2.5 litre short stroke questions
I'm planning on building a short-stroke twin-plug 2.5 litre engine & have some initial questions. The engine will use high compression (10.3 or higher) pistons, S cams & the twin plug ignition will be supplied by an Andial-converted Bosch twin plug distributor.
Intended use is mainly road + occasional sprints/hillclimbs.
1) What port sizes should I go for - std S or larger ?
2) Should I base the engine on a pair of 7R crankcases or opt for the earlier aluminium crankcases & get all the updates (oil squirters, etc) carried out ?
3) What induction system should I opt for - Webers or mfi ? (I have a complete 2.4S as new mfi set-up, as new Weber 46 IDA's, 2.2E mfi with magnesium stacks ready to be bored out & a set of 40 IDA's)
4) What are the preferred conrods - 2.0 ? 2.2 ?
Andy
M&W 904 ... now gone
GT-style 356C ... also gone
Old 08-29-2004, 03:03 AM
Halm's Avatar
Sounds like a fun motor. FWIW, I was over on the EBS Racing site yesterday and they have a package deal for essentially 2.7 RS p&c clones for $1,650 in case you will need them.
Any idea the HP difference if you went with 9.5 CR pistons and stayed with a single plug system versus your 10.3 and dual plug?
'17 Cayenne
Old 08-29-2004, 07:33 AM
BURN-BROS's Avatar
What is your budget? I personally would opt for the early case and the e stacks bored out to "?". I think 2.5 rsr spec is 38 or 39 mm on the intakes I forget(alot). Street driving may dictate that you keep the ports close to stock. 2.2 rods apparently have more meat to them so i would go with them.
You should think about the Andial conversion. The replacement parts will water your eyes. The Marelli cap and rotor fit more applications, so those parts will be available longer and for less prices. This is not a shameless plug for what I am doing, just what I have learned.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 08-29-2004, 07:34 AM
Licensed User
Shuie's Avatar
Aaron, do you have the caps and rotors available yet? Im not trying to hijack anything, but whats involved in converting over to the distributor you are talking about? Is there a thread or a website with the details anywhere?
TIA
Old 08-29-2004, 10:34 AM
BURN-BROS's Avatar
I am machining revised molds as we speak. P.M. me from time to time if you have questions. Should be ready to sell in the fall(earlier if I work fast!)
Burnham Performance
Old 08-29-2004, 10:46 AM
Aaron,
Excuse my ignorance, the Andial conversion uses a Bosch cap? And that is not interchangeable with the Marelli?
Are the rotors the same?
Tinker
Old 08-29-2004, 11:40 AM
BURN-BROS's Avatar
Tinker, unless there is another conversion they are doing, they are using the Bosch twin plug cap and rotor found on 3.0 rsr and 935s. The rotor is being replicated and I belive they are working on the cap. $1000.00 apprx. for both. They are not interchangable. The Marelli was on Ferrari, maserati, etc since 1959. Way more demand out there. O.k. no more highjacking of threads. P.M. if you have questions or Post a new topic por favor.
Burnham Performance
Old 08-29-2004, 11:50 AM
Grady Clay's Avatar
andyjboy,
I have posted several times on this issue.
I think the best lightweight engine is a 2.8S (92x70.4) on a 7R case, twin plugs (electronic), and MFI. Keep standard S heads, throttle bodies, stacks, etc. Use a stock OEM muffler for the street.
I would recommend you do some searching on this Forum.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 08-29-2004, 11:59 AM
Anyone else got any advice/suggestions ?
Andy
Old 08-30-2004, 10:01 AM
126coupe's Avatar
My 2.5 short stroke is 10.3:1 single plug no detonation
I run the pmo's 46MM they work great
S Cams
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 08-30-2004, 10:35 AM
126coupe's Avatar
here are some photos [
28' Pace Trailer
Old 08-30-2004, 10:39 AM
911SCfanatic's Avatar
Nice looking car, Minkoff!
Bill G.
'68 911 Ossi Blue coupe
Old 08-30-2004, 11:00 AM
What port sizes do you have ?
Is your engine based on an aluminium or mag case ?
Andy
Old 08-30-2004, 11:03 AM
126coupe's Avatar
its an alum case, I need to check my notes on port sizes.
remember this engine would not be too good on the street
28' Pace Trailer
Old 08-30-2004, 11:46 AM
126coupe's Avatar
39mm intake and 40mm exaust
28' Pace Trailer
Old 08-30-2004, 12:15 PM
How is the 2.5L built?
Based on what I have read, the 2.5L 911 was built with a bore and stroke of 89mm X 66mm. I anly assume that a 2.2L crankshaft and rods used with larger pistons and cylinders. What case is used in this build? Are the case spingets 92 or 97 mm. Can a 2.7 be converter to a short stroke 2.5?
Thx!
Old 08-31-2004, 11:59 AM
James - the 2.5 litre short-stroke engine uses 90mm (2.7) barrels/pistons & a 66mm (2.0/2.2) stroke crankshaft to give a capacity of 2519cc.
Essentially there are 2 ways to achieve this:
1) start witha 2.7 engine (ideally with the 7R crankcases) & swap the crank for the 66mm version
2) start with an aluminium crankcase (from a 2.0 911 swb), get all the necessary machine work done (case squirters, bore spigots, etc) & add the 90mm barrels/pistons
This poses one of my original questions - which crankcase to use as the basis ?
The aluminium cases are heavier (but stronger) are now expensive (& becoming difficult to find) & will require quite a bit of machining whereas the 7R mag cases are lighter, cheaper/easier to find & have most of the required features already incorporated as std.
Andy
Old 08-31-2004, 12:23 PM
Halm's Avatar
Andy, I don't remember the exact issue, but unless you do additional machining, the standard 2.7 RS p&c's will yield a very low compression ratio. I believe a work around is to use (for example) JE pistons designed for higher CR.
'17 Cayenne
Old 08-31-2004, 12:27 PM
Hal, I'm planning to use high compression JE pistons - my description above was just a simplification for James.
Andy
Old 08-31-2004, 12:41 PM
BURN-BROS's Avatar
Andy, the 7r will be lighter than any aluminum case. the aluminum will be heavier and stronger. I think the 7R case from the 2.7 already have piston squirters(nit sure about the 2.4 7R). The early case would need this mod done as well as the layshaft bearing mod(I think). The 7R may need shuffle pins for high rpm stability.
Either case is fine, both have their merits.
Burnham Performance
Old 08-31-2004, 12:42 PM
