It's a trap...
It's too bad that has to go in a car and get dirty. Noyce.
Run like the wind, straining the limits of machine and man.... 2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys). |
That pump is beautiful. I see there's an added (?) strut - are the pumps known to torque over?
David 1972 911T/S MFI Survivor |
Straight shooter
I don't want to steal Henry's thunder but I believe the strut is more of an insurance policy to lessen vibration and keep those aluminum mounting ears intact at the base. Aluminum does fatigue and a lot of these parts have plenty of cycles on them by now.
____ Cool find Henry - thanks for sharing. Not sure why folks are voting this down as you won't likely see another any time soon. I was remarking to the wife the other day about the cost of stamps when I found and removed a half dozen of these boxes (also unused) stuffed into the wall behind the dishwasher in our old farmhouse. "Free" insulation! About the CAD/CAD II/Zinc plating process - I was curious about your input on when and where to use it. I understand fastener coating technology has improved since these engines were built but from an appearance standpoint there is a desire for close to original as possible so the newer greenish coatings are out. The average DIY can get their hands on kits to do some CAD/Zinc coating in the garage which really adds a nice bling factor to a solid build. But like Lund accessories on a Chevy pickup, there must be a point when you've gone too far... when you've "Lunded out" as they used to say. I agree once you start on the visible hardware, it makes sense to have it all match. I noticed the threads weren't plated on the through bolts and the neck of one pictured doesn't appear to be coated either. Is there a reason to not coat the threads or has the coating worn through from pre-assembly activities such as checking bearing clearance? Items intended to wear in an oil bath I haven't observed as normally coated (excluding softer anti-friction coatings for bearings/pistons by 3M etc) because they would quickly shed the layer of metallic plating. Is the sprocket on the right just a chain holder that was laying around the shop or was it installed during the build? I look forward to more pics/updates. Appears it ended as a twin plug from the after pictures so there must be trick head work to share still.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Try not, Do or Do not
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 06-04-2015 at 09:26 AM.. |
Crusty Conservative
Henry,
Am I correct in thinking you will have a closed oil system for the pump that is not connected to engine oiling system. I recall seeing that first on one of your builds. Really top shelf work by the way. Thanks for sharing.
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
Thanks!
And BTW, great shot through the stacks!!
We discovered 20+ years ago that the engine oil would super-heat the pump. With the exception of a possible improvement on hot restart the heat had no other benefit. By isolating the pump we could insure the quality of the pump oil and isolate the engine from any possible fuel contamination of the oil. The engine runs a Supertec cold start device making the thermostat obsolete. Our cold start device is controlled by the driver via a small level next the the hand brake. ![]() If you choose to seal your pump it is important to remember that as the engine heats up, pressure will build inside the pump forcing the oil passed the seals and gaskets. To relieve this pressure we designed a neat little breather that double as a filler for pump oil. The breather is also a little filter. This breather will retrofit to any Bosch MFI pump. ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
What a unique build. Thanks for sharing
Henry |
Absolutely beautiful engine build.
'71 914-6 #0372 '17 Macan GTS |
Crusty Conservative
The best toy in the best Toy Store... Thanks for making us all crazy, Henry. You are an artist..
very nice as usual henry...)) btw, who's headers & do you have a pic of the muffler you will be using...? I live for pics like this from henry...)))) just por-fect...
I live for 911 tweaks... |
Beautiful work!
Current Project - http://forums.pelicanparts.com/paint-bodywork-discussion-forum/860107-mid-year-humane-society-76-re-fresh-4.html PCA Member, Early S Reg member, 356 Reg member. Instagram Jason Morski Current Rides: 76 911s 3.4 white/lobster hot rod, 2000 Boxster S Lapis Blue, 2005 Carrera S Riviera blue/pccb's, 13 Cayenne S, 2018 GT3 Lava Orange |
Cars and Cappuccino
I'm certainly no expert, but just wondering if this could have possibly been an IROC motor? I think they were 3.0 RS-based cars. The uniqueness of it would sort of make sense. From what I have researched, Roger Penske bought most of the IROC cars when Porsche ceased support of the series after the inaugural season. He then resold them to various race teams. Maybe Brumos bought one? Anyway, just a thought.
And BTW, beautiful build.
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
Schleprock
Fantastic stuff! I love the look of the finned lower valve covers.
Those Mahle pistons look to be really light. I see they were plunge-cut/milled under the crown all around the pin bosses Curious what size piston spray jets are used? Reason I ask is because I noticed the 964 oil pump.
Kevin L '86 Carrera "Larry" |
work of art
Henry
thanks for posting these photos, truly a modern masterpiece.
1975 911S Targa Silver Anniversary Edition |
SC squirter for under 260hp Turbo squirter up to about 350 964 for 300 to 400 hp There is an over-sided 964 squirter that is appropriate for higher heat engines.
