Try not, Do or Do not
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Schleprock
I think the oversized 964 squirter is the one that was used in the 993 twin turbo engine?
Kevin L '86 Carrera "Larry" |
Henry, I noticed you are running pressure fed tensioners on this engine. I assumed you weren't a fan of these as you prefer the 930 tensioner. What gives?
In the case the engine had relatively new Carrera tensionsers so reusing them seemed appropriate. Whenever possible, I'm a fan of reusing components that offer reasonable serviceability as long as they don't represent an unreasonable compromise to my build.
Under the radar
What cams are being used?
Dougherty Racing cams DC 62 with a 104 lobe center.
Fresh off the dyno. ![]() ![]() ![]()
As usual, you set the bar high Henry....nice build.
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Thanks Al and all the rest of my Pelican friends who leave such nice compliments.
I would rather be driving
Henry, Great Build as usual. Thank you for continually sharing your special projects with us.
I am curious why there is such a significant increase in torque with the air filters on. These look like ITG filters. As far as I know the top surface is filter material, not hard. I am just trying to figure out what causes the increase in output. Is this an effect of engine break-in from successive runs? What are your thoughts?
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Henry,
I enjoy reading your updates on what you are up to. Thank you very much. Very impressive build and numbers to match. Thanks, Paul
Thanks, Paul 1979 SC "A man of many projects and too many hobbies" |
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
