I would rather be driving
Great work.
Since no one asked... Need any test cars?
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I am glad you are doing these and they look great. For normally aspirated, will this be the final configuration or will you build them out with longer primaries such as the 29-31" length 911 motors normally use? If you want to completely blow everything else out of the water you would want to make sure no other header has anything on you technologically, which if you'd like to consider, includes stepped primaries, such as illustrated below with 1 5/8" on the first third, and 1 3/4" on the second third, (or 1.5" - 1 5/8") your mitered collector, and a reverse cone immediately after such as these headers. This helps preserve midrange while adding high rpm flow like a set of progressive tapering megaphones. Add a heat option and design it to also fit the 964s and 993s, targeting your price point similar to SSIs and everybody will be buying yours.
Steve, who makes the stepped headers? very nice!!
I see the competition for mb's headers as Fabspeed
Crotchety Old Bastard
Steve, unfortunately it is not likely we can do all of that and add heat exchangers while retaining a retail price of <$1200.
This product is designed for a different niche than SSI and will be priced competitively for what it is. Flipped flanges are not a problem so 964/993 option is viable. Yes the headers pictured are not complete. There will be extensions that bolt up to stock configuration mufflers such as M&K.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
yes but that will be part of the preproduction run. if interested PM me or Brian. it should be noted that these are brian designs that We at M&K have made happen. We are both excited to get this launched
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
excellent work guys. I agree, heat along with larger primaries would put the product in competition with Fabspeed, along with B&B, and if it will work with a factory style muffler, that would be a big plus.
Bill - those pics are of Rob McCabe headers. |
I hate resonance/drone
Is there anything that can be added during the design process to reduce resonance? To me this is the most important factor.
1987 Carrera MoTec 3.8L Transplant, 993TT Brakes 2006 M3 Competition Package 2007 997 GT3 - SOLD |
E-85 sippin drunk
I think that, well, atleast in my opinion...resonance is created in the muffler....not in the headers...
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
Yes, sound quality will be verified befrore anything goes out the door.
Nice
When do you anticipate the pre-order folk will get their headers?
I am going to start building the secondary assembly today. Primaries are finished and all the tooling is done. Secondary Y-joint is finished and all tooling done. All that is left is tooling on the 2 y-assembly slip joints and of course final fitment test. All should be finished in a couple of weeks.
So to directly answer your question, the first complete set should go out the door in about 3 weeks.
911 headers are done. Secondary pipes will take no time. I was referring to 930 headers.
I removed my exhaust system and bolted on the headers today. If you can turn a door knob you can install these headers. Took maybe 10 minutes to bolt up with gaskets. Everything very easy to get to as designed. This is the 930 version, the mirrored 911 version is just as easy to install. ![]()
Great product! But decreased clearance would be a problem for those who want to lower their cars or for use on some country roads.
'87 3.2 Targa |
they don't hang down any further then any other system it is more optical illusion
3 restos WIP = psycho
Missed this reply. Thanks! Certainly makes life easier than having to weld all of the pipes. Looks like I need to buy some springs and clips! What is the rule of thumb on flare length?
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 Last edited by kenikh; 07-20-2009 at 02:02 PM.. |
Will they also work with the backdated oil lines that most of us running racing headers already use?
Gone 92 C2 82 Euro SC race car 993 C4S 3.8 84 Euro Carrera |
I know a nice new shiny 2.5L race motor that would be happy to test these out....
Chad Plavan 911ST Race Car/2.5L SS Race Motor #02 1972 911T- Numbers matching- Restoring to stock 2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold) 2016 Elan NP01 Prototype racecar- Chassis #20, #02 |
Schleprock
![]() ![]() Those lines pictured above are the non-backdated lines. As you know the backdated lines work with the more commonplace headers and are typically required. It looks like the new headers stop well short of the oil cooler where the backdated half-circle U-shaped oil line is routed. I think the backdated or the later style lines will both work. Also a friend of mine (cstreit here on Pelican) uses slip-fit headers on his race car. They don't leak and also are much more installation friendly.
Kevin L '86 Carrera "Larry" |
