3.2 Piston Pin Diameter
Why would the specs on this be n/a in Wayne's book? Is this to imply reusing them is not an option or just that for whatever reason Porsche didn't make it public. Mine appear to be just a couple thou under 23mm.
TIA
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 04-11-2008, 10:00 AM
Bill Verburg's Avatar
Bill Verburg
Old 04-11-2008, 10:29 AM
Bill, Can you clarify your post for me? I must be missing something since I assume it would not be even close to in spec if it was down to 20.033. Is 20.033 the minimum diameter for the smaller displacement pins? Hopefully not a stupid question on my part...
Buck
'88 Coupe, '87 Cab,
Old 04-11-2008, 12:27 PM
Scrappy's Avatar
He mistyped it ... they are 23 mm
Ron Meier
Backyard Shadetree Mechanic
1974 914/6 conversion with 2.7L (The Grey Ghost)
1973 Chalon with 2.4T MFI (Schlitzalom)
All my 4 cylinders are gone
Old 04-11-2008, 12:53 PM
conrod bush diameter installed 23.020 <> 23.033mm
conrod bush/ piston opin clearance +0.02 <> +0.037, wear limit 0.055
Bill Verburg
Old 04-11-2008, 04:09 PM
Piston pins are usually considered reusable.
Since the pin is a press fit into the piston, the only wear area is the contact surface on the rod bushing. Since the rod bushing is the softer material, it wears instead of the piston pin.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 04-12-2008, 03:39 AM
The tech that measured them said the piston pins fit very snugly into the bushings and suggested reusing them. I guess I got lucky but so far everything that has been measured has been in spec...lucky me, so far.
Buck
'88 Coupe, '87 Cab,
Old 04-17-2008, 07:13 AM
