theiceman's Avatar
does the sump plate use regular washers or sealing washers ?
cant quite make it out in Waynes book .
my original setup on my 78 sc is looking like regular washer, spring washer regular nut. I was going to put on yellow zinc nyloc with a yellow zinc flat washer for that nice finished look but then wondered if I am supposed to be using some kind of aluminum sealing washer like the valve cover guides.
Thanks in advance.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 04-25-2016, 08:03 AM
Aluminum sealing washers.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-25-2016, 08:38 AM
theiceman's Avatar
Thanks Steve .
the project continues ......
Old 04-25-2016, 08:51 AM
prschmn's Avatar
The sealing washers aren't needed if the studs are loctited-they just prevent leakage past the threads. I'd say use whatever you think is prettiest-is that word?
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 04-25-2016, 07:10 PM
Try not, Do or Do not
Henry Schmidt's Avatar
We use a very thin coat of Curil T on both sides of both gaskets and large diameter steel washers.
The sealant prevents leakage and the larger washers prevent sump cover deformation.
Just another thought.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-26-2016, 04:04 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Get a box of nyloc flange nuts and make the nuts & washers one with each other.
Box of 50 yellow zinc class 10 (overkill) is $9 or a box of 100 white zinc class 8 is $5.37
Kevin L
'86 Carrera "Larry"
Old 04-28-2016, 07:26 AM
theiceman's Avatar
damn you guys .... if I only had one choice life would be easy
Old 04-30-2016, 07:24 PM
