they call it , "ONE STOP SHOPPING" to me... Wayne has created such by starting with answers to the how do I fix xyz... a live internet forum... and parts!!! how much easier could he make it!!
Now Wayne, you promised me that trans repair ~book... are you working with Grady on it?? That publication will wrap it all up for me and I will be hooked here @ Pelican for the rest of my life !! Thx Wayne for everything !!! Bob
I live for 911 tweaks... |
Don't get me wrong....I willingly drank the Pelican Kool Aid and don't regret it one bit!
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Henry & John, here is the response I got from ARP regarding ordering bolts sans nuts
and nut sizing: Quote:
andy |
Try not, Do or Do not
My comment is " he is probably correct".
The parts number is probably AR363-2. not AR-363-2 The rod nuts might be 12mm. We don't use them so I can't answer that with any confidence. As for "We do not recommend after market nuts with our rod bolts. I would guess that they don't recommend other peoples products. That is the nature of sales.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 06-10-2008 at 08:23 PM.. |
Just one more thing Henry, is there a special tool required for the
12 point flanged 928 nuts or will any 12 point socket fit correctly? andy |
Standard 14 mm 12 point socket.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Henry do you think i should replace my rod nuts, the engine was started and warmed up to temp a handful of times. The car was never driven, never broken in, so the engine never saw any load. The engine was completely disassembled because of oil leaks and after finding some metal in the sump screen he wanted to make sure all was still well . The builder is replacing the rings, and bearings but says the rod bolts were still within limits, should i invest in another set of the 928 nuts, do they also stretch or fatigue when torqued.
I hope someday i will get to drive this thing, it's going on 3 years now, the engine has been in the shop since Feb this time, i am pushing them to get it together this month. The car looks great. I visited the shop this morning, no one was home but peeking in the windows i saw the heads were on and looks like all that is left are the tensoners.
![]() 914 6 Turbo twinplug 3.12 87 924S Lexus SC400 Lexus LS400 Last edited by iamchappy; 06-12-2008 at 07:58 AM.. |
Hi Chappy
I am sorry to hear that your project is dragging on. If there is anything I can do to facilitate a more rapid completion, it would be my pleasure. Sometimes you just get so close and the end just slips away. If you are using ARP bolts with my nuts, reusing them multiple times is not an issue. Good luck.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 06-12-2008 at 04:27 PM.. |
Thanks Henry.
![]() 914 6 Turbo twinplug 3.12 87 924S Lexus SC400 Lexus LS400 |
| Tags |
| trade secrets |
