I really think I agree, Andy. I think Henry said he found the 17-4PH studs in a high powered turbo race engine (perhaps 962), I wonder whether the thermal expansion on that material is similar to or different from the 200ksi alloy steels, but I'm too lazy to look it up right now.
Andy |
I had Henry put supertec studs in my engine aout a year ago. They have served me well so far...Why did I choose the Supertec studs? First the lifetime warranty. You cannot have any more confidence in your product than that. Second, I have observed that broken and pulled headstuds seem to be a prevailing problem based on posts here...broken with dilvar...pulled with others (That was the problem with my old 2.7). Henry's studs have a history of doing neither...even under extreme conditions. They did not cost that much more either. It seems to me that people on PP BBS overkill on so many parts..suspension, brakes, cupholders, etc, then try to save a buck on the most important part...their engine. I figure that it is one of those "while you're in there" things. I don't intend to be "in there" for at least 100k after a Supertec rebuild...so amortizing the difference over that many miles makes the better quality a cheap investment. And like most of you guys...I run my engine pretty hard. For my engine...overkill is good.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Try not, Do or Do not
Porsche redesigned their heads studs at least 5 times in an attempt to improve stud performance. Porsche is a great design company but designers sometimes have cost constraints that impair their designs. When we designed our stud,we designed it with performance in mind, not cost. We looked at how other engine designers remedy these problems. All performance engines that I have worked with that had a steel head stud in an aluminum case or block used a coarse thread in the case and a fine thread at the nut end. (see Continental aircraft engines, high performance motorcycle engines, Ford, Chevy, Rolls Royce, BMW and the list goes on). And what's with the allen head nut ? A 12 point flange nut is the best hardware for this application. Performance you say? What can a head stud do? Simply put, a head stud holds the heads in place. When you build a large number of engines that come apart with very low mileage ( race engines) you can see problems that quality engine builders want to remedy. Head movement is the problem and our studs reduce that problem to an exceptable level. Whether you make 200 hp or 800 hp our head studs hold the heads in place. This is not our experience with stock steel studs. It might be ridiculous to assume that if it hasn't broken, it must work just fine. As for thermal expansion, all the head studs ( Fcatory Porsche, ARP, Raceware and SUPERTEC) are made of differing materials so they all expand differently. The key might be to look at why Porsche chose Dilavar. It is my understanding that Dilavar was chosen in an attempt to stop the heads from leaking (seeping) during and after cool down. Leaking oil not compression. This was the reason for the missing fins on the 3.3 (78-89) Turbo cylinders. We prefer to build an engine that functions well during running and we'll let cool down take care of itself. The 993 stud is steel so apparently Porsche have taken the same direction. Raceware, stock steel, updated Dilavar (all thread), old Dilavar, Factory 935, Supertec, 993 steel
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 11-17-2004 at 08:18 AM.. |
Irrationally exuberant
The 2nd one from the left looks like the Raceware I've used.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
The second stud is a stock steel stud that was cad plated.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
They all look so frail and puny in comparison to the 935 and your head stud. Also yours and the 935 stud look eerily similar, in a good way! keep up the awesome work henry.
74 911s neverending story. two feet and a jetta for now. |
im with flintstone, surely overkill is better than a 20-30% saving on cost when it comes to key engine components?
Andy
Andy 1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Henry
Do you recommend retorqing your head studs at valve adj? If so, to what value? Any special instructions?
Hi Stoney
No retorquing but if you would like to check it the torque should be 30#.
Thanks Henry!
17-4PH is an excellent stainless "spring steel" with high yield strength (180KSI +). Its coefficient of thermal expansion is close to carbon steel. I've used it very successfully in the design of loadcells and as the host material/Mechanical amplifier for silicon strain-gage based bolt-on stress/strain gage designs. The high strength and temp match to carbon steel is ideal for these applications, high stresses and cycles, and as we can see for others as well.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Banned
Performance Developments, at Costa Mesa,(I think),they sell and use those studs,(Henry's), cheers,Antonio.
Henry, being Sunday today, I have been re-reading old threads about studs
and I have just found two quotes that I find interesting. See below. So I'm wondering if your studs are manufactured in the same way? Can you confirm?Quote:
Doesn't want/need a 3.6L
Ralph |
Banned
17-4ph HCR 38-42 4hrs @ Temp 1025 http://www.latitudemanufacturing.com/174PHPrint.html The process is first to cut the round stock to length. Next we center less grind 3 times. Each end must be ground to the size specified by the tooling company for each thread roller. Then the center is ground to remove the transition (possible stress riser). Then they are heat treated to 1025* for the prescribed time (4hrs). At that point they a Rockwell tested to insure they are within specs (38-42). Then the threads are rolled, each end receiving a separate thread pitch. The threads are checked for depth and consistency. The finished product is then polished to insure a quality surface. At that point they are inspected to ISO-9003. We tried having a new company manufacture them to reduce cost and the result was a 300 piece sample run in the trash. As you can see the process is lengthy and expensive. We build them because we wanted a better stud. If no one ever buys another one I will still make them for Supertec engines.
1985 M491 Carrera Slate Blue Metallic(fun car) 2001 BMW 325i (basic tranportation) http://jmforge.com |
To get closer look at the 935 stud, peek here Name that stud...
Chris https://dergarage.com ‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8 |
