Cheers, Mike
Mike 97 993TT Arena Red - "Scarlett" |
Would like advice on the installation of the Transmission Shift Rod seal. I installed a new one last year and its leaking again after 2000 miles. Its a &*% to get out with the trans in the car. Should a sealant be used on this seal?
David |
Is it leaking between the seal and the shaft or the seal and the transmission case? Maybe you have too much slop in your shift rod and the seal can't keep up? If its between the case/seal then you have a few options including using some Curil-T or other sealer when you drive the seal in..
Cheers, Mike
You talkin' to me?
Don't use the blue thru-bolt o-rings for NUTTIN'. I used them for my 964 3.6L but apparently was not "careful" enough and shredded a few of them. Always go with green here unless you don't make mistakes or are kind of lucky - cheap insurance. Lube them with something (I used good old red grease, others have used ATF) and for GODS SAKE DON'T LET THE BOLT TURN WHEN YOU'RE TURNING THE NUT SIDE (this has a tendency to tear the o-ring and I'm deathly afraid 1 or 2 of mine are going to weep now).
Might want to take a very fine dremmel bit and unsharpen the holes where those o-rings slide into - mind the metal bits though. I would have done this if I wasn't already out of patience by that point. I did the following, mostly following Henry's method: 1104 - case perimiter, cam housing to heads 1211 - #8 nose bearing, attempted it with power steering pump around the o-ring didn't work out 574 - journal webs Curil-T - all seals and gaskets - NOTE - the round orange seals WILL work themselves out unless you put a VERY VERY thin coat on. Red Grease - anything rubber - except the #8 nose We'll soon see how it all worked out...
-Chance ------------------------------------------- '90 C2 Cab - Temporarily out of service |
Outer Case Halves: Threebond 1104
Bearing Saddle Surfaces: Loctite 574 #8 Bearing (balancer end) O-Ring: Threebond 1211 Case Thru Bolts: Dow Corning 111 on Green Viton O-Rings Flywheel Seal: Curil-T Balancer Seal: Curil-T Intermediate Shaft Cover to Case: ThreeBond 1211 Oil Breather Cover to Case: ThreeBond 1211 Cylinders to Case: Curil K-2 or ThreeBond 1211 Cam Towers to Cylinder Heads: Threebond 1104 Cam Chain Housings to Case: Threebond 1104 Cam Chain Housings to Cam Towers: Threebond 1104 Cam Chain Housing Cover to Cam Chain Housing: Threebond 1104 Gaskets: Thin coat of Loctite 574 Most Popular solutions for sealing each item above Thanks a lot folks, I really appreciate the feedback!
Chris https://dergarage.com ‘07 GT3, '80 SC Weissach (For SALE), '01 986S, '11 958S, '18 Stelvio, '18 Dursoduro 900 |
Really have enjoyed all the comments on sealant favorites, and came away with a couple of questions........sorry to drag out the thread, but then it really is a good one.
Can someone tell me more about Threebond 1104? Is it an anaerobic? On the Threebond site the ll00 series products are mostly acrylic resin based, but I couldn't actually find a 1104 listed. It isn't RTV is it? Exactly why do most of you prefer this to the Loctite 574 for the outer case flange sealant. Recently I have been exposed to considerable hype about the new sealant being used by GM on all their aluminum engine cases. The product is GM Assembly Adhesive number 1#12346141. Apparently GM developed the stuff specifically for Aluminum cases and it is all they use. I have a tube of it here on the desk and cannot imagine how we could use it on the main case, since it instructs to apply and perform final bonding within 5 minutes. But while I don't believe I could ever achieve that with an engine case, it certainly could be useful elsewhere, chain housings and etc. I is just new to me and I wonder whether any of you have experience with it. James |
I've used 1211 on the flywheel seal by mistake..#@$# instead of Curil T. Does anyone see a problem in leaving it or do I need to remove the crank and redo the whole operation.
Thanks! |
I think you will be fine, provided that the seal stays in place after initial curing. When I used curil T on my pulley seal, the seal popped out. I now install pulley and flywheel seals dry.
Michel |
Loose nut bhind the wheel
The only good use I have found for the blue case o-rings is to use on the plug wires to identify the lower set of wires on a twin plug engine. I slipped one on the plug end before I put the boot on and used moroso heat shrink cylinder id numbers and did the same at the distributor end. Blue o-ring = bottom plug. Hows that for simple. If I could just figure out a way to put the cyl # on the o-ring. I will post pics when the proper time comes and I can figure out how to get the pictures to load. $hitty camera?
Ed 1970 911S Targa 2.7RS MFI dual plug 10.5:1 1974 260Z SCCA ITS 1998 M3 |
Try not, Do or Do not
1211 on the flywheel seal will not hurt but in turn will not help.
The crank and flywheel seal should be installed dry . There is no need to glue them. Non hardening glues ( Curil T, Curil K2, Gaska Synch and Aviation Permatex) used for this application can promote squeeze out. A touch of 1211 at the case seam behind the seal is a technique that has surfaced of late but I have not added this to my method of sealing.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Anybody used 573 instead of 574?
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
resident samsquamch
Just wanted to provide an update: nearing 10,000 miles on my rebuild (see my sealing methods on page 1 of this thread) and no leaks! Knock on a large plank o' Porsche wood, that this continues! I should also add that the red silicone (re-usable) valve cover gaskets have been worth their weight in gold as I've had my covers on and off 1,000,000,000,000 times and they still seal perfectly!
The only issue I encountered were a few rocker shafts that "walked", and even with the RSR seals, leaked until I finally got them right. I attribute this to not having things dry enough (oil free) when I installed them...oil them after they're torqued.
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP ![]() |
Forced Induction Junkie
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Is this where they go?
That is a very nice graphic. The locations for glue placement are similar to the way we do it accept here is no reason to glue the flywheel seal. In over 400 rebuilds and even more tear downs I have never seen a properly installed flywheel seal leak around the perimeter.
We also glue the entire # 8 saddle with a very thin coat of TB 1211. We reserve the Curil T for base cooper gaskets.
Thanks Henry. I keep repeating your mantra, "Four Glues Equal No Leaks."
Super Moderator
I really REALLY do not recommend putting Curil-T on the nose or flywheel seal. Reason being it does not cure and therefore acts as a lubricant. Early in my engine building days I literally watched these seals slowly squeeze out of the bores while the new engine was sitting on the stand. I install them all dry now. If I really had a question about the sealing (such as a small scratch in the bore), i might put a hair-thin bit of hi-temp silicone on it. I've only had to do that once!
P.S. I just sealed up my case, and this thread was a HUGE help. Especially Johns photo diagram, great idea John!
John A. 1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.) 05 Boxster S: For the Track. 06 Dodge Ram 2500 Power Wagon: Tow Vehicle |
Well, you know what they say about a picture being worth a thousand words....thanks for the graphic John.
On the flywheel seal, I replaced mine "from the outside in" when I did my clutch a couple of years ago, which is a common "WYIT" item, I believe. Did it dry, and had no leaks. So, I see no reason why you'd need to do it on a nice clean rebuild. I can vividly see in my mind's eye how a non-curing sealant would just provide the lube needed to walk that sucker out!
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
resident samsquamch
I would imagine that the ThreeBond would accomplish the same thing...but would be used in conjunction with the gasket. So in answer to your question, apply to the gasket.
Thread Tools | |
Rate This Thread | |
