KobaltBlau's Avatar
I really think I agree, Andy. I think Henry said he found the 17-4PH studs in a high powered turbo race engine (perhaps 962), I wonder whether the thermal expansion on that material is similar to or different from the 200ksi alloy steels, but I'm too lazy to look it up right now.
Andy
Old 11-14-2004, 11:45 PM
Send a message via AIM to fintstone
I had Henry put supertec studs in my engine aout a year ago. They have served me well so far...Why did I choose the Supertec studs? First the lifetime warranty. You cannot have any more confidence in your product than that. Second, I have observed that broken and pulled headstuds seem to be a prevailing problem based on posts here...broken with dilvar...pulled with others (That was the problem with my old 2.7). Henry's studs have a history of doing neither...even under extreme conditions. They did not cost that much more either. It seems to me that people on PP BBS overkill on so many parts..suspension, brakes, cupholders, etc, then try to save a buck on the most important part...their engine. I figure that it is one of those "while you're in there" things. I don't intend to be "in there" for at least 100k after a Supertec rebuild...so amortizing the difference over that many miles makes the better quality a cheap investment. And like most of you guys...I run my engine pretty hard. For my engine...overkill is good.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 11-14-2004, 11:47 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Originally posted by Eagledriver
Just curious if anyone has ever seen a failed steel headstud? I know Porsche went to Dilavar on the street turbos for all 24 studs and suspect but don't know for sure that they used them in the 935 as well. This talk about super duper head studs is kind of rediculous. Any steel stud will pull the threads out of the case before it will break unless it corrodes. The only advantage that I can see from stud differences would be thermal expansion differences and none of the studs except Dilavar are different in that catagory.
-Andy
Yes, we see it all the time. Failure is measured in degrees as is performance. As for Delivar in 935s not in the one's I've seen. [see picture]
Porsche redesigned their heads studs at least 5 times in an attempt to improve stud performance. Porsche is a great design company but designers sometimes have cost constraints that impair their designs. When we designed our stud,we designed it with performance in mind, not cost. We looked at how other engine designers remedy these problems. All performance engines that I have worked with that had a steel head stud in an aluminum case or block used a coarse thread in the case and a fine thread at the nut end. (see Continental aircraft engines, high performance motorcycle engines, Ford, Chevy, Rolls Royce, BMW and the list goes on). And what's with the allen head nut ? A 12 point flange nut is the best hardware for this application.
Performance you say? What can a head stud do? Simply put, a head stud holds the heads in place. When you build a large number of engines that come apart with very low mileage ( race engines) you can see problems that quality engine builders want to remedy. Head movement is the problem and our studs reduce that problem to an exceptable level. Whether you make 200 hp or 800 hp our head studs hold the heads in place. This is not our experience with stock steel studs.
It might be ridiculous to assume that if it hasn't broken, it must work just fine.
As for thermal expansion, all the head studs ( Fcatory Porsche, ARP, Raceware and SUPERTEC) are made of differing materials so they all expand differently. The key might be to look at why Porsche chose Dilavar. It is my understanding that Dilavar was chosen in an attempt to stop the heads from leaking (seeping) during and after cool down. Leaking oil not compression. This was the reason for the missing fins on the 3.3 (78-89) Turbo cylinders. We prefer to build an engine that functions well during running and we'll let cool down take care of itself. The 993 stud is steel so apparently Porsche have taken the same direction.
Raceware, stock steel, updated Dilavar (all thread), old Dilavar, Factory 935, Supertec, 993 steel
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-16-2004, 08:02 AM
Irrationally exuberant
ChrisBennet's Avatar
The 2nd one from the left looks like the Raceware I've used.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 11-16-2004, 09:35 AM
The second stud is a stock steel stud that was cad plated.
Henry Schmidt
Ph: 760-728-3062
Old 11-16-2004, 09:54 AM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
They all look so frail and puny in comparison to the 935 and your head stud. Also yours and the 935 stud look eerily similar, in a good way! keep up the awesome work henry.
74 911s neverending story. two feet and a jetta for now.
Old 11-16-2004, 11:04 AM
adomakin's Avatar
im with flintstone, surely overkill is better than a 20-30% saving on cost when it comes to key engine components?
