Splitting the case question
I am a little nervous about splitting the case, it seems awfully stuck together. Would it make sense to turn the case so that the joint is vertical and then spray it with wd40, work it open that way? Or is it best to keep it so the joint is horizontal as though I am re-assembling it?
Any tips on what sort of tool to use to "gently" pry it open? Run a razor knife along the joint? very stiff metal putty knife?
thanks
Old 01-30-2014, 03:12 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
I would keep the cases in a horizontal position. WD is not likely to help as it is not corrosion that is holding them together but more likely the sealant. Make really sure you have all the cases bolts and nuts off. Two dome nuts in the cooler cavity and the nut in the chain case can get overlooked. There are some extended bosses on the cases near the part line that you can tap on with a urethane hammer to loosen the grip. Do not pry between the cases, it will do permanent damage to the sealing surface. Skip any brute force and go for patience and perseverance, they will win the day. Good luck
Old 01-30-2014, 03:56 PM
toddu's Avatar
And make sure all case hardware is off. There are 1 or 2 sneaky ones (e.g. - where engine mounted cooler comes off).
Todd
(sorry, looks like I'm repeating previous post)
'81 SC
Old 01-30-2014, 04:13 PM
Thanks guys!
i will continue to tap away…...
Old 01-30-2014, 04:23 PM
Make sure you have the nut or two that face the opposite side on center line bottom and the one under the fan by itself.
The 17mm inside the left chain cavity.
Bruce
Old 01-30-2014, 04:49 PM
Try not, Do or Do not
Henry Schmidt's Avatar
When you're certain all the nuts and bolts holding the case together are removed, leave the engine in an upright position and smack on the engine stand. The impact will break the glue and the case will start to separate.
If you feel bad about bruising your engine stand, it's time to turn in your man card...lol
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-30-2014, 04:57 PM
Case
+1 on Henry's comment. Just did mine and it worked like a charm.
Old 01-30-2014, 07:58 PM
toddu's Avatar
Wish the yokes weren't $200+. :-)
Todd
'81 SC
Old 01-30-2014, 08:14 PM
0396's Avatar
Man card....what a way to start the day with a big smile. Thanks for the info. Best
Old 01-31-2014, 09:17 AM
What's the point if you can't help a fellow enthusiast and why not chuckle a little along the way.
Henry Schmidt
Ph: 760-728-3062
Old 01-31-2014, 10:38 AM
I had one once that was glued together. I had to run a MAP gas torch around the perimeter to melt the glue before the case would split.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 01-31-2014, 05:11 PM
2 lb. Brass Hammer with Hickory Handle
Harbor Freight brass hammers are pretty good and on sale.
Mine will never have the experience and stories to tell that Henry's has
Old 01-31-2014, 05:18 PM
beancounter
jwasbury's Avatar
Sometimes the case is really stuck together and you need to take a different approach. This is what I had to deal with, and my solutions to the problem:
My case does not want to separate
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 02-01-2014, 05:08 AM
Well done Jacob,
I especially liked the case splitting tools of yours and the other poster. Engineering often triumphs over BFH as I tried (unsuccessfully) to convince some of my lead drillers in the GOM. I'll be keeping them in mind.
Mick
Old 02-01-2014, 10:01 AM
irobertson's Avatar
While a tad unorthodox, this worked very well for me. I was just planning on putting a little stress on it then tapping with a hammer, but it just opened right up with surprisingly little force.
'88 sunroof delete Coupe in Venetian Blue (back on the road Wooo!)
'11 Cayenne Manual, as in it has a clutch :-) (daily driver)
'97 BMW Z3 (wife's ride)
Old 02-02-2014, 02:18 PM
AlfonsoR's Avatar
I would worry about putting too much of a side load on those long studs and possibly break the case.
I really like David's idea
That tool, plus a rubber mallet and maybe throw a little heat on top of that and you should be able to split almost any case.
"Simplicity is supreme excellence" - James Watt
Old 02-02-2014, 10:07 PM
SCadaddle's Avatar
Non technical humor to follow:
I've got The Maestros' aka the Late Great Harry Pellow 356 engine disassembly/rebuild VHS tapes, all 6 of them, and in one episode Harry is going to split a 356 engine case with a BFH and a 2X4. He starts with light tapping and ends up just beating the hell out of the 2X4 to the point it splits into pieces flying across the room before the case is split. Rewinding the video he is hitting the case half mounted to the engine stand......then finally in the closing video he is running the newly rebuilt engine and begins to hear a loud squealing sound...he's checking the fan belt, the fan housing, all the usual suspects and finally shutting the engine down he realizes it is the smoke detector in his shop. Classic stuff!
Old 02-03-2014, 07:58 PM
AlfonsoR's Avatar
"VHS" - what is that? Ha ha. Yes, classic stuff. :-)
Old 02-04-2014, 03:33 AM
irobertson's Avatar
Agreed, you could easily damage things with the jack setup. I was only trying to preload things a bit, then give it a couple of taps. I got the jack snug between the wrenches and gave it one pump and the case separated. I barely felt any resistance, so I guess my case wasn't as stuck as I thought.
I do really like David's fabricated tool as well.
Old 02-04-2014, 06:58 AM
304065's Avatar
I nominate this hammer as the "Pelican Cudgel of the Year" for 2014
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 02-04-2014, 10:12 AM
