70' 911e engine rebuild, soda blast cases?
I am performing a concourse engine restoration/rebuild on my 70' original paint 48k mile 911e.
I have heard of baking soda blasting the cases for optimum finish, opposed to machine shop pressure cleaning solution.
Has anyone had any experience of baking soda blasting early 911 cases ?
Old 02-28-2011, 09:26 AM
Chain fence eating turbo
I don't have first hand experience with soda blasting but I can attest to the niceness the cases shown here on Pelican.
I don't think any chemical cleaning can reproduce the results mechanical cleaning can due to the instant corrosion (spotting and darkening) chemicals/soaps and water do to magnesium and aluminum.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 02-28-2011, 09:41 AM
For a concourse finish, have the case tumbled by Ollies.
Home Page
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 02-28-2011, 10:26 AM
Max Sluiter
Flieger's Avatar
I have heard at least one expert recommend soda blasting the case, since it is so gentle and will not abrade the surface.
Old 02-28-2011, 10:42 AM
356RS's Avatar
Ceramic Porcelain Media is what's used in the tumbler that Ollie's has. It's the gentle rubbing of the media that produces a deburring effect on the case. IMHO soda blasting on a mag case would take a very long time, and I don't think it's a strong enough media to accomplish the same thing a tumbler provides.
Mark Jung
Bend, OR
MFI Werks.com
Old 02-28-2011, 11:30 AM
Carrerax's Avatar
I had mine tumbled with ceramic media and it turned out perfect. Ill look for pictures. Just remember that media will get everywhere and into everything. you or your engine builder must be very diligent to get it all out. I thought I had it all out and then my builder informed me otherwise. That said, glad I did it.
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
Old 02-28-2011, 01:24 PM
brads911sc's Avatar
M Callas recommends against using any media on the case. He actually wont use it. wont be as pretty but also wont have to worry about missing any...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 02-28-2011, 01:57 PM
Hbrand
hbrand's Avatar
Soda Blasting
I have had a 911S case locally Soda Blasted and it came out great. Clean up with water and air.
Keeps all the edges sharp as they are, while tumbling will round up corners.
Thanks, Harold
Cheers
1982 Porsche 911SC Euro
1969 Mercedes 280SL
1956 Austin Healey 3x
Old 04-05-2011, 05:01 PM
Walt Fricke's Avatar
I can confirm that soda blasting is gentle. I can hold the parts in my hand without gloves. Worked great on the hard to deal with grime on an aluminum 915 tranny case.
Didn't do as much on a mag tranny case. However, you don't really want to remove the surface oxide layer from these cases, as it is what protects it. So you can remove grime, but not necessarily get an even finish, much less a shiney one (which wouldn't last long anyway, due to oxidation).
For true concours, at least in some classes, you will be docked points if parts of your car are better looking than when the car rolled out of the factory!
Walt
Old 04-06-2011, 03:47 PM