Andy
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 11-16-2004, 03:04 PM
Henry
Do you recommend retorqing your head studs at valve adj? If so, to what value? Any special instructions?
Old 11-16-2004, 10:27 PM
Hi Stoney
No retorquing but if you would like to check it the torque should be 30#.
Henry Schmidt
Ph: 760-728-3062
Old 11-17-2004, 08:30 AM
Thanks Henry!
Old 11-18-2004, 08:29 PM
al lkosmal's Avatar
17-4PH is an excellent stainless "spring steel" with high yield strength (180KSI +). Its coefficient of thermal expansion is close to carbon steel. I've used it very successfully in the design of loadcells and as the host material/Mechanical amplifier for silicon strain-gage based bolt-on stress/strain gage designs. The high strength and temp match to carbon steel is ideal for these applications, high stresses and cycles, and as we can see for others as well.
RGruppe #669
http://www.x-faktory.com/
Old 11-18-2004, 10:15 PM
Banned
Performance Developments, at Costa Mesa,(I think),they sell and use those studs,(Henry's), cheers,Antonio.
Old 11-27-2004, 05:36 PM
Henry, being Sunday today, I have been re-reading old threads about studs and I have just found two quotes that I find interesting. See below. So I'm wondering if your studs are manufactured in the same way? Can you confirm?
Originally posted by Carrera3.5L
Quoting direct from my ARP catalog,
1. Following heat treat, each (ARP) stud is centerless ground to make it as close to perfectly concentric as possible. This procedure involves about ten very slight cuts and results in an exceptionally straight part.
2. ARP studs are thread rolled after heat-treat, which gives them about 1000% (that's ten times) better fatigue strength than those studs that are threaded prior to heat-treat".
Old 07-23-2006, 07:37 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
You'd be wrong. Neil does his own.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 07-23-2006, 10:20 PM
Banned
Ralph
I know, I only use Neil's stuff, they look similar thou, cheers, Ant.
Old 07-24-2006, 06:33 AM
The specs on our studs are as follows.
17-4ph HCR 38-42 4hrs @ Temp 1025
http://www.latitudemanufacturing.com/174PHPrint.html
The process is first to cut the round stock to length. Next we center less grind 3 times. Each end must be ground to the size specified by the tooling company for each thread roller. Then the center is ground to remove the transition (possible stress riser). Then they are heat treated to 1025* for the prescribed time (4hrs). At that point they a Rockwell tested to insure they are within specs (38-42).
Then the threads are rolled, each end receiving a separate thread pitch.
The threads are checked for depth and consistency.
The finished product is then polished to insure a quality surface. At that point they are inspected to ISO-9003.
We tried having a new company manufacture them to reduce cost and the result was a 300 piece sample run in the trash.
As you can see the process is lengthy and expensive. We build them because we wanted a better stud. If no one ever buys another one I will still make them for Supertec engines.
Henry Schmidt
Ph: 760-728-3062
Old 07-24-2006, 12:33 PM
jdm61's Avatar
Ok....you got the attention of an amatuer steel geek here...lol. Do you know what thew alloying elements are and does it have similar properties to "high speed" steels as far as resistance to tempering goes? I ask because is supect that head studs might be close enough to some heat that could soften them up a bit over time if they werre made of standard springor carbon steel like 5160, 9260, 10xx series, etc. I use these to make knives and i can temper 5160 in my oven at around 350 degrees.
1985 M491 Carrera Slate Blue Metallic(fun car)
2001 BMW 325i (basic tranportation)
http://jmforge.com
Old 07-24-2006, 04:06 PM
jdm61's Avatar
38-42 Rockwell is pretty soft compared to what I am used to. I shoot for 57-58 on my edges and probably high mid to high 40's on the spine of my knives....and they can be bent to the point where they don't spring back. Sounds like your studs are being annealed and normalized down pretty soft before HT. I would guess that you really don't have to worry that much about stress risers
http://jmforge.com
Old 07-24-2006, 04:12 PM
CBRacerX's Avatar
To get closer look at the 935 stud, peek here Name that stud...
Chris
https://dergarage.com
‘07 GT3, '80 SC Weissach (For SALE), '01 986S, '11 958S, '18 Stelvio, '18 Dursoduro 900
Old 07-29-2006, 08:46 PM
