IMR-Merlin's Avatar
2.7 total rebuild coming will need some help
Hi guys.
I posted here a few times, but mostly lurk the 930 forum.
I am helping a buddy with a 2.7 car. He has someone who didn't know jack about the platform rebuild the car. I got it here a while back and did some preliminary digging. The care had no compression on 4-5-6 so I suspected the cam timing was off.
Well we pulled the engine and trans today and there were 5 broken rockers on the (R) side of the engine.
Leak down was about 80-90 on the first cyl we checks so I am assuming all the valves crashed on that bank.
So a top end tear down is coming next weekend.
I will be seeking some advice from this board for sure.
If the valves do crash, what is the chance the pistons are that badly damaged that the bottom end needs a rebuild. I am trying to not split the cases.
Brendon
82 twin plugged, EFI, G50 930, RSR suspension (soon to be) GT35R...
Old 04-15-2017, 12:16 PM
tharbert's Avatar
The rockers worked as advertised. They are designed to break like that when valve/piston contact is made. That (hopefully) saves other parts of the valve train from damage.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 04-16-2017, 05:35 AM
Usually when the piston tags the valve, breaking the rocker it shows up on the face of the piston by the exhaust.
The bottom end usually goes when the valve head breaks off bending the rod, holing the piston and head and blowing shrapnel through the injection and in the case.
Bruce
Old 04-16-2017, 12:31 PM
IMR-Merlin's Avatar
I am getting leakdown in the intake and exhaust side so the valve have to be bent. Tear down is happening late this week or weekend
Brendon
Old 04-17-2017, 07:58 AM
I hate to say it, but if somebody who didn't understand the motor did the rebuild, then I'm guessing you'll want to tear into the case anyway just for piece-of-mind.
Old 04-17-2017, 08:54 PM
IMR-Merlin's Avatar
From my understanding, he only did a top end rebuild. The Owner was there a lot and he's not even sure the heads were pulled off. I am treading lightly as this "rebuilder" is my buddy's father inlaw....
I have office work all week, then I am planning some shop time to get into the engine. Once I dig deeper, I will post up the carnage.
Old 04-18-2017, 05:58 AM
I would hope the pistons are save-able but plan for the worst. Father in law, eh?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-18-2017, 06:14 AM
IMR-Merlin's Avatar
yeah, it's a touchy subject. I was going to put an offer in on the car and use the parts to build a light weight car to go side by side with my 930... I am glad I didn't..
Old 04-18-2017, 10:55 AM
Vintage Owner
Jack Stands's Avatar
Once the heads are off, you might have an idea of the damage, but I'd also think that a complete tear down would be appropriate if in doubt.
If you need specifics, Wayne Dempsey's book on rebuilding 911 engines uses a 2.7 as his example and goes through the steps involved very thoroughly.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 04-19-2017, 06:40 PM
IMR-Merlin's Avatar
It's on my book shelf
Old 04-20-2017, 06:28 AM
What's with the trepidation on splitting the case? If the top end looks like that, you could have:
- bad rod bearings
- bad crank bearings
- scored crank
- oval cylinder spigots
- pulled head studs
Read Dempsey's book and do the whole thing.
Old 04-30-2017, 09:36 PM
IMR-Merlin's Avatar
- bad rod bearings
- scored crank
- pulled head studs
I have the book and we are planing a total rebuild now. he's ordered a yoke so we're on hold for a few days.
Old 05-01-2017, 09:18 AM
IMR-Merlin's Avatar
Got my yoke delivered yesterday and pulled the engine number
Looks like I have a 2.7 out of a 75 Sportomatic car
*6459117*
Old 05-13-2017, 04:14 PM
Irrationally exuberant
ChrisBennet's Avatar
- bad rod bearings
- scored crank
- pulled head studs
Splitting the case on anything *but* a 2.7 is a just a bit more money.
A 2.7 case is a different animal and will most likely require resizing - sending it to a west coast machine shop for +$1000 worth of work. I'm not saying you shouldn't split the case, just be aware of what you are in for.
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-14-2017, 04:32 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Just take careful steps in pulling out the old or damaged head studs, you do not want to take off case material when you remove them. Ask me how I know.
I would let a pro do it and have them clean up the threads or insert CASE Savers if needed.
'85 Carrera Targa
PCA/POC
Old 05-14-2017, 06:55 AM
*6459117*
Funny, I'm just starting on a 2.7 out of a '77 Sportomatic. The crank is on my bench.
Old 05-14-2017, 07:58 AM
IMR-Merlin's Avatar
thanks for the input guys. I will update as i dig in.
Old 05-14-2017, 08:19 AM
Timely post, a certainly buddy of mine is helping me (alot!) with my 2.7L sportomatic rebuild. Thanks ChrisBennet
Looking forward to this 2.7 rebuild to see how best to do mine!
Old 05-14-2017, 11:37 AM
IMR-Merlin's Avatar
where in New England are you?
Old 05-14-2017, 11:48 AM
Oh too funny! Southern NH too. I wonder if we both know ChrisBennet
PM me and we can see if we have Pfriends in common or have met at a tech session etc.
Old 05-18-2017, 06:01 AM
