(the shotguns)
Do you feel like the instruments are a bit...hidden or muddled? Overly subdued maybe? Maybe what i'm getting is they are lost in a big space? Does a 'warm' sounding speaker hide this?
Then again i keep reading Rumours is one of the all time great recordings and much as i love the songs i'm kinda 'meh' on the recording itself.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
they are very efficient @93dB my also very efficient JBL L100s are only 90dB even though they are efficient the Polks can take lots of power, I used to run them w/ 2x 1000watt amps in a bi-amped configuration, these days in my dotage I use a single 500watt amp I used burn out the JBLs regularly w/ single 500watt amps
OK ... I'm "ready" ... should I Polk & amp this thread or start another one with my nonsense?
Wouldn't want to go off topic ... again
Alter Ego Racing
nah, no matter where you post it will derail.
I posted on another forum about my then new tube amps and it derailed into a discussion about "using tube amps is wasting energy and a clear sign of your white privilege". Let it rip
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion |
Model Citizen
I watch Paul from PS Audio every morning on YouTube while I have coffee; his viewers are actually mostly pretty civil. A few miscreants want to throw bombs, but for the most part, a gentleman's group of enthusiasts.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Alter Ego Racing
paul is a friend
Model Citizen
He seems like a really nice person. God knows he works harder than almost anyone half his age.
(the shotguns)
His basics videos on room treatment and speaker placement/imaging are immensely helpful.
Alter Ego Racing
Paul is a gem for the hobby. He know more than what I have forgotten and he shares knowledge freely on a daily basis. He does his daily videos, his daily posts and is active on their forum. Not to mention audio shows, designs, etc.
He shared a lot of knowledge with me about my speakers. He didn't have to as they are no his current nor prior brand. He likes them though and owns a set! Great fiction writer also ( I know there is a joke in there ).
If bi amping I think one really good amp would be a better solution, unless adding in an electronic crossover, and that adds other problems.
87 930, Last edited by 908/930; 02-17-2025 at 06:56 PM.. |
Since were all over the shop here I might as well ask before I try to remember my user and password to avsforum.
I have a VMPS large that I’ve been running through a pair of bridged mono GFA-555s. Mostly used for movies. I recently found the smaller (4 ohm) woofer is causing the amp feeding it to soft clip like crazy and the larger woofer (8 ohm) also needs a bit more grunt. Anyone have a suggestion for amplification that doesn’t require a second mortgage? I picked up the Adcom’s for about $250 a pop used and they were ok until the new receiver reoptimized the room. Now I need some more electrons. |
Alter Ego Racing
87 930, |
Bridging into 4 ohms is tough on any amp, the effective current for each bridged channel is that of a 2 ohm load as stated above.
These are passive subwoofers you are trying to drive? CrownvXLS series is very good for that application. Pro amps but the fans arnt noticeable, they have consumer inputs and voltages, and adjustable gain. I have an XLS1502 bridged into a 4 ohm 18" ultimax DIY sub (1.6 kW). Puts out way more bass then anything in my house can deal with. If you have 2 passive subwoofers Id get a bigger XLS series and run each in a non bridged channel though. Its just a better setup and watts are cheap enough in these series. Otherwise as stated in an earlier post hypex based class d amplifiers for huge power, a bit more expensive and less flexible, but basically SOTA amplification at a reasonable cost. Overkill for sub only maybe. Buckey amplifiers, VTV applifiers, Nord acoustics, apollon amps, there are a dozen or so companies that package these modules into turnkey amps
84 930 07 Exige S |
Yep, in prosound applications we always use a dedicated amp for each passive sub that is impedance matched to the speaker with a high dampening factor to handle LF energy without stressing the components. We also use a subsonic filter to eliminate subsonic energy that robs amplifier power. This really cleans up the bottom.
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) Last edited by Cajundaddy; 02-18-2025 at 11:54 AM.. |
The 12” is 4ohm. The 15” is 8ohm. I’ve had to turn the bass down 10db (from where the audyssey wants it) to tame the clipping and it’s still not happy. I could bridge the woofers - so 6 ohms - and biamp into both, but I was hoping for a neater solution. I looked the the crown, but my receiver has RCA preamp outputs for the sub. Last edited by Alan A; 02-18-2025 at 02:16 PM.. |
Crown XLS has RCA input. Possible to adapt the XLR to RCA on other amps
87 930, |
This, and they're not expensive.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
Didn’t see that. I’ll go look again. Thx.
