Very nice transmission pr0n!
Are you going to slap on a billet sideplate while you are at it? I may be interested in having my box gone through in the spring so I'll PM you for details... E-man |
Thanks E-man!
Yep, billet cost $200 extra, but while ur in there
I meant the diff cover / side plate, not the bearing retainer - which is a great upgrade on it's own.
Oh, no gotta draw the line somewhere...now where did that line go?
LOL, the 'while you're in there' addiction can be very strong.
No doubt, I've got it so bad I'm shaking just thinking about the EFI
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha |
Exh gasket choice
Which exh gaskets should I use?
The ones on the left!
Tranmission, sprockets, headers all done!
Headers done thanks Brian!
Tranmission done thanks Mike! Sprockets torqued but what should the parallelism measurements be on a 1987 930 case? I've got these measurements that don't match Bentley and I can't decifer what Wayne's book says...3 shims on the left and 4 shims on right: 8mm = intermediate shaft Edit: Correction not 57mm...actually 53mm = right sprocket 107mm = left sprocket Edit:Would it work best if I took the 4 shims on the right off and the 3 shims on the left off??? ![]() ![]() ![]()
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha Last edited by CaptainCalf; 08-27-2011 at 12:22 PM.. Reason: correction |
Are those mounting points next to the wastegate outlets or are those O2 sensor bungs?
More progress today!
I was amazed at the amount of oil in these big brake lines that run from the oil tank area to the front right wheel area
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha Last edited by CaptainCalf; 08-28-2011 at 04:13 PM.. Reason: spell |
Oil line juction
What the heck is this intersection for???
Turbo oil pump
Anybody know where I can source a new drive pin for my turbo oil pump? I'll also need a new seal to do this rebuild right...Thanks
oil tank out for cleaning
can a radiator shop clean an oil tank?
Thermostat an bypass valve for front oil cooler.
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
If you have a hard time sourcing the pin just give me the dimensions and I'll whittle you one, lol.
turbo oil pump dowel pins
If anybody needs a dowel pin to rebuild their scavange/turbo oil pump shoot me a PM and I'll hook you up. Warning these pins require a press to remove and replace...I can't even begin to tell you how much I like my 10 ton press
![]() Oh yeah, got a new keg yesterday...Bells Two Hearted Ale and it rocks!!!
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha Last edited by CaptainCalf; 08-31-2011 at 06:51 PM.. Reason: beer |
