johncmng's Avatar
Angry How to remove a stripped head nut
I guess I have been one of the lucky ones to have just ONE head stud or nut problem. All went well till I stripped the Hex nut. So, how do I get the bugger off? The location of the problem is on the exhaust side cylinder #5
John
3.2 Carrera
Old 09-18-2006, 10:53 AM
dtw dtw is offline
GAFB
I think I'd go in with a Dremel and cut the stud under the cylinder. You're replacing studs anyway right?
Several BMWs
Old 09-18-2006, 11:20 AM
buy a big spiral easyout, cut the end off so the taper just begins to enter the nut, wack it in tight with a big hammer, and use a breaker bar to crack it loose. it should actually expand the top of the nut as it's hammered in, if you fit it right. typical on 3.2 engines.
206 637 4071
Old 09-18-2006, 11:51 AM
johncmng's Avatar
If I use a dremel to cut off the stud. What do I use to remove the stud from the case? I was going to use the snap-on collet type stud remover.
John
Old 09-18-2006, 12:52 PM
Navin Johnson
TimT's Avatar
You can also apply heat to the stud to relieve some of the tension in the stud.
Apply heat, and use the ez-out, you should be in good shape.
cutting the stud is a last resort, unless of course your replacing the studs anyway.
'69 911 GT-5
'75 914 GT-3
and others
Old 09-18-2006, 02:01 PM
dtw dtw is offline
GAFB
If you're not a production shop that might get more frequent use out of the tool JW mentioned, and you are indeed replacing studs, I stand by my suggestion. Torch and vice grip to remove remaining stud. BTDT - takes 5 mins.
Several BMWs
Old 09-18-2006, 02:17 PM
the easyout doesn't need heat. it will take the nut off the stud. they're cheap too. get a #6, and it does need to be shortened as described. a cut-off disc is the best way.
206 637 4071
Old 09-18-2006, 05:59 PM
Less brakes, more gas!
euro911sc's Avatar
That sounds ugly...
Good luck!
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 09-19-2006, 08:00 AM
johncmng's Avatar
Which part sounds ugly, cutting the stud or using the easyout?
Old 09-19-2006, 09:58 AM
Try not, Do or Do not
Henry Schmidt's Avatar
This is a new one on me. I have struggled with this problem in the past and without a dought this method is the best I have heard.
Even an old dog can learn new tricks, if he listens.
Thanks John
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-19-2006, 05:05 PM
euro911sc's Avatar
The ugly part I think would be cutting the stud. Usually, if I round a nut off or something like that I just use a dremel and cut it down the axis and split it open. I'm not sure that can be done here due to access issues.
-m
Michael
'13 Cayenne GTS
Old 09-20-2006, 06:41 AM
actually split the nut this time, but usually the nut just flares out at the top. never had a failure with this tool, and they get so tight that a 2 ft breaker bar is needed to snap them loose. a 1/2 impact won't do it.
206 637 4071
Old 09-20-2006, 08:29 AM
euro911sc's Avatar
Perfect Picture!
Michael
'13 Cayenne GTS
Old 09-21-2006, 06:31 AM
johncmng's Avatar
Thanks for everyone that responded to my post. This is what I use to remove the head nut. Found a cheap screw extrator from Sears for about $6 and use a Dremel to cut off 1/2 from the top so I would fit snuggly into the nut. Pounded it in with a hammer and use a two foot breaker bar to remove it. Here are the pics.
Old 09-22-2006, 11:39 AM
Newsflash: Stripped head stud barrel bolt succumbs to Pelican community experience & ingenuity. Thank you John Walker.
"V"
Old 12-21-2010, 05:01 PM
Chain fence eating turbo
It's my turn. I have 2 of them on my 3.2 (3.4) about to strip.
2 studs weren't deep enough into the case making the "drive" of the barrel nut too shallow.
My fault, I rebuilt it before! Should have fixed it.
Half-@$$ery has bitten me.
A 7/16" Allen would work that could be beaten into the 10mm drive, me thinks....
Old 01-16-2017, 09:20 PM
When ever I've run into a stripped head nut, I hammer in a XZN12 bit and try that
If that doesn't work I hammer a 12 pt socket over the outside and try again, so far I've gotten every one
I do like the easy out idea, never thought about cutting it down.
Old 01-18-2017, 10:43 PM
Slippery slope skier
Costa P's Avatar
I started with a 12mm allen key socket.
Shaped the sides down in a taper (equal amounts) to end up with a tip that measures 10mm
I drove the tapered tip into the already damaged barrel nuts (the blow also helped to loosen them).
This provided enough bite to turn them loose, combined with heat + a pneumatic impact wrench, I was able to get all the stubborn ones removed.
John's method def sounds much easier than my method (OCD and labour intensive to prepare)
'85 930 ...the oil leak rebuild which mutated into more than I could chew... then came back to my senses and climbed "back up" the slippery slope!
A stock 930 is far better than an incomplete project car!
930 rebuild – The revival of my mothballed project
Old 01-19-2017, 02:07 AM
You know what worked for me?
Using the same 10mm, cheap allen socket I had, I simply used my electric 1/2" impact.
Leaned on top of it, and zinged them right off with ease.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 01-19-2017, 05:45 AM
Valve grinding compound
Put valve grinding paste on your tool.No comments Rawknees.Then inside the nut with a small acid brush.Two foot bar for leverage and give it a quick crack after brief heating with a #2 torch head.Fred
Old 01-24-2017, 09:55 AM
