LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
930/66's Avatar
Assembling Oil Temperature Regulator
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods
Old 08-09-2014, 01:57 AM
930/66's Avatar
Vent Cover
Old 08-09-2014, 02:02 AM
930/66's Avatar
Assembling New Turbocharger Oil Feed Line Set from TurboKraft
Old 08-09-2014, 02:06 AM
930/66's Avatar
Installing Air Guide Plates
Old 08-09-2014, 02:52 AM
930/66's Avatar
Assembling Zylinder Heads
Old 08-09-2014, 02:55 AM
930/66's Avatar
Assembling Zylinder Heads and Camshaft Housing
Old 08-09-2014, 03:00 AM
930/66's Avatar
Preparation Chain Housing / Assembling
Befor Assembling the Chain Housing i have to preparation it.
The Sealing Kit from Supertec has everything you need!
Old 08-10-2014, 02:53 AM
930/66's Avatar
Assembling 964 Camshaft and End Cover
Old 08-10-2014, 02:56 AM
930/66's Avatar
Installing Camshaft Sprocket
Old 08-10-2014, 02:58 AM
930/66's Avatar
Installing Patrick Motorsport RSR Flyweel
Old 08-10-2014, 03:09 AM
930/66's Avatar
Installing D-Zug Pulley
Old 08-10-2014, 03:11 AM
930/66's Avatar
Checking Parallel of Sprockets with Stromski Racing Tool
I Think for a DIY is the Tool from Stromski Racing helpful
Old 08-10-2014, 03:15 AM
930/66's Avatar
Installing End Cover for Intermedia Shaft
Old 08-10-2014, 03:27 AM
930/66's Avatar
Installing Chain on Sprockets an fix it with the Chain Sprocket Holder
Old 08-10-2014, 03:33 AM
Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
It's on my bucket list to rebuild a Porsche engine. This seems so complicated, and beautiful at the same time. Fantastic job.
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 08-12-2014, 01:52 AM
Great attention to detail on the build, and well-lit photography.
I remember when those 3.4 cylinders came up for sale and I started daydreaming about picking them up. Glad they went to such a fine home!
Ken
Ken
1986 930 2016 R1200RS
Old 08-12-2014, 01:31 PM
930/66's Avatar
the conversation from 3.3 to 3.4 was many jears in my Head!
Old 08-14-2014, 01:26 PM
930/66's Avatar
Ken
Hi Ken
Thanks for your kind words!
Old 08-14-2014, 01:33 PM
930/66's Avatar
Installing Rocker Arm with new Rocker Arm Shaft
Installing Rocker Arm (with new bushings) and new Rocker Arm Shaft.
I also ordered the Rocker Shaft Lock Set and the Rocker Shaft Seal Set : Porsche Motorsport from Chris TurboKraft.
Bolts from the Rocker Shaft and some Adjusting screw and nuts are also new.
Old 08-16-2014, 09:39 AM
930/66's Avatar
Assembling Rocker Arms in the Camshaft Housing
Old 08-16-2014, 09:49 AM
