930/66's Avatar
Another 930 Engine Conversion
This conversion report is a good possibility to introduce myself and my Car.
I drive the car for 14 years it`s black / black with RUF Wheels
It`s a 87-er. 930 with 4-Speed Transmission before beginning the conversion was all original.
It`s not the first conversion and rebuilding on this Car, but now i start from zero.
The Transmission I have revised five years ago and the Suspension 2 years ago.
Some pictures of the Car:
My Parts List:
Mahle P/C 3.4 7.5:1
964 Cams
Intercooler Longneck from Turbokraft
Tial Wastegate
Headers with heat port size 38mm from Rarly8
Turbocharger K27/29 from Rarly8
Oil feed line from Turbokraft
CIS Injector Blocks port size 36mm from Turbokraft
Rocker Shaft Set from Turbokraft
Rocker Shaft Seal Set from Turbokraft
Flyweel Clutch Set from Patrick Motorsport
Supertec Head Studs and Engine Seal Kit
High Torque Starter
D-Zug 935 Style Crankshaft Pulley
Zeitronics ZT-II
and a long List of Parts from Pelicanparts
The modifications I will describe during the report...
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods
Old 07-07-2014, 11:42 AM
930/66's Avatar
engine removal
Helpful Tool from a Friend:
Old 07-07-2014, 11:55 AM
Very cool posting! Will be following with great interest... GOOD LUCK!
Old 07-08-2014, 06:07 AM
930/66's Avatar
Sources of Information
Thanks Joe
I have used various sources of information:
I also used my Porsche Service Manuels and not to forget the help of porsche friends.
Old 07-08-2014, 08:29 AM
930/66's Avatar
before I had the motor removed I always expand the heat exchangers, Intercooler and airfilter box.
generally ran the motor without problems with little oil leaks
start with strip down the engine
Old 07-08-2014, 09:05 AM
930/66's Avatar
Strip down
Good old 3LDZ
another Oil leak left side
Old 07-08-2014, 11:05 AM
930/66's Avatar
more pictures
Old 07-08-2014, 11:19 AM
930/66's Avatar
Clutch and Flyweel removing
last change of the Clutch is 45t Miles ago (with about 413 Pound Force on the Crank)
Old 07-08-2014, 11:41 AM
930/66's Avatar
Tensioner, Camshaft sprocket, Chain Housing Removal
Chain Housing left Side
camshaft sprocket flange
endplate
left chain housing
Old 07-09-2014, 09:40 AM
930/66's Avatar
Rocker Arm, Camshaft Removal
remove all rocker arm and shaft components no oil leak at all
some wear
remove camshaft from housing
Old 07-09-2014, 10:58 AM
930/66's Avatar
Camshaft Housing / Heads Removal
Old 07-09-2014, 11:21 AM
proffighter's Avatar
Hi swiss fellow
Nice, keep going with a lot of pics.
BTW your thread is listed in the Pelican newsletter, congratulations
Roland
930 Turbo '81 Too many modifications to list
Old 07-09-2014, 03:16 PM
DSM DSM is offline
DSM's Avatar
Subscribed!
Old 07-09-2014, 04:02 PM
Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Always interested in this, as I've never rebuilt an engine before. #bucketlist
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 07-09-2014, 04:42 PM
Strygaldwir's Avatar
Thanks for all the pictures! I know you always have to remember to grab the camera instead of loosening that next fastener.
Good luck, will be watching as you go through this.
Keith
Old 07-09-2014, 05:08 PM
SchnellSchweitz's Avatar
Those pics bring back memories to me. Best of luck with your rebuild!
Eric
'82 SC 3.0L Targa, Chiffon/Brown
“It all began when I was looking around but couldn’t find the car of my dreams anywhere. So I decided to build it myself.” - Ferry Porsche
Old 07-09-2014, 06:36 PM
Excellent work. Looking forward to updates
Old 07-10-2014, 02:12 AM
930/66's Avatar
Originally Posted by proffighter View Post
Hi swiss fellow
Hi Roland
believe me there are many more pictures
I have see it in the newsletter i love this section:
And check out his home-made engine and transmission stand!
he is really practical for working, the angle can be easily adjusted for removing and installing
Old 07-10-2014, 08:14 AM
930/66's Avatar
@all
Thank you Folks
working and make some pictures are not always so easy... need some more time.
For the assembling for me as a DIY it`s a good help
Old 07-10-2014, 08:24 AM
930/66's Avatar
Removing Air Guide Plates / Piston Cylinders /Dilavar Studs
air guide plates
removing pistons and cylinders
dilavar studs / just 2 off 24 have make some problems (heating the loctite helps)
just with 2 nuts an 2 wrench
Old 07-10-2014, 08:50 AM
