, rods checked and new ARP bolts, all new bearings.
I also balanced the the connecting rods to within 0.1 gram. Had a friend 3d print a jig to balance the rods. Worked great!
I'm now looking into all the sprockets for the timing chains. Does anyone know if the Sebro sprockets are any good? Or am I better of using the old sprockets with new chains?
Jesse
Old 07-31-2025, 05:02 PM
Looking good. Which version crank pulley and trigger wheel is that?
When it comes to sprockets, I tend to re use them if they are not showing obvious signs of wear. You can go crazy and repace EVERYTHING but if the chains were aligned previously and nothing solid went through the engine, then they should be good to reuse.
If I come across one which shows signs of wear from the chains rubbing or if it suffered a tensioner failure, then they are all likely being replaced.
Always learning.
Old 07-31-2025, 05:07 PM
Jesse911's Avatar
Crank pulley is from Adapt Motorsport.
Thanks Mike I will have a good look at my sprockets than. Unfortunately I misplaced my chains so I don't know which one was left and which one right side. If the sprockets look to be in good condition some new chains would be ok?
Jesse
Old 07-31-2025, 06:01 PM
