I would rather be driving
jpnovak's Avatar
Great work.
Since no one asked... Need any test cars?
Old 07-15-2009, 09:13 PM
Steve W's Avatar
I am glad you are doing these and they look great. For normally aspirated, will this be the final configuration or will you build them out with longer primaries such as the 29-31" length 911 motors normally use? If you want to completely blow everything else out of the water you would want to make sure no other header has anything on you technologically, which if you'd like to consider, includes stepped primaries, such as illustrated below with 1 5/8" on the first third, and 1 3/4" on the second third, (or 1.5" - 1 5/8") your mitered collector, and a reverse cone immediately after such as these headers. This helps preserve midrange while adding high rpm flow like a set of progressive tapering megaphones. Add a heat option and design it to also fit the 964s and 993s, targeting your price point similar to SSIs and everybody will be buying yours.
Old 07-15-2009, 09:34 PM
Bill Verburg's Avatar
Steve, who makes the stepped headers? very nice!!
Bill Verburg
Old 07-16-2009, 05:23 AM
I see the competition for mb's headers as Fabspeed
Bill Verburg
Old 07-16-2009, 05:25 AM
Crotchety Old Bastard
RarlyL8's Avatar
Steve, unfortunately it is not likely we can do all of that and add heat exchangers while retaining a retail price of <$1200.
This product is designed for a different niche than SSI and will be priced competitively for what it is.
Flipped flanges are not a problem so 964/993 option is viable.
Yes the headers pictured are not complete. There will be extensions that bolt up to stock configuration mufflers such as M&K.
Old 07-16-2009, 07:51 AM
Originally Posted by jpnovak View Post
Great work.
yes but that will be part of the preproduction run. if interested PM me or Brian. it should be noted that these are brian designs that We at M&K have made happen. We are both excited to get this launched
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 07-16-2009, 08:24 AM
Steve W's Avatar
excellent work guys. I agree, heat along with larger primaries would put the product in competition with Fabspeed, along with B&B, and if it will work with a factory style muffler, that would be a big plus.
Bill - those pics are of Rob McCabe headers.
Old 07-16-2009, 10:56 AM
mnmasotto's Avatar
I hate resonance/drone
Is there anything that can be added during the design process to reduce resonance? To me this is the most important factor.
1987 Carrera MoTec 3.8L Transplant, 993TT Brakes
2006 M3 Competition Package
2007 997 GT3 - SOLD
Old 07-18-2009, 11:53 PM
E-85 sippin drunk
turbobrat930's Avatar
I think that, well, atleast in my opinion...resonance is created in the muffler....not in the headers...
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 07-19-2009, 03:16 AM
RarlyL8's Avatar
Yes, sound quality will be verified befrore anything goes out the door.
Old 07-19-2009, 04:59 AM
mnmasotto's Avatar
Nice
When do you anticipate the pre-order folk will get their headers?
2007 997 GT3 - SOLD
Old 07-19-2009, 10:35 AM
RarlyL8's Avatar
I am going to start building the secondary assembly today. Primaries are finished and all the tooling is done. Secondary Y-joint is finished and all tooling done. All that is left is tooling on the 2 y-assembly slip joints and of course final fitment test. All should be finished in a couple of weeks.
So to directly answer your question, the first complete set should go out the door in about 3 weeks.
Old 07-19-2009, 11:55 AM
NA sets would be a bit faster once we have a commitment don't you agree?
Ben
89 944,85.5 944
914-6werkshop.com
Old 07-19-2009, 05:22 PM
RarlyL8's Avatar
911 headers are done. Secondary pipes will take no time. I was referring to 930 headers.
I removed my exhaust system and bolted on the headers today. If you can turn a door knob you can install these headers. Took maybe 10 minutes to bolt up with gaskets. Everything very easy to get to as designed.
This is the 930 version, the mirrored 911 version is just as easy to install.
Old 07-19-2009, 07:59 PM
Great product! But decreased clearance would be a problem for those who want to lower their cars or for use on some country roads.
'87 3.2 Targa
Old 07-20-2009, 06:40 AM
they don't hang down any further then any other system it is more optical illusion
Ben
89 944,85.5 944
914-6werkshop.com
Old 07-20-2009, 09:27 AM
3 restos WIP = psycho
kenikh's Avatar
Originally Posted by mb911 View Post
As long as the slip fits are tight then no issues' I run a slip on my set up and it is a very tight seal so very happy with the design
Missed this reply. Thanks! Certainly makes life easier than having to weld all of the pipes. Looks like I need to buy some springs and clips! What is the rule of thumb on flare length?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-20-2009, 01:59 PM
Will they also work with the backdated oil lines that most of us running racing headers already use?
Gone
92 C2
82 Euro SC race car
993 C4S 3.8
84 Euro Carrera
Old 08-11-2009, 06:58 PM
Plavan's Avatar
I know a nice new shiny 2.5L race motor that would be happy to test these out....
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 08-12-2009, 10:24 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Those lines pictured above are the non-backdated lines. As you know the backdated lines work with the more commonplace headers and are typically required. It looks like the new headers stop well short of the oil cooler where the backdated half-circle U-shaped oil line is routed. I think the backdated or the later style lines will both work.
Also a friend of mine (cstreit here on Pelican) uses slip-fit headers on his race car. They don't leak and also are much more installation friendly.
Kevin L
'86 Carrera "Larry"
Old 08-12-2009, 12:18 PM
