CaptainCalf's Avatar
Originally Posted by 911 tweaks View Post
looks good...I would consider banding or clamping the fuel lines at the connection points...!!
Thanks 911tweek!
I've put clamps on push on SS lines that don't even need them, so you know I'll be clamping these
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 01-13-2012, 05:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #581 (permalink)
MBruns for President
JeremyD's Avatar
Originally Posted by CaptainCalf View Post
Thanks 911tweek!
I mocked mine up with rubber fuel line then took to Amazon and had them make with stainless steel... Fuel is not one of the areas where I trust the connections...
Looks great though - looking forward to seeing the finished product.
Old 01-13-2012, 06:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #582 (permalink)
Agreed Jeremy! All my pressure lines are SS and most are Amazon SS w/ teflon inside. The rubber return lines IMHO don't need to be as heavy duty
Old 01-13-2012, 06:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #583 (permalink)
What a great project here. Thank you for sharing your journey with us all here. I'm inspired to go out to my garage and clean something.
PM me on that fuel accumulator... My engine is out but I think my accumulator was on the fritz last summer. (intermittent hot start issues)
Ken
1986 930 2016 R1200RS
Old 01-14-2012, 08:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #584 (permalink)
Thanks GSXRKen, sorry I've already sold the accumulator
Old 01-15-2012, 05:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #585 (permalink)
Last box of EFI parts
The final EFI parts are on the way, so I should finally have the motor in within a few weeks
In the meantime, I replaced the motor mounts with a set of sport mounts and pulled the flags for sanding, priming, sanding again, base coat, sanding again, top coat
Anybody ever paint their flags black on a red car???
Old 01-15-2012, 05:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #586 (permalink)
rsrfan's Avatar
black mirrors... no affiliation
JP
86 930/4 tribute beasty
81 sc beach beater
‘55 Belair
‘40 Ford pickup
Old 01-16-2012, 09:44 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #587 (permalink)
Thanks RSRFan, IMHO if those flags were flat or even satin they would look much nicer.
Old 01-16-2012, 10:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #588 (permalink)
350HP930's Avatar
That would sorta match those satin black wheels and headlight rims I gave ya, lol.
Old 01-16-2012, 10:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #589 (permalink)
Banner Red Flags
I decided to go back with the original color
Multiple coats of the base:
Sanded slick as a baby's butt ready for clearcoat:
Old 01-16-2012, 10:42 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #590 (permalink)
5.7 GT1's Avatar
Thanks Bob, they are Sparco tunner/streat seats R100s and weigh around 26 lbs in cloth fabric:
Sparco USA
I decided to go with them cuz they are not expensive and are reclinable for commuting comfort.
Did you order you seat mounts from sparco or fab them? Are they adjustable?
Car is looking fantastic! Wish I had more time to work on mine.
Old 01-17-2012, 01:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #591 (permalink)
Thanks 5.7GT1
I bought both the adapter/seat base bracket and the sliders from Sparco.
Sparco USA
However, with your skills you could fab up the adapters in no time, but since they were so cheap I decided against making my own: cut/weld/grind/paint/repeatx2
Old 01-17-2012, 05:12 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #592 (permalink)
CV Joint Rebuild
Today I pulled the CV joints apart and found 1 outta 4 is acceptable to reuse, so I'm replacing all 4.
I took the time to label and organize the parts in case I reused them:
Old 01-21-2012, 01:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #593 (permalink)
DSPTurtle's Avatar
Did you see a lot of galling on the balls, or the races? I've taken a lot of them apart over the years and the always seem reusable...
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 01-23-2012, 06:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #594 (permalink)
As you can see by the way I kept everything in order I figured I'd see minor wear and would be able to reuse them all, but that was not the case. The balls all seemed fine and reusable although some were discolored. 3 of the 4 races had deep cruves & pitting where material has worn away over the years. Only 1 set outta the 4 was acceptable. Looked like only one of the 4 had been serviced, so the grease in the other 3 was dried and full of metal shavings which I'm sure added to the wear seen.
Not sure what kinda interval these CV joints should be cleaned and repacked, but I think 25 years is prolly pushing it
Old 01-23-2012, 07:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #595 (permalink)
Cv
Rick, call me regarding your Axle and prep for them
Mike
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 01-23-2012, 07:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #596 (permalink)
Mike
will do & thanks Mike
Old 01-23-2012, 07:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #597 (permalink)
old CV joint detailed
I detailed the old CV joint with the least wear and it looks better then new
Here's my detail kit
Here's what the inner & outter races look like before and after detailing
Old 01-24-2012, 05:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #598 (permalink)
one more cv detail pic
done & ready to go!
Old 01-24-2012, 05:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #599 (permalink)
proffighter's Avatar
I don't think it's a good idea to work on ball races, because they are hardened (in your case probably no longer).
They will have too much play which can cause failure and wear immediately..
Look here:
CV Joints, Part 1
Roland
930 Turbo '81 Too many modifications to list
Old 01-25-2012, 12:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #600 (permalink)
