Head Studs
If I remove the heads from my 85 with 90K is it recommended that I go a few steps further and replace the head studs with new ones? Are there any others to consider, or is genuine the best bet?
I appreciate the feedback.
-matt
Old 04-04-2013, 02:15 PM
Although seemingly not as frequent as with SC's, Carrera head studs do sometimes break. On my recent rebuild I used Supertec head studs which are phenomenal quality and not that much more than stock steel studs (assuming you would use new nuts and washers).
In your case I would definitely consider it.
Old 04-04-2013, 02:44 PM
Standard practice for these engines is to replace the lower (exhaust) Dilivar studs with steel studs. Steel studs do not break in street motors.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 04-04-2013, 03:38 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The 911SC had more head stud problems (IE: breaking) then any other Porsche engine.
They were the first production engine equipped with Dilivar and they only used them on the bottom row making the clamping force on the cylinder to head joint incredibly uneven.
Throw the Dilivar studs away and seek another solution. Of course I think Supertec studs are the best but I advise you to do your own research and come to a conclusion the fit your sensibilities including budget.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-04-2013, 03:40 PM
Puny Bird
Mark Henry's Avatar
I just ordered your studs from here and they are back-ordered?
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 04-04-2013, 04:01 PM
Every time there is a discussion about head studs on this forum, there is a rush on my studs. People hear the arguments for and against and many builders choose my studs. We don't even have studs for three engines we're building now.
For some reason, the supply of our material with certs is in short supply. Our studs will be available in about two weeks.
Henry Schmidt
Ph: 760-728-3062
Old 04-04-2013, 04:47 PM
Do people consider the head studs to be single use? Or are they only replaced when broken?
Old 04-04-2013, 04:52 PM
Puny Bird
Mark Henry's Avatar
It's cool.
I was hoping to get it sent to my US buddy in time for hershey, but I'll just have to wait till he comes up to my place in June.
Old 04-04-2013, 04:53 PM
So is this a good problem or a bad problem for you Henry?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-04-2013, 08:25 PM
safe's Avatar
I ordered a set of Henrys awesome studs too a few days ago, back ordered.
I'm a bit annoyed with Pelican for claiming to have 1 set in stock, when they don't....
Magnus
Old 04-05-2013, 04:32 AM
Ingenieur
If you are not going to reuse your lower studs I will by them. They are reusable and I think they are a better solution. PM me if you want to sell them.
Old 04-05-2013, 08:53 AM
Straight shooter
Lapkritis's Avatar
Yes, replace all. Plenty of decent replacement options.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 04-05-2013, 09:29 AM
I have a plethora of used Dilivar studs. Mostly early Dilivar.
I would not recommend that anyone use them ( in fact it's crazy) but I will sell as many as you want for $ 5/ea.
Henry Schmidt
Ph: 760-728-3062
Old 04-05-2013, 10:29 AM
Straight shooter
Lapkritis's Avatar
Halves worth $2.50?
Old 04-05-2013, 11:24 AM
Puny Bird
Mark Henry's Avatar
Originally Posted by Lapkritis View Post
Halves worth $2.50?
I'm sure Henry will toss in a few for free if you buy a set of old Dilivar studs.
Old 04-05-2013, 11:34 AM
Still up in the air. I am leaning toward reusing the ones in the block, provided they are still holding up.
First step for me is starting the teardown and inspect them further, see if I can make it to the goal of removing the heads without breaking any.
I'll post an update in a bit.
Old 04-05-2013, 03:30 PM
At a minimum, you should replace your lower (exhaust) head studs with steel studs. The lower Dilivar studs ALWAYS break due to corrosion cracking. If yours are still in one piece, consider yourself lucky.
PM me if you are interested in a set of lower steel studs.
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 04-05-2013, 03:49 PM
Straight shooter
Lapkritis's Avatar
Host has the lowers for $14ea in Steel by Canyon...
Pelican Parts - Automotive Parts and Accessories - Porsche & BMW
Old 04-05-2013, 04:42 PM
With all the talk about cylinder expansion rates, I wonder if it ever makes sense to run dissimilar studs on the same engine?
The 78-83 experiment with dissimilar materials was abandon in 84 and never revisited by Porsche. Just like the engine builders in the real world, Porsche engineers learned something.
No matter what studs are chosen, they should all be the same. Now the only question is, are there studs that offer superior characteristics?
Henry Schmidt
Ph: 760-728-3062
Old 04-06-2013, 05:06 AM
Henry,
I absolutely agree - completely crackers and having been involved in hot gas turbine test stands for years I find the concept of mismatched expansion rates of studs bewildering.
There must be all sorts of ugly 'out of round' issues to worry about and it can't help the longevity of integrity of the CE Ring.
Old 04-06-2013, 05:50 AM
