Not a Rebuild - Just Rings
I have new rings in my early 964 engine - not a complete rebuild.
What is the procedure for seating the rings? Thanks. |
Read "break in oil" just below.
Bruce |
Thanks Bruce. I should do this:
"Vary the rpm with no full loads pulls & leakdown test after 500 miles." Yes, and do a leakdown before you first start it so you have a comparison." |
Brad Penn? What grade?
Read about the 30 ND
Brad Penn won't seat, too slick Bruce |
It took a little bit to figure out what 30 ND was. Thanks Bruce!
Now I need to see which brand. Thanks again. I shall do some research. Found this (66 pages); Break in oil- first 20 minutes- Brad Penn or standard non detergent Does it mater what brand of SAE 30? I found a local supplier with these; BRAD PENN HIGH PERF. GREEN SAE 30 NON DETERGENT SAE 30 KENDALL Last edited by jamesjedi; 02-20-2017 at 07:26 AM.. Reason: Added the research |
Try not, Do or Do not
I am not a fan of Brad Penn or Kendall....too much paraffin content.
I like Valvoline 30 wt non-detergent (NAPA 30wt ND id the same) followed by Delo 400.... You choose the weight that meets your temperature requirements.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
I cant say how much I appreciate the input from engine builders. Thanks!
Are you using that oil in your race cars and street cars? I understand if you do not want to answer. Thanks again. |
I also run Supertec SpeedLube in all my vehicles. I use Supertec assembly when assembling all our engines. These formulations we're specifically designed to replace ZDDP and fortify all types of metals subjected to the excessive heat seen in air-cooled engines. ![]() ![]() We caution against using SpeedLube Bearing Life in a newly assembled engine.
Thanks Henry. Always excellent to here from someone who does it for a living.
Member 911 Anonymous
Caution, ND ( Non-Detergent ) is the key for break in. Read the label as NAPA also carries the Detergent added 30W as well.
Do a leak down to get a base reading and 500 miles later another, if good swap to the usual suspect
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I will get it from Napa, thanks for the "heads up". The price is good, which is a nice change.
I will do the leak down test. |
I always wondered if one could do a cheap down and dirty engine refresh by just doing rings and bearings... Of course not as good as a complete rebuild... But better than worn out? With the price of a full rebuild nearing 25k$, it's out of reach for most... They did it on Chevies all the time... I know. Blasphemy... |
Chain fence eating turbo
I see people here who replace things needlessly. The 911 engine, IMO, is one of the most robust motors. There are a lot of parts that don't need replacing. I tossed the main bearings from my motor, but kept questioning why. They looked pristine. Even the rod bearings were near brand new looking. The one set of bearings that are a must are the IMS. Those show wear really early on. |
Did you have line bore, or skim the block or heads? Or, did it all go back together well? |
My engine is a very low mileage engine that has Raceware Rod bolt and head studs. Cup cams, slightly modified intake. The cylinder heads are also new. The PO disassembled the P's and C's to install lower compression pistons and a Ruf turbo charger. He lost interest in his project.
When l bought it, he reinstalled the original Pistons and gave it new rings. He did race this motor in the One Lap of America. Hopefully it will run as well for me as it did for him. |
I PM'd you
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
When my heads were getting rebuilt, cgarr found that my intake guides were in spec. We agreed to leave them alone. What would one gain by replacing them? That's what I am referring to.
