B&B Header - Oil Tank S-Hose Problem Resolved
Bought the Billy Boat (B&B) oil line and installed it today: Anyone have a solution tank to cooler line with B&B Headers?
Should be ready to dump 10 quarts of non-detergent oil in the tank tomorrow, crank for a bit and then see if it fires off. Gordo
Don "Gordo" Gordon '83 911SC Targa |
83 911 Production Cab #10
as in crank a bit without the DFU plug in to see the oil pressure build up and then fires her up.
I'm sure that is what you mean but having just received a Supercharger that some run without oil in the reservoir... and know a friend with a the $10,000 paper towel story, just want to make sure.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
What happened here, who pulled the plug?
cheers, Phil 84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies. |
Happy Ending
Build was complete - moved onto stuff like starting:
Gordo's 3.2L Engine Rebuild - It's Alive PMO carb tuning: Gordo's PMO Carb Tuning And driving ![]() Gordo
Good on you mate. Really enjoyed your doco and I'm sure it will come in handy with my upcoming maiden engine drop.
PCA Member since 1988
I'm also surprised that the torque for rods 1 and 5 was that much lower than the others for the same stretch. I would have tightened and loosened them a couple times, with the ARP-supplied lubricant to make sure I didn't get a mis-measurement.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
One thing that I have noticed when using ARP rod bolts/studs, you need to torque/untorque them multiple times before you tighten them for the final. I think I read somewhere in a ARP documentation they call that cycle burnish or work-harden the threads. During my last build (3.4 turbo) I have noticed a couple of them needed to be cycled 4 or 5 times before I got a good stretch. Also I have noticed after testing a few stretch gauges that the only consistent and accurate one is the ARP gauge. the worst one was from Lunati, values were all over the place.
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management. -1987 Carrera Coupe. -2013 Carrera S PDK Coupe, factory Aero Kit. My DD. -1987 928S4. |
Rod Bolt Stretch
Few years later, still roaring.
All good recommendations - ultimately a matter of having reasonably good tools and a sound approach. Thanks for bringing this back to life, Gordo
Genuine question and observation here:
With ARP rod bolts, how does everyone else keep track of their starting lengths? I usually measure all 12 ,and then try to pair them up so they are matching lengths. I have seen variances within a set of bolts by up to 5 or 6 thou.. Usually I can get 4 or 5 pair that are the same as each other, so when tightening them, I can easily keep track of how much each bolt has been stretched.. but there are usually 1 or 2 pairs that are a few thou different from each other.. I mark on the rod which is "0" and the other is "=3" or "=2" etc.. Wondering if there is a better way to do it?
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Bolt Measuring is a Gut Check
Hey gents - I addressed ARP stretch stuff on a separate thread discussion on stretch gauges (pro/con).
https://forums.pelicanparts.com/911-engine-rebuilding-forum/789996-summit-racing-rod-bolt-stretch-gauge-review.html Quote:
"I used a control bolt (point) as ZERO point" - which I understood as - one rod bolt was placed in the stretch gauge; the gauge was zero'd and then you measured the amount that each rod bolt stretched (as you torqued them) as compared to your original rod bolt. In other words, you used one bolt as a standard and based the stretch length on this one bolt. Not saying this is wrong; just confirming your process and basis for how you determined the amount of stretch per rod bolt. If I'm understanding correctly, my issue with this method was that I found the original rod bolts have slightly different lengths (as compared with both micrometer and when placed in my stretch gauge). As such each connecting rod bolt needed to be initially zero'd on the stretch gauge and then torqued/stretched to the ARP recommended spec." Looking back, I'm not even sure I know what I meant.
Don "Gordo" Gordon '83 911SC Targa Last edited by Gordo2; 12-05-2025 at 08:03 PM.. |
