LinkBack Thread Tools Rating: Thread Rating: 5 votes, 4.20 average.
jsveb's Avatar
It looks fantastic.
What paint did you use for the Oil tank?
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 10-02-2011, 06:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #361 (permalink)
350HP930's Avatar
Do a test of the thermo switch and/or fan motor when you can. If memory serves me correctly I think that towards the end of her previous days I never heard the fan kick in when she started getting hot like it used to.
Old 10-02-2011, 06:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #362 (permalink)
CaptainCalf's Avatar
Originally Posted by jsveb View Post
It looks fantastic.
Thanks, I used an engine enamel with ceramic in it
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 10-03-2011, 06:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #363 (permalink)
Thanks for the heads-up Tony, I'll order a new switch before I put it back in
Old 10-03-2011, 06:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #364 (permalink)
Ring & Pinion value???
Anybody recognize this R&P that came outta the 930 4speed gearbox? I figure it's original but is marked high output. Looks like the set is in great shape so I'll be sending it on it's way for somebody out there that needs it
Any idea what $$$ I should ask for the set?
Thanks!
Old 10-03-2011, 07:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #365 (permalink)
More parts not being used
Here's some more parts I wont be using, so if you see anything you want let me know and I'll hook you up before I list them in the classified section:
930 clutch set
Wastegate & pipe spring set at 7psi to be used with Electronic Boost Controller
HKS Electronic Boost Controller
Euro fuel head and 930 intake manifold and associated parts
CIS fuel injectors
Old 10-03-2011, 08:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #366 (permalink)
Max Sluiter
Flieger's Avatar
Is that a 9/37 ring and pinion? I believe that is a desireable ratio for being shorter than 8/31 but stronger.
Old 10-03-2011, 11:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #367 (permalink)
I wish! I double checked and it's a 9:38 stock ratio
Old 10-03-2011, 11:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #368 (permalink)
Max Sluiter
Flieger's Avatar
9/38 is even better I would think. I thought 9/37 was the ratio that was made aftermarket to be shorter but I must be wrong if 9/38 is stock. Or maybe 9/37 is for 915s?
Old 10-03-2011, 11:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #369 (permalink)
a little more progress
got the headers fitted, alternator & fan on
Old 10-03-2011, 06:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #370 (permalink)
MBruns for President
JeremyD's Avatar
excellent progress!
Old 10-03-2011, 07:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #371 (permalink)
exh stud hole stripped
I decided to torque up the headers tonight and found that 1 of the 12 studs pulled instead of torquing, so I pulled the feft bank of headers back off and will drill, tap and time-cert the bad hole. It's a setback, but I'd rather find it now then later as an exhaust leak
Old 10-06-2011, 06:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #372 (permalink)
350HP930's Avatar
I guess I should have warned you that I wrote that I next to that hole to remind myself it needed an insert. Keep an eye out for a similar marks next to one of the engine trim bolt holes as well.
Old 10-06-2011, 09:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #373 (permalink)
Dude, you gotta tell me these things otherwise I may not be anal enough to find them
Old 10-08-2011, 02:59 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #374 (permalink)
Good progress today
I got the 930 int gaskets modded for the Carrera intake, new fatter brass bushings in the spacers and more!
Old 10-08-2011, 03:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #375 (permalink)
350HP930's Avatar
I'm impressed as always Rick.
Old 10-08-2011, 03:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #376 (permalink)
Thanks, I appreciate everything
Old 10-08-2011, 03:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #377 (permalink)
Ken911's Avatar
so the spacers need bushings? I didnt know that , one more thing i need to get done lol.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 10-11-2011, 03:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #378 (permalink)
350HP930's Avatar
You could get by without them, but the bolt holes are large enough to allow for a little mis-alignment so it never hurts to go for the extra degree of accuracy.
Old 10-11-2011, 05:55 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #379 (permalink)
+1, it's one of those little things that taken together all add up to a big difference in the end
Old 10-11-2011, 06:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #380 (permalink)
