brads911sc's Avatar
Update --
Rockers in.
Valves Adjusted.
Chain Housing Covers on.
Tensioner Oil lines installed.
Distributor in.
To do...
Install Oil Cooler - Test, Clean, Flush by Tom Butler.
Install Valve Covers
Install Spark Plugs.
Close to a completed Long Block.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 02-03-2011, 06:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
arbita1's Avatar
Cool. Looks good.
Did you put the JB Weld in the spots according to Wayne's book? I don't see it on the chain housing covers.
Matt.
83 911SC
85.5 944 NA - Sold
Old 02-04-2011, 05:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
911 SC '83 using Microsqu
Great work, looking to rebuilt mine as well in the next coming months. Will go to 10.5 JE, twin, JB racing cylinders, GE80 cam and custom CNC head porting and EFI with Microsquirt as hte engine control (Great and cheap package). Engine in pieces, no damage. In process to get the parts, wish to close the case by this summer. Slow lead time, better cash flow!
Sorry to ask but what is the coating added to the main crank bearing?
Alain
Old 02-04-2011, 06:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
brads911sc's Avatar
I did.. except on the chair housing covers. It was never there. Would you add it?
Originally Posted by arbita1 View Post
Cool. Looks good.
Old 02-04-2011, 08:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
arbita1's Avatar
Check Wayne's book. I believe he tells you to do it.
Matt.
83 911SC
85.5 944 NA - Sold
Old 02-04-2011, 08:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
brads911sc's Avatar
It has been a real education and alot of fun. You will have a blast. Just take your time...
The coating is a micro shot peen with Tin (Sn) and Molybdenum Disulfide (MoS2) , and other material. Company is WPC.
WPC - Metal Surface Treatment / Micro Shot Peening
Alain
Old 02-04-2011, 08:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
WPC metal surface
Hum! Interesting but not convinced...
Just to let people know, to repair cracks or any damaged inside the case I would prefer to use Loctite 99393 or Magnobond 6398 over JB weld product.
I taught I could share some pictures of my project. Still in the mode to prepare the parts and redo some of them.
thanks
ALain
Old 02-05-2011, 09:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
PFM PFM is offline
PFM
PFM's Avatar
pw36889,
What distributor or sync wheel is in the second photo? Do you have a part number?
Thanks,
PFM
Stay Tuned,
PFM
Old 02-05-2011, 10:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
This is a custom made distributor that uses the JB racing rotor and cap! I did used an hall effect sensor from Bosch. 1500 $ for the JB racing design was too expensive so I decided to design and built the unit myself
Alain
Old 02-05-2011, 12:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
PFM PFM is offline
PFM
PFM's Avatar
pw36889,
The part looks so good I thought it was a factory piece. I plan to use a coil near plug setup with a Megasquirt and that looks like it would work.
I assume the drive gear is from JB Racing too. I think I will stick with my crank fire setup and flying magnets on the pulley and a pickup like Bruce Andersons.
Nice work.
Stay Tuned,
PFM
Old 02-05-2011, 04:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
The part has been made in a factory by myself using housing in alu 7475(over kill) and 17-4 ph shaft h900. That piece will las forever. Bevel is from the original dist. Pf course everything anodize. Will be on test on the microsquirt soon. The next part to go is a superlight engine support.
Old 02-05-2011, 04:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
brads911sc's Avatar
Longblock Complete...
Old 02-12-2011, 04:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #132 (permalink)
Targa Time's Avatar
Beautiful engine! Have a question for you though. Did you forget the alternator ground wire that attaches to the top of the case or are you relocating it elsewhere?
Old 02-13-2011, 03:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #133 (permalink)
brads911sc's Avatar
I have the wire. I actually did forget. but when I started cleaning my fan/housing i saw it.
I have a new alternator being delivered Wednesday...
Update...
I also have thin flange SSI's, so I am swapping out all my exhaust studs. What a ball buster that is. Youd think for $2,250, the heads would come with new hardware. Not so much... I snapped off four of the first 8... So I am glad I have the jig. But its painful. Think Ill need to Timesert two of them. I ordered the M8 timeserts and the installation tools. Should have it by the weekend. Stay tuned.
Old 02-15-2011, 07:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #134 (permalink)
onboost's Avatar
Nice work Brad!
Spring is coming and you seem to be at the proper pace. Good Luck.
Paul
RGruppe #180
Old 02-23-2011, 01:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #135 (permalink)
onboost's Avatar
thanks
ALain
Nice stuff.. have you started a thread for your build?
RGruppe #180
Old 02-23-2011, 01:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #136 (permalink)
brads911sc's Avatar
Update
Some updates.
Engine is complete except for Clutch/Pressure plate.
Intake Manifolds on. PMO's will go on after engine is under the car.
My distributor was off 180 degrees. That was fixed. ready to go.
Old 02-27-2011, 07:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #137 (permalink)
brads911sc's Avatar
I have decided to tackle the electrical inside the engine bay. I had my relay board mounted back on the firewall and I just wasnt happy with the looks. I bought a new EFI wiring bundle and a new 8 fuse fuse block.
Hope to get this done this week.
Old 02-27-2011, 07:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #138 (permalink)
brads911sc's Avatar
Thanks Paul!
Originally Posted by onboost View Post
Nice work Brad!
Paul
Old 02-27-2011, 07:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #139 (permalink)
Arrow
Looking good Brad, fire that engine up allready!
Shane
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 02-28-2011, 08:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #140 (permalink)
