LinkBack Thread Tools Rating: Thread Rating: 5 votes, 2.60 average.
Sunday morning at 7:15 they get back on it with the trowel machine. It spins metal blades and basically polishes the slab to a smooth finish. It can't get into the corners so that has to be troweled by hand. More hard on your knees work.
Old 12-03-2018, 05:54 PM
A930Rocket's Avatar
Looks good!
Old 12-03-2018, 05:57 PM
I wanted a curb so the walls will be up on the curb. This makes the bottom edge of the interior walls to be off the floor. Also easier to clean the corners and find that ball bearing after I drop it.
Old 12-03-2018, 05:59 PM
The slab will have control joints cut tomorrow. This is right at 600 s.f. The cut out in the curb is for the door.
That's all for now. Wall framing is next. Stay tuned.
Old 12-03-2018, 06:05 PM
Can the architect do the structural calc in FL? That seem to be a pretty simple built and its a non living space. I wish we have that much land out here I would do the same thing. I am keeping on eye out for this thread, interesting for sure.
Only if the Architect is a licensed PE and not many are. I tried to only used signed/sealed drawing from the Architect with building department. Told the plans reviewer it was a work shop addition and not a living space but no go. I needed s/s plans from a PE. $750 later I get the detailed structural drawings. All structural members are sized, details on walls, slab etc.
Old 12-03-2018, 06:13 PM
Shaun @ Tru6's Avatar
Great project! How does the perimeter framing work? Is the concrete poured and cured and then the wood pulled away and then the slab poured? Or is the wood left in place?
Tru6 Restoration & Design
Old 12-03-2018, 06:42 PM
A930Rocket's Avatar
^^^ The wood is a temporary form. The footer/edge is poured first, then the slab. All in one pour. We call it a mono slab, but there are probably other names. After the concrete is firm enough, the forms are pulled to finish the inside edge/top/outside edge, fill in the honeycomb, etc.
One thing I noticed, was no anchor bolts installed. Will you drill and epoxy threaded rod in?
Old 12-03-2018, 06:48 PM
Thanks, that's what it looked like, and seemed logical. Important to know for my own project this spring.
Old 12-03-2018, 06:55 PM
That's right. They are actually threaded rods that are epoxied in and connect to the top plate of the wall. Engineer calls for 3/8" which I thinks is pretty thin. I was lucky to find some 5/8" rods from a friend for free.
The outside forms were able to be removed late on Saturday after about 6 hours after pouring.
Old 12-03-2018, 06:56 PM
A930Rocket's Avatar
3/8”? That’s really small.
Years ago, we used 1/2”. Now it’s 5/8” every 4’. An LTT19 every 8’ and both sides of all doors and windows.
Make sure you get good embedment...9” or so. Drill the holes and use a bottle brush and compressed air to clean the holes out. 3” square washers.
Old 12-03-2018, 07:01 PM
I'll have straps, clips, brackets, rods, etc, etc. Simpson Strong-Tie owe the code writers big time.
Old 12-03-2018, 07:10 PM
rfuerst911sc's Avatar
Paul looking good so far I will be following your progress . Will you install AC ?
Old 12-04-2018, 04:01 AM
I see you
flatbutt's Avatar
Cool, keen to see how you treat the roof wrt big wind.
Old 12-04-2018, 04:21 AM
Zeke's Avatar
Nice, and I read where you said concrete "placed," which is the trade term. But it was still workable the next morning!!??
Old 12-04-2018, 09:46 AM
Yep I'll need AC for sure.
Old 12-04-2018, 10:56 AM
We had a lot of rain, high humidity and mild temps so yes they could still trowel it the next morning. If it was in August with the sun beating on it they would have had to stay an finish it same day.
Old 12-04-2018, 10:58 AM
It sure makes it easier when you don't have to worry about frost heaves.
Cool project. When we were looking for our house I told my wife if it did not have a three car garage it had to have the space to build a workshop. We found a place with a three car garage and a built in workspace. I still want to build a workshop, but it is never going to happen with a wife that is a master gardner, and keeps expanding the gardens.
Old 12-04-2018, 02:04 PM
Motorsport Ninja Monkey
Captain Ahab Jr's Avatar
Paul, looks good so far, thanks for starting your thread
I'm really going to enjoy following your build and to see how you do it on the other side of the pond
Wer rastet, der rostet
He who rests, rusts
Old 12-04-2018, 02:18 PM
Thanks Captain. I've been watching your build and planning mine. My 2 x 4's are going to be a lot lighter than your stones and steel beams.
Old 12-04-2018, 03:42 PM
Last two weekends I been prepping the existing utility room walls for the tie-in of the new addition's walls. I've removed the vinyl soffit material and the 1/4" masonite which appears to be original to the house.
Old 12-16-2018, 04:06 PM
