Head Studs
If I remove the heads from my 85 with 90K is it recommended that I go a few steps further and replace the head studs with new ones? Are there any others to consider, or is genuine the best bet?
I appreciate the feedback. -matt |
Although seemingly not as frequent as with SC's, Carrera head studs do sometimes break. On my recent rebuild I used Supertec head studs which are phenomenal quality and not that much more than stock steel studs (assuming you would use new nuts and washers).
In your case I would definitely consider it. |
Standard practice for these engines is to replace the lower (exhaust) Dilivar studs with steel studs. Steel studs do not break in street motors.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
Try not, Do or Do not
The 911SC had more head stud problems (IE: breaking) then any other Porsche engine.
They were the first production engine equipped with Dilivar and they only used them on the bottom row making the clamping force on the cylinder to head joint incredibly uneven. Throw the Dilivar studs away and seek another solution. Of course I think Supertec studs are the best but I advise you to do your own research and come to a conclusion the fit your sensibilities including budget.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Puny Bird
I just ordered your studs from here and they are back-ordered?
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
For some reason, the supply of our material with certs is in short supply. Our studs will be available in about two weeks.
Do people consider the head studs to be single use? Or are they only replaced when broken?
Puny Bird
I was hoping to get it sent to my US buddy in time for hershey, but I'll just have to wait till he comes up to my place in June.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
I ordered a set of Henrys awesome studs too a few days ago, back ordered.
![]() I'm a bit annoyed with Pelican for claiming to have 1 set in stock, when they don't....
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Ingenieur
If you are not going to reuse your lower studs I will by them. They are reusable and I think they are a better solution. PM me if you want to sell them.
Straight shooter
Yes, replace all. Plenty of decent replacement options.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
I would not recommend that anyone use them ( in fact it's crazy) but I will sell as many as you want for $ 5/ea.
Straight shooter
Halves worth $2.50?
Puny Bird
I'm sure Henry will toss in a few for free if you buy a set of old Dilivar studs.
Still up in the air. I am leaning toward reusing the ones in the block, provided they are still holding up.
First step for me is starting the teardown and inspect them further, see if I can make it to the goal of removing the heads without breaking any. I'll post an update in a bit. |
At a minimum, you should replace your lower (exhaust) head studs with steel studs. The lower Dilivar studs ALWAYS break due to corrosion cracking. If yours are still in one piece, consider yourself lucky.
PM me if you are interested in a set of lower steel studs.
Straight shooter
Host has the lowers for $14ea in Steel by Canyon...
Pelican Parts - Automotive Parts and Accessories - Porsche & BMW
With all the talk about cylinder expansion rates, I wonder if it ever makes sense to run dissimilar studs on the same engine?
The 78-83 experiment with dissimilar materials was abandon in 84 and never revisited by Porsche. Just like the engine builders in the real world, Porsche engineers learned something. No matter what studs are chosen, they should all be the same. Now the only question is, are there studs that offer superior characteristics?
I absolutely agree - completely crackers and having been involved in hot gas turbine test stands for years I find the concept of mismatched expansion rates of studs bewildering. There must be all sorts of ugly 'out of round' issues to worry about and it can't help the longevity of integrity of the CE Ring. |
