.Personally I never considered boring out my stock vents as they don't fit in a lathe well its just not that easy.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
I don't think it's automatic that mag cases need extensive machine work just because you split it for rebuild. Unless it has been exposed to significant heat (2.7 with reactors or racing) I wouldn't just assume it's automatically going to need a line bore Etc. Also, if you aren't building a high performance motor, the piston squirters and a lot of the race mods aren't necessary either. These 2.2 motors were pretty durable just the way they came out of the factory. It's when they stroked them to 2.4 and especially 2.7 when the cases started to be over stressed. I will give in to the oil bypass mod and case savers but those are pretty inexpensive.
70T 2.7RS spec. 68L coupe |
It's common enough for Dave to know it should at least be evaluated. Trying to reassemble a warped case is probably extremely exasperating and will undoubtedly leak like a sieve. Nothing I mentioned is considered a "race mod." Piston squirters were added in 1972 to even the lowly T model and is a desirable mod for a more bullet proof engine, not to make it rev higher...and it's fairly inexpensive. We certainly agree on the head studs.
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
True. Piston squirters are inexpensive as well. I suppose that alone would justify going ahead and getting it done. I guess my point was that more often than not, a 2.2 will come apart without warping. To me they get lumped in with the 2.7 motors that were exposed to much more heat.
Case/Piston squirters were added in the '71 model year. If you change cams don't forget about changing or altering your distibutor to match. You should have a Marelli for that "T" Try and find the proper Bosch 008 for the "T" cams or the 006 for the "E" cams and the 007 for the"S" cams.
Great input guys. Any idea where I can get the right distributor for "e" or "s" cams?
Post a wtb here. You should find one between $3-$400.
You can have your Marelli rebuilt and recurred to match your other modifications. Contact Kurt at Parts Klassic
Tom Butler 1973 RSR Clone 1970 911E 914-6 GT Recreation in Process |
