I just switched from a carbureted 2.8 race motor to EFI and ITB. The throttle response was amazing. Good for a couple of seconds on the track. But track tuning is a lot simpler than street tuning, as you really don't care about part throttle or idle.
A mag cased 2.7 is not, however, the engine I'd want to fuss around with hot rodding. Longevity compromised with stock power as it is. CIS is a pretty nice street system. Its complexity is at least easier to understand to some of us than a computer controlled system. It can be made to run just fine. Walt |
EFI is sweet with endless tunability, but I think its a lot easier than carb and CIS. My belief is that initial tuning of an EFI system on a rolling road by a professional is mandatory.
A good tuner will have the system running at 99% in 4-6 hours. Back to the mag case CIS to carb with e-cams. I just want a sweet running street engine with good throttle response and a bit more power than its original 165-175hp.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
carbs?
I have a very sweet running mag case 2.7 1977 with PMO 40's e cams barry hershon recurved dizzy ssi's and m&k 2 in 2 out. MSD 6al. Idles beautifully and pulls strong up to the redline and beyond if I let it. I have a 6.5k limiter. I could not recommend it mor e it's super. I only had to change idle jets from 55's to 60's to remove a slight flat spot at transition. It's a little loud but i love it. I had Webers before the PMO's and they were sold for $1500 and the new PMO's cost 3K I think. My pro Porsche mechanic's butt dyno estimates 200 to 210 horses. good luck with your project.
wally , Montreal
Wally in Montreal, Canada My age 50 something,P- Car's age 30 something 2.7 911S PMO 40's , E cams, RS pistons/cylinders, MSD6AL, Pertronix, SSI's, M+K 2 in 2 out. Perfect studs (whew!) |
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
When you all do an MSD 6al ignition do you also convert the dizzy to remove the points? Thanks, Nathan PS: al lkosmal - your ITB setup sure looks cool, I'll probably check into something like that at some point, just no all-inclusive kits for us newbie EFI ITB guys. If yours ends up like that I'd be all over it.
'73 2.0 914 (2.8 /6 conversion in progress) '64 356SC '65 Ducati Falcon 80 ‘19 Audi SQ5 |
You can use the points with the MSD. I haven't done a conversion to no points. I like the simplicity and reliability of points.
-Andy
72 Carrera RS replica, Spec 911 racer |
