LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
930/66's Avatar
Rarly8 Headers Change Silikon hoses to Aluflex
The Silikon hoses with the heat insulation tape was not mine.
I have made an aluminum adapter for the Aluflex.
but first comes the 3ldz out
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods
Old 01-17-2015, 06:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #141 (permalink)
930/66's Avatar
Adapter for Heater Box (new all in Black)
New Paint in black with Adapter
New K27/29
Old 01-24-2015, 02:22 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #142 (permalink)
proffighter's Avatar
Even if I prefer raw, black looks beautiful. Nice work!
Roland
930 Turbo '81 Too many modifications to list
Old 01-24-2015, 02:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #143 (permalink)
930/66's Avatar
Thanks Roland
Old 01-24-2015, 10:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #144 (permalink)
930/66's Avatar
New Aluflex Tubes
I like the Aluflex vs Silikon Tubes (with heat Tape)
Old 01-24-2015, 10:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #145 (permalink)
930/66's Avatar
Modification Air Filter Box
I still had problems with the fitting between the TK intercooler and the Air Filter Box.
Again i cut some Piece out and fix it together.
Old 01-24-2015, 11:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #146 (permalink)
930/66's Avatar
First Drive with the New K27/29
The First Drive with the "new K27/29" was good, no Problems.
The difference of the different exhaust turbine is very noticeable.
I have the Data from Zeitronics as the compressor nut coming loose (3.Gear)
Old 01-26-2015, 10:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #147 (permalink)
930/66's Avatar
Current AFR Results
My current AFR results looks not to bad.
I must do test runs at maximum speed and full boost to see this afr situation.
First i recheck all pressure from the CIS and make a flow testing from the injektors.
Old 01-26-2015, 10:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #148 (permalink)
Do you have a design or a build sheet for your engine/tranny rest? I'd love to make something similar for when I need to drop the tranny and motor.
~Andy
Originally Posted by 930/66 View Post
Helpful Tool from a Friend:
1983 Porsche 911SC Blk/Blk
1956 Ford F1 - Patina
2013 Toyota Tundra 4x4 5.7
2013 Honda Pilot
Old 02-01-2015, 04:03 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #149 (permalink)
AFR of 14.1 - 14.2? Too lean. That is with no boost and low rpm but no room for error there.
Old 02-01-2015, 04:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #150 (permalink)
930/66's Avatar
Hi Andy
I'm sorry I do not have a plan of the design or a build sheet. My Friend has it continuously constructed by hes engine build.
The base is a motorcycle hydraulic ramp.
Thomas
Old 02-02-2015, 11:22 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #151 (permalink)
930/66's Avatar
In the first diagram you can take the values on the right side / compressor nut coming loose (3.Gear)
In the second and third diagram you must take the values from the vertikal line..
for example:
Idle 4531 / Boost 099 Bar / AFR 12.4
Old 02-02-2015, 11:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #152 (permalink)
Got it, looks good. So over about how much time does the 3rd graph cover? You've convinced me to get a Zeitronix for my build. It's cheap compared to dyno time for tuning.
Old 02-03-2015, 02:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #153 (permalink)
FAST test saves lives
black pipes
I agree... the black pipe work looks ace :-)
Old 02-03-2015, 03:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #154 (permalink)
930/66's Avatar
The 3rd gear covers 3 second on the graph 0 Bar Bost to 1.03 Bar
Yes i think the Zeitronics is a god solution (i have the little Blackbox) it helps, but a dyno is a must for me in the final.
Old 02-05-2015, 11:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #155 (permalink)
Subscribed
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 02-05-2015, 07:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #156 (permalink)
Having a similar problem with my k27HFS. I will look into the same methods of testing as well. I do not have a turbo to swap out though. Thank you for such a detailed build. Nice work.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 02-06-2015, 04:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #157 (permalink)
930/66's Avatar
Any news about your problem with the k27HFS?
Thank you for your kind words!
Old 02-10-2015, 08:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #158 (permalink)
930/66's Avatar
CIS Testing
CIS Test:
System pressure was too low:
I have ordered a new system pressure regulator to fix the Problem
Old 02-21-2015, 07:06 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #159 (permalink)
930/66's Avatar
Installing Fuel Pressure Regulator and Damper
I have also ordered the Fuel Pressure Diaphragm Damper (was installed in the 930/66 S)
New Parts:
Old 02-21-2015, 07:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #160 (permalink)
