Still here
pmax's Avatar
It's just simple plastic fittings and crap. You can do it, no pressure ! Just make sure no one uses the toilet
Looks like one might have already been replaced with the Y as circled in green.
OK, I bit the bullet. I really didn't want to crawl under the house. It had some seriously black, sticky mud/dirt. It was probably only 8-12 feet from the entrance. I did what I said, telescoping PVC, hole drilled through both with a bent nail through. The bigger pipe's end was cut in a V (like a mouth, not a spear). When I pulled the cap, a little bit of toilet paper and water came out but not much, a cup or two.
Watch out for the black widows !
I did once pull the snake out and found the last inch was full of what seemed to be super fine roots. I was afraid that the issue was due to the small snake not really cleaning them out enough, and with spring coming on, maybe more have grown.
Old 05-05-2021, 10:11 AM
I had my eyes open, but there doesn't seem to be anything living under the house (which is great, IMO).
Old 05-05-2021, 10:21 AM
Still here
pmax's Avatar
You gotta crawl under at night and have a look with a flashlight, don't leave it on for too long or they'll hide !
In the daytime, look for the webs.
Old 05-05-2021, 11:05 AM
Hahah. Yep, I saw no webs while I was down there which was surprising (but made me quite happy).
Yes, I was down there with a flash/headlight in the last 30 mins before sunset. It wasn't pitch black, but it was pretty dark.
I've actually been very surprised that I've seen very few spiders since we've moved in. I've only recently seen a couple of small ones outside the house. I haven't seen any inside the garage which seems like it'd be prime territory for spiders, and I haven't seen any under the house or inside the house.
I'm sure it's only a matter of time.
And, apparently, there are tarantulas in the area. I haven't seen any, but some folks from the neighboring county have posted photos on facebook of tarantulas that they've run across.
If I was under the house and ran into a tarantula, I don't think it would go well for either of us.
Old 05-05-2021, 11:42 AM
My brother and his son were doing some rearranging out in the shops and ran across this guy hiding under some siding he had stored between the shop buildings.
Let's hope you don't run into any of them under the house.
Scott
'78 SC mit Sportomatic - Sold
Old 05-05-2021, 11:54 AM
wdfifteen's Avatar
There are some jobs that I just won't DIY. Crawling under a house with bugs and snakes and whatnot is where I turn to my superpower to solve the problem.
Old 05-05-2021, 12:54 PM
I was thiiiiiiiiiiis close to going that route.
I also want to swap out the lid or lids on my septic tank. The one on the first tank has been hit by the mower, and is broken. I managed to get the lid off (not that hard) and then back on (huge PITA) yesterday. I'd either like something that's not cement, or something cement with handles, preferably handles that drop down when not in use.
What I found especially crazy when searching the 'Net for photos of septic tanks was how many had square access holes and lids. It seems insane to have anything other than a round hole/lid, at least, if it's concrete.
Old 05-05-2021, 12:56 PM
MBAtarga's Avatar
That card is neat! What does the other side look like?
Mark
'83 SC Targa - since 5/5/2001
Old 05-05-2021, 02:11 PM
Mother nature defeats that superpower especially in the middle of the night or evening or outside working hours.
You've just got to keep bumping the number up. Eventually someone will come out on nights and weekends if you're willing to ring up enough $$$
Old 05-05-2021, 03:14 PM
Still here
pmax's Avatar
Yeah, a lot can happen in the hours while waiting for them to show up. And guess who has to calm down the fam during that time ?
Old 05-05-2021, 03:18 PM
Platinum Member
dad911's Avatar
I also want to swap out the lid or lids on my septic tank. The one on the first tank has been hit by the mower, and is broken. I managed to get the lid off (not that hard) and then back on (huge PITA) yesterday. I'd either like something that's not cement, ..........
For safety lid should be locking or bolted, with a riser to grade. Find a supplier, they will know what's 'legal' for your area.
Old 05-05-2021, 03:37 PM
wdfifteen's Avatar
I like it that it has my image on the front. The other side doesn’t have my picture on it, so you would be bored.
Old 05-05-2021, 03:45 PM
wdfifteen's Avatar
I
In my experience the square lids have been for the risers. The tanks themselves have always had round covers. Drop a square lid into a riser and you just reach down and get it out. Drop a square lid into a tank and YEEEOWWW!!!
Old 05-05-2021, 03:47 PM
Jolly Amaranto's Avatar
We get our share of critters at the country place in Milam County.
Old 05-05-2021, 04:06 PM
A930Rocket's Avatar
Originally Posted by BK911 View Post
The fitting circled in green is questionable, but I would probably let it slide if all else was ok. The two in red are just wrong and will cause blockage every Wednesday after taco Tuesday.
That’s what I was saying. No way that meets code.
Old 05-05-2021, 07:56 PM
And out of the bunch, the bottom one would freak me out the most.
Apparently, those are not far from here either. I don't know if they have them right here, but there are folks that aren't that far away that say they have them.
Old 05-05-2021, 08:47 PM
You do not have permissi
john70t's Avatar
Cut and angle it up with "y" connections?
Old 05-06-2021, 09:17 AM
Home of the Whopper
I am about as cheap as they come.
No way I am crawling under a house to mess with poop pipe.
You have to excavate around the joints, then cut the pipe, then fab and glue the new pipe.
I'm with Patrick; american express time!
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 05-06-2021, 09:31 AM
Still here
pmax's Avatar
Looks like you have 3 ft of crawl space ... go for it !
Old 05-06-2021, 02:05 PM
Looks can be deceiving. I suspect it ranges from 12 or 14" up to about 20-24".
It's doable, but not terribly pleasant.
Old 05-06-2021, 03:09 PM
