E-man930's Avatar
Very nice transmission pr0n!
Are you going to slap on a billet sideplate while you are at it?
I may be interested in having my box gone through in the spring so I'll PM you for details...
E-man
Old 08-25-2011, 04:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #281 (permalink)
CaptainCalf's Avatar
Thanks E-man!
Yep, billet cost $200 extra, but while ur in there
Old 08-25-2011, 04:57 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #282 (permalink)
E-man930's Avatar
I meant the diff cover / side plate, not the bearing retainer - which is a great upgrade on it's own.
Old 08-25-2011, 05:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #283 (permalink)
Oh, no gotta draw the line somewhere...now where did that line go?
Old 08-25-2011, 05:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #284 (permalink)
350HP930's Avatar
LOL, the 'while you're in there' addiction can be very strong.
Old 08-25-2011, 05:57 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #285 (permalink)
No doubt, I've got it so bad I'm shaking just thinking about the EFI
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 08-27-2011, 11:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #286 (permalink)
Exh gasket choice
Which exh gaskets should I use?
Old 08-27-2011, 12:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #287 (permalink)
The ones on the left!
Old 08-27-2011, 12:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #288 (permalink)
Tranmission, sprockets, headers all done!
Headers done thanks Brian!
Tranmission done thanks Mike!
Sprockets torqued but what should the parallelism measurements be on a 1987 930 case?
I've got these measurements that don't match Bentley and I can't decifer what Wayne's book says...3 shims on the left and 4 shims on right:
8mm = intermediate shaft
Edit: Correction not 57mm...actually 53mm = right sprocket
107mm = left sprocket
Edit:Would it work best if I took the 4 shims on the right off and the 3 shims on the left off???
Old 08-27-2011, 12:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #289 (permalink)
Will do and thanks!
Old 08-27-2011, 01:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #290 (permalink)
350HP930's Avatar
Are those mounting points next to the wastegate outlets or are those O2 sensor bungs?
Old 08-28-2011, 01:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #291 (permalink)
Lambda bungs with plugs cuz I wont be using them to start with...my Lambda will be pulled after the turbo before the muffler
Old 08-28-2011, 03:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #292 (permalink)
More progress today!
I was amazed at the amount of oil in these big brake lines that run from the oil tank area to the front right wheel area
Old 08-28-2011, 04:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #293 (permalink)
Oil line juction
What the heck is this intersection for???
Old 08-28-2011, 04:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #294 (permalink)
Turbo oil pump
Anybody know where I can source a new drive pin for my turbo oil pump? I'll also need a new seal to do this rebuild right...Thanks
Old 08-28-2011, 04:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #295 (permalink)
oil tank out for cleaning
can a radiator shop clean an oil tank?
Old 08-28-2011, 04:58 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #296 (permalink)
j911brick's Avatar
Thermostat an bypass valve for front oil cooler.
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 08-28-2011, 08:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #297 (permalink)
350HP930's Avatar
If you have a hard time sourcing the pin just give me the dimensions and I'll whittle you one, lol.
Old 08-29-2011, 10:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #298 (permalink)
Thanks, but I found them at McMasters...they have just about anything you could think of, but you have to buy 10
Old 08-30-2011, 05:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #299 (permalink)
turbo oil pump dowel pins
If anybody needs a dowel pin to rebuild their scavange/turbo oil pump shoot me a PM and I'll hook you up. Warning these pins require a press to remove and replace...I can't even begin to tell you how much I like my 10 ton press
Oh yeah, got a new keg yesterday...Bells Two Hearted Ale and it rocks!!!
Old 08-31-2011, 06:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #300 (permalink)
