Less brakes, more gas!
euro911sc's Avatar
Fuel Injectors pointing into stream instead of with?
This pic was posted in a different thread:
It looks like the fuel injectors are pointing into the oncoming stream of air?? Why? Better atomization? space constraints? Other? I have always seen them pointing down stream...
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Last edited by euro911sc; 07-06-2011 at 10:35 AM.. Reason: Totally wrong engine type!
Old 07-05-2011, 01:49 PM
Hi Mike, thats high butterfly injection and sometimes they did aim the injectors up high in the injection stacks against airflow.
When I asked if that was for better atomization first time I saw that on a mechanical injection 935 motor when I worked at Gunnar 25 years ago, I got a nod meaning that is correct.
edit: that kinda looks like a 962C motor with air cooled cylinders and water cooled dual overhead cam heads. they used a small vertical fan instead of the large flat fan on that motor.
Old 07-05-2011, 02:16 PM
Jaguar did this in the late 50's, on the Lucas-injected D-Types, and BRM was famous for this, begining in 1962, on their Formula One engines (below). Tests showed it made engines less sensitive to variations in air/fuel ratios.
Jon B.
Vista, CA
Old 07-05-2011, 03:46 PM
Originally Posted by JFairman View Post
edit: that kinda looks like a 962C motor with air cooled cylinders and water cooled dual overhead cams. they used a small vertical fan instead of the large flat fan on that motor.
And that's a Kugelfischer injection pump at top RHS....956 I think
Old 07-05-2011, 04:22 PM
Schwarzeritter's Avatar
Location: PaloAlto Calif, IndianWells PalmDesert, Japan
How cool. I like these old pictures and so on.
Taze em..TAZE EM ALL!!
A man that builds a thousend bridges is a bridge builder, but a man that sucks one ( blank ) is a ( blank ) sucker.
It looks like the 4th of July from my rear view, how about from your view?
Old 07-05-2011, 04:25 PM
Max Sluiter
Flieger's Avatar
Yes, that is a 956 engine.
Old 07-05-2011, 07:03 PM
Almost Banned Once
sc_rufctr's Avatar
Great info but... Wouldn't the be dangerous at idle??? I'm think engine bay fires or worse.
EDIT" More about the Jag set-up than Porsche.
- Peter
Old 07-05-2011, 11:54 PM
Max Sluiter
Flieger's Avatar
Yeah, Lucas electrics + fuel spray =
The 956 would not be running much at idle, of course.
With MFI type fuel injection pressure there should be a pretty good cone of fuel spray when the momentum of the air is not pushing it down the intake runner. That is why it sprays below the throttle butterfly. At idle, the butterfly or slide is closed and blocks the fuel from coming out the top.
Old 07-06-2011, 10:26 AM
euro911sc's Avatar
Thanks for the engine correction I still have years of learning ahead !
So if it was better for race cars did it ever make it into a production car? Why don't we see it in today's race applications?
-Michael
Michael
'13 Cayenne GTS
Old 07-06-2011, 10:34 AM
Max Sluiter
Flieger's Avatar
DFI trumps all of that. It has better fuel atomization thanks to the tremendous injection pressure. That cools the charge, allowing higher compression, reduces wall wetting and the associated loss of lubrication. It can be timed for optimum emissions or power, even using multiple injection events per combustion cycle.
As to cars before DFI,
Street cars idle a lot, so would have worse fuel atomization due to fuel hitting the butterfly and condensing. Engine downsizing is done so that the throttle is open more and more often for better pumping efficiency. BMW has even used variable valve timing and lift (Valvetronic) to completely eliminate the throttle butterfly during normal engine operation.
Old 07-06-2011, 10:44 AM
Try not, Do or Do not
Henry Schmidt's Avatar
I found this MFI, hi butterfly injection on a turbo charged 2.5 liter 906.
MFI injectors pointing up. Some old school German fabricator spent countless hours on this
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-06-2011, 11:54 AM
Max Sluiter
Flieger's Avatar
Wow, turbo 906 motor. Was it used in a 906 or some home-built, sports-racer special?
Old 07-06-2011, 06:42 PM
euro911sc's Avatar
It never ceases to amaze me what you guys pull out of your hats!
Michael
'13 Cayenne GTS
Old 07-07-2011, 07:57 AM
It was in a wide bodied 906 basket case that was being restored to stock configuration.
Here an engine we just finished for a 904/6.
Henry Schmidt
Ph: 760-728-3062
Old 07-07-2011, 08:11 AM
stevepaa's Avatar
I remember walking into a shop over by San Jose airport next to the Maestro's shop and saw 4 or 5 of the four cam motors being rebuilt.
What a thing of beauty!
steve
old rocket inguneer
Old 07-07-2011, 10:22 AM
Jim Wellington's old shop, Rennsport Werke, 320 Martin Ave Santa Clara, once the center of all things 4-cam Carrera & Spyder.
Jon B.
Vista, CA
Old 07-07-2011, 10:27 PM
PFM PFM is offline
PFM
PFM's Avatar
Not a big fan of Henry's but he sure does nice work.
Stay Tuned,
PFM
Old 07-07-2011, 11:11 PM
