jamesjedi's Avatar
Not a Rebuild - Just Rings
I have new rings in my early 964 engine - not a complete rebuild.
What is the procedure for seating the rings? Thanks.
Old 02-19-2017, 06:23 PM
Read "break in oil" just below.
Bruce
Old 02-19-2017, 08:26 PM
jamesjedi's Avatar
Thanks Bruce. I should do this:
"Vary the rpm with no full loads pulls & leakdown test after 500 miles." Yes, and do a leakdown before you first start it so you have a comparison."
Old 02-20-2017, 05:37 AM
jamesjedi's Avatar
Brad Penn? What grade?
Old 02-20-2017, 05:40 AM
Read about the 30 ND
Brad Penn won't seat, too slick
Bruce
Old 02-20-2017, 05:45 AM
jamesjedi's Avatar
It took a little bit to figure out what 30 ND was. Thanks Bruce!
Now I need to see which brand. Thanks again. I shall do some research.
Found this (66 pages); Break in oil- first 20 minutes- Brad Penn or standard non detergent
Does it mater what brand of SAE 30? I found a local supplier with these;
BRAD PENN HIGH PERF. GREEN SAE 30
NON DETERGENT SAE 30 KENDALL
Old 02-20-2017, 06:16 AM
Try not, Do or Do not
Henry Schmidt's Avatar
I am not a fan of Brad Penn or Kendall....too much paraffin content.
I like Valvoline 30 wt non-detergent (NAPA 30wt ND id the same) followed by Delo 400.... You choose the weight that meets your temperature requirements.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-20-2017, 10:43 AM
jamesjedi's Avatar
I cant say how much I appreciate the input from engine builders. Thanks!
Are you using that oil in your race cars and street cars? I understand if you do not want to answer. Thanks again.
Old 02-20-2017, 01:02 PM
We're mot running a race team right now so I can't answer that question intelligently. I like Delo and would use it (and do) in everything I own but with race cars there is always a question of sponsors and loyalties.
I also run Supertec SpeedLube in all my vehicles. I use Supertec assembly when assembling all our engines. These formulations we're specifically designed to replace ZDDP and fortify all types of metals subjected to the excessive heat seen in air-cooled engines.
We caution against using SpeedLube Bearing Life in a newly assembled engine.
Henry Schmidt
Ph: 760-728-3062
Old 02-21-2017, 07:36 AM
jamesjedi's Avatar
Thanks Henry. Always excellent to here from someone who does it for a living.
Old 02-21-2017, 09:06 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Caution, ND ( Non-Detergent ) is the key for break in. Read the label as NAPA also carries the Detergent added 30W as well.
Do a leak down to get a base reading and 500 miles later another, if good swap to the usual suspect
'85 Carrera Targa
PCA/POC
Old 02-21-2017, 11:26 AM
jamesjedi's Avatar
I will get it from Napa, thanks for the "heads up". The price is good, which is a nice change.
I will do the leak down test.
Old 02-21-2017, 01:18 PM
Curious what your approach was. Did you disassemble the motor and just change the rings?
I always wondered if one could do a cheap down and dirty engine refresh by just doing rings and bearings...
Of course not as good as a complete rebuild... But better than worn out? With the price of a full rebuild nearing 25k$, it's out of reach for most...
They did it on Chevies all the time...
I know. Blasphemy...
Old 02-21-2017, 03:26 PM
Chain fence eating turbo
I used to be a jet mechanic. If the part checked out, we used it (of course there's a lot of inspection done to validate).
I see people here who replace things needlessly.
The 911 engine, IMO, is one of the most robust motors. There are a lot of parts that don't need replacing. I tossed the main bearings from my motor, but kept questioning why. They looked pristine. Even the rod bearings were near brand new looking.
The one set of bearings that are a must are the IMS. Those show wear really early on.
Old 02-21-2017, 04:40 PM
Great to hear, in case I ever decide to go down this road...
Did you have line bore, or skim the block or heads? Or, did it all go back together well?
Old 02-21-2017, 05:02 PM
jamesjedi's Avatar
My engine is a very low mileage engine that has Raceware Rod bolt and head studs. Cup cams, slightly modified intake. The cylinder heads are also new. The PO disassembled the P's and C's to install lower compression pistons and a Ruf turbo charger. He lost interest in his project.
When l bought it, he reinstalled the original Pistons and gave it new rings. He did race this motor in the One Lap of America. Hopefully it will run as well for me as it did for him.
Old 02-22-2017, 09:02 AM
I PM'd you
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 02-22-2017, 10:33 AM
Originally Posted by afterburn 549 View Post
Tippy
I know you know most everything in / on a aircraft is rented, a bunch of parts with the eviction hour written on it.
With the Porsche, one guy will go several races, the next guy will go 200K
With the AC engine,- there are parameters to stay within so as not to burn it dwn B4 TBO
With the IC engine and single ownership, we do what we will.
There is no NAZI standing over us.
Next the BIG caveat- It is a slippery slope to open a P Car engine and hope its just rings!
If the rings are shot, I will have to guess there are a bunch of other worn areas.
Cylinder walls ?
valve job?
Chains and gears?
Measure pistons and ring lands (lots people forget that one)
ETC
The above is just my opinion as I dabble in AC too
Absolutely. Not saying you can just rering and go. But, the low end of a 911 motor is far more robust than any commuter car out there from my experience. Hence reason many will simply do a top-end job or throw bigger P&C's on an untouched bottom end and carry on with pride.
When my heads were getting rebuilt, cgarr found that my intake guides were in spec. We agreed to leave them alone. What would one gain by replacing them? That's what I am referring to.
Old 02-22-2017, 10:43 AM
Sounds like you will be fine.
