Another 930 Engine Conversion
This conversion report is a good possibility to introduce myself and my Car.
I drive the car for 14 years it`s black / black with RUF Wheels It`s a 87-er. 930 with 4-Speed Transmission before beginning the conversion was all original. It`s not the first conversion and rebuilding on this Car, but now i start from zero. The Transmission I have revised five years ago and the Suspension 2 years ago. Some pictures of the Car: ![]() ![]() My Parts List: Mahle P/C 3.4 7.5:1 964 Cams Intercooler Longneck from Turbokraft Tial Wastegate Headers with heat port size 38mm from Rarly8 Turbocharger K27/29 from Rarly8 Oil feed line from Turbokraft CIS Injector Blocks port size 36mm from Turbokraft Rocker Shaft Set from Turbokraft Rocker Shaft Seal Set from Turbokraft Flyweel Clutch Set from Patrick Motorsport Supertec Head Studs and Engine Seal Kit High Torque Starter D-Zug 935 Style Crankshaft Pulley Zeitronics ZT-II and a long List of Parts from Pelicanparts ![]() The modifications I will describe during the report...
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods Last edited by 930/66; 07-11-2014 at 11:21 PM.. |
engine removal
![]() Helpful Tool from a Friend: ![]() ![]()
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods |
Very cool posting! Will be following with great interest... GOOD LUCK!
Sources of Information
Thanks Joe
I have used various sources of information: ![]() ![]() ![]() I also used my Porsche Service Manuels and not to forget the help of porsche friends.
before I had the motor removed I always expand the heat exchangers, Intercooler and airfilter box.
![]() generally ran the motor without problems with little oil leaks ![]() ![]() start with strip down the engine ![]() ![]() ![]()
Strip down
![]() ![]() Good old 3LDZ ![]() ![]() another Oil leak left side ![]()
more pictures
Clutch and Flyweel removing
last change of the Clutch is 45t Miles ago (with about 413 Pound Force on the Crank)
Tensioner, Camshaft sprocket, Chain Housing Removal
Chain Housing left Side
![]() ![]() camshaft sprocket flange ![]() endplate ![]() left chain housing ![]() ![]()
Rocker Arm, Camshaft Removal
remove all rocker arm and shaft components no oil leak at all
![]() some wear ![]() ![]() ![]() ![]() remove camshaft from housing ![]() ![]()
Camshaft Housing / Heads Removal
Hi swiss fellow
![]() Nice, keep going with a lot of pics. BTW your thread is listed in the Pelican newsletter, congratulations
Roland 930 Turbo '81 Too many modifications to list |
Subscribed!
Rennch on YouTube
Always interested in this, as I've never rebuilt an engine before. #bucketlist
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
Thanks for all the pictures! I know you always have to remember to grab the camera instead of loosening that next fastener.
Good luck, will be watching as you go through this. Keith |
Those pics bring back memories to me. Best of luck with your rebuild!
Eric
'82 SC 3.0L Targa, Chiffon/Brown “It all began when I was looking around but couldn’t find the car of my dreams anywhere. So I decided to build it myself.” - Ferry Porsche |
Excellent work. Looking forward to updates
believe me there are many more pictures ![]() I have see it in the newsletter i love this section: And check out his home-made engine and transmission stand! he is really practical for working, the angle can be easily adjusted for removing and installing
@all
Thank you Folks working and make some pictures are not always so easy... need some more time. For the assembling for me as a DIY it`s a good help
Removing Air Guide Plates / Piston Cylinders /Dilavar Studs
air guide plates
![]() ![]() removing pistons and cylinders ![]() ![]() ![]() ![]() dilavar studs / just 2 off 24 have make some problems (heating the loctite helps) just with 2 nuts an 2 wrench ![]() ![]() ![]() ![]()
