Up on jack stands
More progress:
I got the car up on stands last night and took a look at the brake pads & rotors. The front and rear calipers look like they are the same size/part, but if that's true why are different pads offered for each end? I'll be needing new front pads (<0.02mm) and the front rotors turned (groves) for sure and prolly the rears too. Our host has too many offerings to choose from Anybody got any experience with BHP pads? They look like a good all around street & track pad. I've used Hawk HPS pads before and like them a lot, but can't find them for a 1987 930. Anybody using Hawks? ![]() ![]()
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha |
This isn't engine forum information anymore, but the pistons in the calipers are different sizes between front and rear calipers.
They use the same pads front and rear but some people like to use different compunds front and rear on the track. I have Hawk HPS (high performance street) pads in my 930 and for the street they work very good. This store used to have the best price and Hawk inventory with free shipping, maybe they still do.. Hawk HPS, HP Plus, SuperDuty, Black, Blue 9012 HT10, HT14, DTC60, DTC70 - Discount Prices ! - Best Brakes |
RC
Looks great Rick, glad you were able to find a shiny 930 hiding out under all that dust and grime.
I've also just realized that the rear engine trim was hanging up in the corner of my garage so I will be adding that to your list of items to be picked up when you have a chance to swing by again sometime. |
![]() RC
NP, don't forget those old valves when you do.
I've got a cassette for ya too that I found in the dash
LOL, I didn't even think about what I might have left behind inside the car.
MBruns for President
Didn't realize this was all happening so close to us - very cool.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Mike at JB Racing has been busy!
Here's pics of the heads after skinning for firerings
APR Rod Bolt Stretch Study
My APR rod bolts are all over the place!
Here's a chart of stretch inches at 30 FT-LB torque: Sorry the grid line units didn't come through, but the top line is 0.012" and each line is 0.002" apart ![]() Here's a chart of stretch inches at 35 FT-LB torque: the top line is 0.014" and each line is 0.002" apart ![]() Here's a chart of stretch inches at 40 FT-LB torque: the top line is 0.018" and each line is 0.002" apart, so the 5th line down is 0.010" ![]() Based on this study in order to meet the stretch spec of 0.010" to 0.0105" I'd need to torque 2 at 40 ft-lbs, 5 at 35 ft-lbs and 5 at 30 ft-lbs. Can that be right?
That makes sense Rick, one reason measuring length is concidered the best way to torque critial fasteners is because a lot of variables can effect how applied torque is converted into stretch. The moly lube is intended to help but its not a perfect solution.
In the aerospace world they actually have special tools with ultrasonic transducers built into them so the stretch on all critical fasteners is used to determine when they are properly clamped instead of using applied torque. |
One thing that scared me about one of the bolts is that after it was stretched it missed coming back to it's original length by 0.002"
Double check your measurements, even a single hair getting caught in the stretch gauge could throw you off that much. It would take quite an over-torquing to permanantly distort an ARP fastener that bad.
Are you having another shop do the fire rings? Nice to see the mating surfaces cleaned up but I'm curious why they wern't cut for the rings at the same time. |
more pics
JB Racing does fine work & fast too!
PFM
CaptainCalf
I only see one spark plug hole in them heads.... What's up? Stay tuned, PFM
Stay Tuned, PFM |
Single spraks should do the job cuz this is only gonna be a mild low boost build at only 500hp
![]() Quote:
Twin plugging is way over rated for this head configuration with a flat top piston IMHO.
I can understand why twin plugging would help flame front propagation on high top, high compression pistons, but that's not the case here and the metal removed for the second plug would be more likely to raise head temperatures than it would be to improve mixture combustion. That's at least my opinion on the subject, but I'm sure some people here might have a differing opinion though. |
PFM
350HP930,
I do understand the point about a flat top piston versus a dome however boost creates cylinder pressure, high cylinder pressure has a large affect on ignition and two ignition sources is better than one. As you said just an opinion. It also depends on how much boost is applied as to benefit received. As for heat I would put a BIG vote in for ceramic coating of the chamber, valves, piston tops and exhaust ports. It does help contain the heat and protect the parts. Stay tuned, PFM
Stay Tuned, PFM |
