LinkBack Thread Tools Rating: Thread Rating: 5 votes, 4.20 average.
CaptainCalf's Avatar
crank sensor tin mod sorted
Since the 930 didn't have a crank position sensor I had to mod the tin for the plug to run up topside
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 11-23-2011, 06:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #481 (permalink)
Switched gears today and worked on interior
Look what I found under the driver's seat. I wont be needing the CIS controller, but I think one or both relays will be needed. Isn't the black one a fuel pump relay?
Old 11-24-2011, 01:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #482 (permalink)
Electric sport seats
these bad boys are heavy! anybody know a good lightweight alternative?
Old 11-24-2011, 01:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #483 (permalink)
ready for a new carpet kit
old carpets are out...door panels next
Old 11-24-2011, 01:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #484 (permalink)
You can remove all the stuff under the driver seat and their harness since you're going EFI.
If you want you can now remove the upper and lower heavy stock rear sound pads and replace them with newer lighter weight material and the car will loose around 25+ lbs without getting louder inside.
Then you can probably sell the stock rear soundpads to someone wanting those.
The stuff on the floor pan weighs around 8 lbs and there's lighter stuff you can brush on there instead.
Old 11-24-2011, 05:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #485 (permalink)
Thanks Jim
Old 11-24-2011, 05:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #486 (permalink)
proffighter's Avatar
Recaro Pole Position:
Roland
930 Turbo '81 Too many modifications to list
Old 11-25-2011, 12:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #487 (permalink)
Thanks Roland, those are sweet!
Old 11-25-2011, 05:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #488 (permalink)
more progress
While I'm waiting for more engine parts I continued working on the interior and ripped out the old heavy oem rear sound pads & headliner...glass had to come out first.
If I go back with a RS style carpet kit deleting the rear seats will I have to cut out the rear seat mounting bracket that is welded in place in the middle of the two rear seats?
Old 11-28-2011, 06:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #489 (permalink)
I got some brass Ts and vac line in, so I plumbed the fuel pressure regulators. Is this vac port on the very bottom of the base of the C2 throttle body normally used for this?
Old 11-29-2011, 06:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #490 (permalink)
Driver door lock stuck
The passenger door lock knob rotates the lock with ease open and closed, but the driver side seems to be stuck.
Could this key hole in the door jamb be the culprit? The ignition key doesn't fit it
Old 11-29-2011, 06:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #491 (permalink)
Sunroof is out
Pulled the sunroof in order to install the headliner and found lots of parts that need replacing. Mostly plastic bits, velvet & rubber seals & foam. Not sure how effective the foam was, but I plan to upgrade it with something that has better noise dampening properties.
Old 11-29-2011, 06:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #492 (permalink)
Sunroof Headliner Pan & glass
The sunroof headliner pan needs a good cleaning & don't tell the wifie I have the front and rear glass in the guest bedroom
Old 11-29-2011, 06:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #493 (permalink)
Your lock in the door probably just needs to be cleaned and lubed.
The keyhole on the door arms the factory alarm. When it was armed you would open the door normally with the key and then use the keyhole inside to disarm it. I think you had to do it without opening the door completely. I'm afraid to play with mine.
1987 GP White 930
1977 Ford Bronco
Old 11-29-2011, 06:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #494 (permalink)
alarm
Thanks Willtel
Old 11-30-2011, 05:03 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #495 (permalink)
350HP930's Avatar
Damn Rick, I haven't seen the thread for a while since for some reason I didn't get an update notice. You've been hard at work since the last time I checked in on ya.
Old 12-01-2011, 08:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #496 (permalink)
Yep, holidays are great cuz I get more time to play in the garage
Old 12-02-2011, 05:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #497 (permalink)
New Headliner & Amazoned CR Fuel line
The new headliner is in and I got Amazon to upgrade the C2 fuel lines to stainless and teflon.
Old 12-02-2011, 06:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #498 (permalink)
350HP930's Avatar
I'm assuming even with the windows and everything else pulled out there is no rust to be found? Porsche did do a awesome job coating those cars in order to back up their decade long rust warranty on them.
Now that I think about it I might still have the alarm key around here somewhere. I'll check to see if I can find it for you when I have a chance.
Old 12-02-2011, 08:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #499 (permalink)
No rust on the body anywhere...thank you Porsche
If you have the alarm key that would be worth a 6-pack of good craft beer when I stop by to pick it up
Old 12-02-2011, 08:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #500 (permalink)
