fred cook's Avatar
Most difficult engine building job........
Just curious, what do you guys see as the most difficult job when rebuilding a 911 engine? Assembling the block? Compressing piston rings to assemble pistons to cylinders? Assembling the heads? Cam timing? Or???
My personal choice would be installing the second piston pin circlip! Getting those strong clips to compress into place while working among the cylinder head studs is a real pain! Most likely, there is an assembly trick that I don't know!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 08-25-2013, 02:11 PM
E Sully's Avatar
I totaly agree on those damm circlips. There is a method to simplify it, maybe I'll try it on the next build. I am also going to worry more about the oil pump o rings after reading a couple of threads lately.
Ed
1973.5 T
Old 08-25-2013, 02:37 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Using the Supertec head studs allows you the put the pistons in the cylinders on the bench, install the wrist pin on the rod, then install the head studs.
Crazy easy compared to all other methods.
CIRCLIP INJECTOR™
m,
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-25-2013, 02:57 PM
Kartoffelkopf
Spenny_b's Avatar
Made myself one of those circlip injectors, did make life easier, for sure!
My vote goes to cam timing...not difficult, but ain't half fiddly, and frankly, tedious
Another one would be getting the head studs out - cue the back-bottom-puckering for a newbie. Was a job I was dreading, but after growing a pair and finding the knack, they all came out nicely - even got into a bit of a rhythm after 2 or 3.
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 08-25-2013, 03:47 PM
When I m doing a stud replacement I ll leave the bottom studs out until the clips are in on the pistons. That gives me more room to use needle nose or circlip injector which actually needs the shock of a small hammer to complete installation.
Bruce
Old 08-25-2013, 04:02 PM
Free minder
Aurel's Avatar
Measuring the cam sprockets alignment is pain in the butt. I had 1 mm difference and removed two shims, mesured again and still had 1mm difference. I ended up leaving the same number of shims it came with originally. It worked then and should work now, since I did not make any changes in the cam towers.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 08-25-2013, 04:35 PM
roadster49's Avatar
I am now able to do circlips by hand and used the Stomski alignment tool on the sprockets. I too found the number of shims remained the same.
But I am really struggling with cam timing on my 83 SC.
Old 08-25-2013, 05:03 PM
I found that putting the 2 case halves together without screwing something up is really hard. Everything else is easy.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 08-25-2013, 05:35 PM
Cleaning everything after disassembly is the worst.
Current: 914/6 GT Conversion, Cayman
Old: Many PCars + Formula Racecars
Old 08-25-2013, 08:06 PM
Kartoffelkopf
Spenny_b's Avatar
Probably the single most difficult job of rebuild?...........
.....paying for it
Old 08-26-2013, 02:55 AM
thumbdoctor's Avatar
Having unrecognizable parts drop into the catch tub the moment the halves split. I was called to help a guy who found seven 8mm ball bearings in the tub and had no idea where they came from.
Old 08-26-2013, 04:52 AM
KTL KTL is offline
Schleprock
KTL's Avatar
I'm in agreement with you. Some engines are shamefully filthy. Not to mention over-use of sealant (or use of the wrong sealant like Permatex bloo RTV) makes things even worse. It also gets worse when you've had bearing failure!
Kevin L
'86 Carrera "Larry"
Old 08-26-2013, 07:32 AM
docrodg's Avatar
Seeing what stupid damage motormeister did on a previous rebuild is the worst.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 08-26-2013, 08:47 AM
dtw dtw is offline
GAFB
Fiddling with wrist pin clips is the biggest PITA to me, and usually results in puncture wounds, bleeding, swearing, and reaching for the extra clips I ordered.
Cleaning the grooves in the rocker shafts...all 24 of them...is mind-numbing.
Scrubbing & polishing the through-bolt bores and all of the other bosses & bores in the case of plaque and hardened sealant from the last build takes hours and uses up lots of handgun & rifle cleaning supplies.
Cleaning mating surfaces - nope, I discovered Roloc discs - life is good on this task now.
Re-seating the timing chains when they fall off the intermediate shaft sprockets before you have installed the cam sprockets - infuriating.
Fishing a Woodrfuff key out of the sealed block after it disappeared down the timing chain openings - without tearing the block apart again - brink of insanity (but I got it out after 3 days of fiddling!)
Several BMWs
Old 08-26-2013, 10:26 AM
Agree that cleaning is the absolute worst. Cam sprocket alignment gave me the most trouble until I bought the Stomski tool, then it was a breeze.
Old 08-26-2013, 01:14 PM
Straight shooter
Lapkritis's Avatar
DIY trick for under $20:
Specific Question - ARP Head Studs on 2.7 Magnesium case - Insane?
Personally, the most difficult as in the greatest pita with my top-end and p/c replacement job was the cam timing. It took me awhile to get them to match... and I did the job a few times over because the back plate seals pooped out and KTL was nice enough to recommend I double-check them.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 08-26-2013, 04:51 PM
Smoove1010
Smoove1010's Avatar
Add me to the list of those who found cleaning to be the toughest part. There's nothing particularly tricky about it, but it was the most labor-intensive and by far the messiest part of the project. A few of the other tasks were a little fiddly. Cam timing would've been easier if I installed all the rockers before attempting it. I did a practice cam-timing run prior to disassembly with all rockers in place, and nailed it on the first try on each side. Both sides were outside the window, probably due to chain wear.
Old 08-26-2013, 06:19 PM
PFM PFM is offline
PFM
PFM's Avatar
Add me to the list on cleaning.....
Stay Tuned,
PFM
Old 08-26-2013, 07:14 PM
johnman001's Avatar
My opinion of the most difficult part of a rebuild is CLEANING and KEEPING EVERYTHING CLEAN. I clean things, send them out and have to re-clean them upon return AGAIN.
Sure the piston pin circlips are a pain in my thumbs, but I can do them much more quickly than I can clean even simple parts. My final cleaning is with lint free wipes and alcohol until the wipes are cleaner than when pulled out of the package.
My experience is that DIRT is the enemy and can be the cause of premature wear and leaks. Then again I firmly believe that haste makes waste.
John Flesburg
2016 981 Boxster S.................| 1983 911 Turbo - (White)
1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver)
1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?)
1971 914 (TBD)..................... |
Old 08-26-2013, 07:17 PM
KTL KTL is offline
Schleprock
KTL's Avatar
This is a very good point. Don't trust your parts that have been sent out for service/reconditioning to be suitably clean & ready reinstallation. Clean them again!
I had a set of rods rebuilt and neglected to take them apart and re-clean. When assembling one of the rods, I found the rod bolt felt "rough" when tightening. These rods are Pauter brand with bolts that thread into the rod body- no nuts. So you are tightening just the head.
Removed the offending bolt and found some grit around the shank of the bolt under the head. Leftover crud from the machine work. So I took all the rods and went thru them. Found more crud on others as well. Shame on me.
Kevin L
'86 Carrera "Larry"
Old 08-27-2013, 06:32 AM
